Old 11-01-2013, 10:37 PM   #26
colgad
colgad's Avatar
Re: power window regulators on the cheap
I got my first one built and here are a few pics. I added to the gear the guide due to the fact that without it the slop in the bearing is close to coming off the motor gear.
I used studs for the motor (welded in), I was afraid that I was wearing out the thread's in the 1/8 steel plate with as many times as I had it on and off. And my Harbor Freight tap was not the greatest.
Please no comments on my stellar welding.
The template was right on and only had to grind it once to made the gears fit together.
Now I have to do the other one!
Thanks for this great Idea
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 11-01-2013, 11:13 PM   #27
bonnieclyde100
looking good . that was a great idea to add the guide on there wish i had done that but mine are more towards the middle of the gear so maybe i wont have any problems none so far
bonnieclyde100 is offline   Reply With Quote
Old 11-02-2013, 10:16 AM   #28
vannatta20
vannatta20's Avatar
Does anyone have info on what all is needed to wire this up?
vannatta20 is offline   Reply With Quote
Old 11-02-2013, 02:00 PM   #29
bonnieclyde100
i wiured mine up with wiring and switches from an aftermarket power window kit i had but you could use any factory wiring and switches from a junk yard if you want most gm stuff is wired up the same
Old 11-02-2013, 04:24 PM   #30
Bigdav160
Bigdav160's Avatar
Has anyone installed their modified regulators yet? Does the window move through the whole range correctly?
I was worried, looking at the angles in the template and other picture, that the motor is not placed properly. Maybe it's an optical illusion.
Since the gear is repositioned 90º from the arm, it would make sense that the motor would need to be 90º to maintain the same relationship. It's hard to tell but Colgad's looks correct.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 11-02-2013, 09:14 PM   #31
colgad
colgad's Avatar
You need a DC reversing switch, here is one from Northern Tool:
http://www.northerntool.com/shop/too...FSEV7AodmHYAQQ
Here is the wiring:
Old 11-03-2013, 12:11 AM   #32
nitrosport_5
nitrosport_5's Avatar
Subscribed. I plan to try this out with my windows on my truck. Was goingto buy aftermarket but im all for the cheap way out!
"Rusty" 1972 K20 Cheyenne Super, 496, A/C, Tilt, Tach, Buckets, 4l80e/NP205, 4" Rancho Lift, 35" BFG AT
"Ramp Truck" 1972 C30 Ramp Truck 350, Air Bags, Factory A/C.
"1968" C10 Shortbed project
nitrosport_5 is offline   Reply With Quote
Old 11-03-2013, 12:56 AM   #33
bonnieclyde100
the motor bracket is mounted at an angle because when you mount the regulator in the door the regulator plate that bolts to the door is at a slite upward angle . if i would have made the motor bracket 90 degrees to the regulator bracket the regulator would have ran out of teeth before the glass got all the way to the top
Old 11-03-2013, 12:02 PM   #34
First c10
First c10's Avatar
Subscribed
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 11-03-2013, 04:37 PM   #35
Bigdav160
Bigdav160's Avatar
Too late. I couldn't wrap my head around the need to not be 90º. My Suburban is at the shop (work) and I have some metal and spare regulator at (home) shop so I built this. I guess I'll find out if it works soon enough.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 11-13-2013, 01:42 AM   #36
jimcaf
jimcaf's Avatar
I did mine a few weeks ago right after I saw this post, Thanks for the great post bonnieclyde100,, they work amazing,lots of power they roll up fast enough where youll want to make sure your fingers are clear
1971 Chevy C-10, 5.3, 4L60E,4.10 gears UNDER CONSTRUCTION
Mid size bed conversion https://picasaweb.google.com/1114721...yC10MidSizeBed
The basic buildup https://picasaweb.google.com/1114721...3/1971ChevyC10
jimcaf is offline   Reply With Quote
Old 11-13-2013, 02:05 AM   #37
BlacklandCamper
Sweet!!
Great idea.
Grunt: 1971 C20 Custom Camper. Runs/Drives/Kinda stops. 350Ci, TH350. 4.10:1 D60. Eight Lug LWB is more better. Hell no its not fast!
Donkey: 93 Nissan D21, the farm truck. My 1/2 ton SWB. The Indomitable Datsun.
1st BN 3rd MAR. '00-'04
BlacklandCamper is offline   Reply With Quote
Old 11-13-2013, 07:35 AM   #38
bonnieclyde100
your welcome glad to see someone got some use out of it things are getting very exspensive and it nice to be able to save some money
Old 11-13-2013, 09:27 AM   #39
snipescastle2
snipescastle2's Avatar
Talking Re: power window regulators on the cheap
So, has anyone adapted a factory power window harness for control of the passenger window as well as the driver side from the driver's door switch?
I know there are aftermarket kits for these, but trying to keep with the "On the Cheap" Theme here.....any ideas?
Thanks!
Ben
snipescastle2 is offline   Reply With Quote
Old 11-13-2013, 11:13 AM   #40
jimcaf
jimcaf's Avatar
Thanks!
Ben
I havnt done my finish wiring but plan on getting switch's from ecology just putting a right and left switch and mounting them some how under the heater controls where a driver and pass can access them leaving the door panels smooth and clean
Old 11-13-2013, 10:41 PM   #41
rx78nt1alex
rx78nt1alex's Avatar
I have seen this developing over the last couple of days, and I have been thinking about how to keep it looking as stock as possible. There was some company that made switches that allowed you to use the factory window handle to bump it up or down, activating the switch but it goes for $150 for a pair of switches.
I thought of making a mechanism of using 80's style GM chrome switch inside of a bracket inside the door, or a using newer style rocker switch with a lever attached to the window crank to rock the switch, plus adding stops to keep the lever over the switch and springs to keep it centered, in keeping with being "on the cheap"
I just got my welder and might try this.
1968 Chevrolet Fleetside C-10
1971 Chevrolet Fleetside C-10
rx78nt1alex is offline   Reply With Quote
Old 11-13-2013, 11:11 PM   #42
Lee H
Lee H's Avatar
Nice!!! I was thinking along those lines but had not gotten that far.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 11-13-2013, 11:13 PM   #43
bonnieclyde100
that wood be cool do a write up on it when your done
Old 11-13-2013, 11:28 PM   #44
rx78nt1alex
I will for sure, it just may take me a bit. Bear with me.
Old 11-13-2013, 11:30 PM   #45
fish938
These?
http://www.electric-life.com/shopexd.asp?id=1372
fish938 is offline   Reply With Quote
Old 11-13-2013, 11:34 PM   #46
rx78nt1alex
Exactly.
Old 11-13-2013, 11:39 PM   #47
jorgensensc
jorgensensc's Avatar
Can't you just use a couple of micro switches, like you can buy at radioshack, to do the same thing? Vintage air uses micro switches on thier AC units with the cable driven controls. Just an idea.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 11-13-2013, 11:45 PM   #48
rx78nt1alex
That would be better. I will check out Fry's. Especially since they are already in a format that allows for mounting. See, this is why I posted my idea and see what everyone might say to improve upon it.
Old 11-13-2013, 11:48 PM   #49
jorgensensc
Kind of like these:
Old 11-14-2013, 12:27 AM   #50
mmiddle
mmiddle's Avatar
This has been on my mind as well. My thought is to use micro-switches activated by the window cranks. Much like the pricy fancy models offered, but with $10 micro-switches. There is very little amperage going through the switch so a small switch is all that is needed.
It will be months before I get to this stage in my build. So if anyone wants to take the lead I can help with info on possible switch selection.
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
