Old 12-10-2013, 06:45 AM   #26
JointTech
JointTech's Avatar
Re: Project "Black Cherry" 68 c/10
i like those. nice build.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 12-10-2013, 04:43 PM   #27
1Bad 37
1Bad 37's Avatar
Nice tails!
1Bad 37 is offline   Reply With Quote
Old 12-10-2013, 09:25 PM   #28
stevenbear72
stevenbear72's Avatar
Thanks guys, I ordered the EFI bed fill Boyd Welding tank for the truck as well, just waiting for it to come in.
Also ordered a new trans cross member from CPP, but am thinking about changing my CPP tubular perches to the ECE ones.
Any truth behind me getting a discount on the Doug Thorley headers because I am a member on here? Those are the only headers that will fit my damn CPP tubular mounts.
Anyone know where to get a driveshaft in San Antonio with 1350 yolks and cut to length for the 4l60e to 12bolt length?
68' Cst10 w/69 front, 5.3/4L60e swap, 12 bolt 4.11's
Project "Huckleberry"
68 GMC K1500 1/2 ton L83/6L80e
stevenbear72 is offline   Reply With Quote
Old 12-14-2013, 08:51 PM   #29
stevenbear72
Some more goodies arrived.
Alper Motorsports billet 3bolt to 4bolt TB adapter
New GM 90mm ls7 style Throttle Body
Lokar flexible aluminum trans dipstick
Old 12-21-2013, 12:18 AM   #30
stevenbear72
Got an early xmas gift from myself. It's a Boyd Welding EFI Stealth bed fill with an In-Tank Aeromotive Stealth 340 Pump.
Old 12-21-2013, 09:10 AM   #31
solidaxel
solidaxel's Avatar
What is the engine cover from, it looks like 3 pieces?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-21-2013, 02:03 PM   #32
Houston Ben
Houston Ben's Avatar
Hi Steven, I used a duel electric fan off a 2001 ford windstar and it works great! I have an 86 though...
Houston Ben is offline   Reply With Quote
Old 12-22-2013, 12:52 PM   #33
-T-
-T-'s Avatar
good start!! Those Boyd tanks are a great piece. I picked up a late model blazer tank from my local yard, we will see how that works out for $75. I have used the Doug Thorley headers on my first 6.0/4L80 swap and the only issue is with the trans shifting hookups. That has been 3 yrs now so someone may have came up with a solution but the collector was right at the shifter rod for the 80 and it took some work to get the shifting correct. Good luck
-T- is offline   Reply With Quote
Old 12-22-2013, 01:13 PM   #34
Marv D
Registered Truck Offender
Marv D's Avatar
A little late to the party here but just for others following this VERY NICE build,, (which BTW is SCHWEET!!!)
RicksTanks makes noce stainless EFI tanks that fits most anything,, will put the right 'in-tank' pump, or a Walbro external pump, and whatever ohm fuel sender you need installed in the kit. I don't remember what he charged for the tank for my El Camino project, but it was a polished stainless specifically for Caminos with the side fill (not top or behind the rear plate like a car)
Another nice thing about Ricks,, Slummit sells them and you can get free shipping on a lot of stuff during specials.
sorry, not trying to hijack the thread, just adding info and wanted to say
NICE BUILD!!!!!!
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 12-22-2013, 06:33 PM   #35
stevenbear72
It is a 3 piece cover, I believe its from a 6.0 escalade, I may be wrong. I'm thinking about smoothing it out and painting it. Either that or sell it and get the one piece cover.
Old 12-22-2013, 06:35 PM   #36
stevenbear72
I have those stupid tubular CPP mounts, so might have to be stuck buying the Doug Thorleys since those are the only ones that clear those mounts. I may also just throw those CPP mounts or sell them, and order the ECE mounts or the Classic Performance Online ones.
Old 12-22-2013, 06:37 PM   #37
stevenbear72
I'm having an issue with the bottom of the 90mm tb hitting the neck of the water pump, need some advice as to what you guys would do in this situation?
