09-03-2021, 11:34 AM | #26 |
Re: 69 stepside RHD built
Cool build! Steppers are getting popular!
09-12-2021, 10:01 AM | #27 |
After blasting stepper bed, here is progression to reshape and repair rust. For marking hole at rear fender, Lucky to me that can find original fender purpose to measuring position for install rear side marker.
09-14-2021, 10:32 AM | #28 |
Tailgate repair lower part by section renew and replace with new section from zinc sheet plate as same as original sizing. I have had design bushing of tailgate pivot by machine bushing made from brass and round shape bottom of tighten bolt. Brass bushing of both side can be reduced friction of bolt if tighten over limit.
09-14-2021, 07:05 PM | #29 |
Very nice work!
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
09-15-2021, 04:55 AM | #30 |
Just impressed when stepper bed was fit on chassis. Due to raining season in our country I will hurry next step painting to reduce occasional of new rust on repaired bed surface.
09-17-2021, 09:57 AM | #31 |
Some progression both left and right rear fender.
09-26-2021, 01:47 PM | #32 |
Post Whore
Welcome, and I have so much respect for you guys outside of these United States because it must be so hard to find parts for these trucks, here you can't throw a rock without hitting one, ha ha
keep grindin' (oh and too bad about the stepside I love them things) |
09-27-2021, 01:11 PM | #33 |
Thank Gregski. I try to build C10 stepside look beauty as much as I can do, so I leave my project for few years ago to seek new truck and collection parts from US that expensed a lot of money for every items on ebay buying need to pay for tax and freight. Quote reply from everyone were increased my attempt to do my build thread goal. Thank you again.
09-28-2021, 05:04 AM | #34 |
Finished paint stepper bed and install on chassis. Change rear axle from 8 lugs to 5 lugs GM 12 bolt from first project that I kept for this project. Temporary wheel from W-work 265/35R18 in rear axle.
09-28-2021, 05:08 AM | #35 |
Work progression pictures.
09-29-2021, 11:42 AM | #36 |
Very nice results!!! Nice color too.
09-30-2021, 03:35 AM | #37 |
Great progress. The color looks nice.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
09-30-2021, 08:13 PM | #38 |
Suay mak.
Keep up the good work. You don't see those trucks much at all there. I see what looks like a 60-66 peeking out from under cover. Choke Dee from Burriram. |
09-30-2021, 10:14 PM | #39 |
Great looking Work!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
10-01-2021, 09:14 AM | #40 |
Kindly accept my sincere appreciation for all guys generous compliments.
10-01-2021, 09:56 AM | #41 |
For front suspension my C10, I was redesign of both upper and lower control arm from local parts from idea picture below. I made new bush housing and machine new shaft of both upper and lower control arm. Then I can use bushing from local parts that I was selected for apply to all control arms.
10-04-2021, 10:20 AM | #42 |
I ordered instruments gauge cluster brand intellitronix model type AP-6003 and bought chrome dash bezel. I think this gauge cluster can be apply for reading engine RPM, speed MPH, volt, fuel level, temperature and oil pressure from LT-1. I bought billet tilt column as well but some think mistaken, I never study how much of length tilt column before ordered. This tilt column too short and I will find the way for apply its to mine stepper. Used lecarra steering wheel look suitable for this tilt column.
https://www.intellitronix.com/produc...k-67-72-analog |
10-07-2021, 05:06 AM | #43 |
Assembling of all prepared suspension of both front and rear parts. Rear stabilizer bar was installed as many thread had install it.(copy idea ) I can find unused parts in garage apply it to both rear trailing arms. Front suspension with disc brake conversion to 5 lugs.
10-07-2021, 09:36 AM | #44 |
Very nice work and great commitment. I'm sure you will have a crowd pleaser when you get done!
Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
10-08-2021, 02:51 AM | #45 |
10-10-2021, 10:52 AM | #46 |
Today is processing of wiring engine diagram for my truck. Not finish today and will carry on next week again.
