Closed Thread
Old 02-22-2014, 10:40 AM   #26
tincan1966
tincan1966's Avatar
Re: John Lee's Halogen Headlight with Relay's Upgrade
Originally Posted by luvbowties View Post
Just for information, I recently installed a kit from LMC, one I'd ordered several years back. It was relatively plug 'n play, simple to install, and seems to work just fine. Of course, they may be selling a different product today(?); if so, it may be a different quality. However, I am satisfied overall with the one I used.
Sam
I also like the fact that the kits offer the molded plug for the relays to help protect the terminals a bit from corrosion.
I normally purchase the plug housings and terminals separately from our suppliers and make my own.
Anything that goes under the hood needs to be somewhat weathertight, if nothing else, at least with heat shrink.
Have also installed similar kits like LMC's and no modification is necessary, just plug and play. We use the H4 conversion bulb housings.
tincan1966 is offline
Old 02-22-2014, 11:14 AM   #27
chevyrestoguy
chevyrestoguy's Avatar
Sharps-
You always have the best "How-To" threads. Your postings should go directly into the FAQ Sticky. There's a couple that you have posted that are on my To Do" list.
As always, GREAT job!
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline
Closed Thread