Old 12-22-2013, 07:53 PM   #38
dayj1
I would buy a water pump from a '07-up 5.3 application. The outlet is positioned differently to clear the 4 bolt DBW throttle body. If you search, you'll find where some have cut/welded the pump outlet or heated the pump body and turned the outlet.
dayj1 is offline   Reply With Quote
Old 12-23-2013, 08:43 PM   #39
stevenbear72
Thanks for the info, I may just buy the newer pump. Is this the correct model?
Old 12-23-2013, 09:26 PM   #40
dayj1
That's the one. You'll need a belt tensioner as well (it bolts to the water pump). If you do buy a new pump, take a close look at how your radiator hoses are going to route. If it works out better, the Gen 5 Camaro (2010 up) L99 water pumps have the same belt spacing as the trucks and the outlet is on the driver's side. Just another option if the hose routing works better with whatever radiator you have. Here's a pic of the L99 pump:
http://ls1tech.com/forums/14992658-post12.html
Old 12-23-2013, 11:26 PM   #41
solidaxel
solidaxel's Avatar
Can you use the truck water outlet and thermostat, or do you need the Camaro parts?
LS 3 4L70E
Old 12-24-2013, 12:11 AM   #42
stevenbear72
That Camaro pump wont work for me, because of the RnD radiator Im going to purchase has both the upper and lower hose coming out on the same side.
Like Menace's radiator
Old 12-24-2013, 12:37 AM   #43
dayj1
I'm pretty sure the thermostat and housing are different, but I don't know that for sure.
Old 12-24-2013, 10:25 AM   #44
solidaxel
solidaxel's Avatar
Anybody ?
What degree thermostat is "proper"?
LS 3 4L70E
Old 12-27-2013, 08:24 AM   #45
68c10airstream
68c10airstream's Avatar
Hi 1 bad 37, finally someone is doing a vette irs/ drivetrain in a pickup. I have thought for a long time if you wanted the best ride, and lower it a lot (not my style) and have the least modifications to the box floor why not vette irs. It should handle like a dream, and go like heck. Will be keeping an eye on this one, good luck, Brian F.
68c10airstream is offline   Reply With Quote
Old 12-27-2013, 11:56 AM   #46
whitels1
whitels1's Avatar
When I ordered my water pump I ordered it for a 2008 GMC Denali with a 6.2 L92, hopefully it will clear. he is a picture of mine mocked up.
Also a picture of the 98 windstar fans.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 12-28-2013, 07:31 AM   #47
eagleuh1
eagleuh1's Avatar
Those Windstar fans look like they fit good. Trucks looking like its getting some good quality parts. I like my Doug Thorley Tri-Y headers on my 5.3. 68C20, as well as the Boyd Welding tank. Needs a better venting system though. Mines a side fill though. Jim
eagleuh1 is offline   Reply With Quote
Old 12-28-2013, 09:06 AM   #48
rgonza
My name is Steven and I am new to the c/10 lifestyle. I have never owned a truck before, let alone a classic one. I recently purchased my 68 Chevy c/10 with a 5.3/4L60e swap. The guy i bought it from was going through a financial hardship and had already done most of the work to the truck. The cab corners, and rocker panels have been replaced as well as removing the gas tank from the rear seat and welding off the factory filler location.
I will have tons of questions about building my truck to my liking and figured this was the best place to seek out the help from fellow chevy truck enthusiast.
I have owned several nice cars, in my mind, in the past and love to learn new things about different types of vehicles.
Here are some photos as the trucks sits at the moment. He did most of the body work and had the cab and bed already painted, so i may as well paint the front end to match, and enjoy the truck the current color it is before taking it all apart and going with a two tone orange/white cheyenne look.
I'll try post some other pics in the next few days.
Name is Steven and I'm addicated to GM power!
Nice Work!!!
rgonza is offline   Reply With Quote
Old 01-03-2014, 06:28 AM   #49
stevenbear72
Thanks for the feedback guys. I may use Nelson Performance here in Sa to do my wiring harness as long as they arent more expensive then the glorious Speartech Harnesses. I am also most likely going with the RnD radiator and dual fan kit from them. Just saving up some though.
Old 01-03-2014, 09:24 AM   #50
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I used Nelson for my tune, most helpful and very fast.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
5.3 swap, c10, help me please, ls swap, swb fleet side
