Old 03-07-2014, 11:22 AM   #26
rgunlock
rgunlock's Avatar
Re: Matt's 56 3600 4X4 Build
Sounds like good progress on the drivetrain. I'll be following your progress because I'm planning a similar build for my '59 after I finish the 78 GMC I'm currently doing.
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 03-11-2014, 04:27 PM   #27
mvitale27
mvitale27's Avatar
Just some random 700r4 pics
1956 Chevy 3600
Matt's 3/4T 4X4 Build
mvitale27 is offline   Reply With Quote
Old 03-17-2014, 11:04 AM   #28
mvitale27
mvitale27's Avatar
Update... tranny rebuild is complete. I am taking it home on Thursday.
Got my engine block back from the machine shop... looks great! I ordered my stroker kit from summit this morning and picked up engine and tranny crossmembers and urethane mounts from performance online.
Fenders and floorboard panels are being delivered today!
Here is a pick of my block when it got dropped off yesterday... will post pics of fenders and other parts as they come in
1956 Chevy 3600
Old 03-24-2014, 10:01 AM   #29
mvitale27
mvitale27's Avatar
Fenders and floor patches came in last week. Still waiting on my stroker kit and engine/tranny mounts.
I managed to remove the bed on Saturday with the help of some friends. Here are the pics of the bed removed...
1956 Chevy 3600
Old 04-29-2014, 03:14 PM   #30
mvitale27
mvitale27's Avatar
Hey guys, got some work done on the truck. Welded in my engine crossmember. Also started building the 383. I have a line on K20 front and rear with 3:73 gears so I am chasing that this week. More pics to follow
1956 Chevy 3600
Old 05-08-2014, 10:39 PM   #31
mvitale27
mvitale27's Avatar
Got a real score on the 78 K20 axles. Got both of them for $300. A pic is below. I will replace the ball joints, u-joints, seals, covers, and brakes before final installation. Right now I am getting some advise from Orrie and some other guys on which lift blocks, u-bolts, and mounting plates to use.
1956 Chevy 3600
Old 05-10-2014, 04:55 PM   #32
Purcell69
Looks to be coming along nicely. Keep up the good work!
-Joe
Purcell69 is offline   Reply With Quote
Old 06-05-2014, 10:54 AM   #33
mvitale27
mvitale27's Avatar
So I have done some work in the past few weeks. I painted my engine block, set all my ring gaps, and assembled the pistons/rods the other night. I am planning on getting the rotating assembly in the block this weekend and also getting my new axles mocked up under the frame. Some pics are below. I also removed the doors from the cab because as soon as I mock up the axles I will remove the cab and send it off to be blasted.
1956 Chevy 3600
Old 06-12-2014, 10:18 AM   #34
mvitale27
mvitale27's Avatar
So I have the rotating assembly installed in my block. I need to double check it tonight for crank clearance at the bottom of the cylinders and oil pan rails. I was turning the crank by the balancer bolt so I am not sure if that is why there was a lot of resistance or if the crank is interfering somewhere.
1956 Chevy 3600
Old 06-19-2014, 10:10 AM   #35
mvitale27
mvitale27's Avatar
Got the rotating assembly in the block. Rotates freely, just needed to add some more oil between the journals.
I started removing the old front axle to get ready for the new front gm 10 bolt. I got the old one out of the way after a little persuasion with the cut off wheel. Went to put my old wheels on the new axle (both are same 8 bolt pattern) and the old lug nuts were too small. After calling all the parts stores in the area, nobody had more than 2 lug nuts available. Ordered a set of 32 from summit that should arrive today. Hope to get the new front installed, old rear axle removed and new (to me) rear gm 14 bolt installed today.
1956 Chevy 3600
Old 06-19-2014, 04:19 PM   #36
Purcell69
Looks like you are making good progress. I am guessing you will be losing the stock steering gear for a GM power steering conversion?
-Joe
Old 06-20-2014, 11:32 AM   #37
mvitale27
mvitale27's Avatar
-Joe
Yes, I am going to be getting rid of the stock steering box. I think I am going to use the CPP kit but I want to do some more research on other power steering options.
1956 Chevy 3600
Old 06-20-2014, 11:43 AM   #38
mvitale27
mvitale27's Avatar
Feel like I am finally making some good progress! Got the new to me front gm 10 bolt mounted under the frame yesterday. It was a big of a struggle to maneuver it because the passenger side hub was frozen. Anyways, got it installed and the front is a solid 4" higher than the rear. I will be mounting the rear gm 14 bolt tomorrow with the Rancho 4" lift blocks. More pics to come!
1956 Chevy 3600
Old 06-20-2014, 07:07 PM   #39
OrrieG
OrrieG's Avatar
That brings back memories...nice progress.
OrrieG is offline   Reply With Quote
Old 06-23-2014, 10:58 AM   #40
mvitale27
mvitale27's Avatar
Got the rear installed over the weekend. Only delay I ran into this time was a massive beehive in my frame rail! Here are some pics of the install...
1956 Chevy 3600
Old 06-26-2014, 09:08 AM   #41
mvitale27
mvitale27's Avatar
So I am getting ready to pull the cab off the frame and send it for sandblasting with the doors, grill, and bed panels. I took some close up shots of my rusted/rotted out area. Seems like the usual floor pans, cab supports, cab corners, hinge pockets, steps/rockers, cowl on the DS. But I also have some rot at the top of the windshield frame/roof. This could be tricky to fix.
I wanted to get it sandblasted before I start welding so its easier to see the rot and cleaner to work with. I am going to build a dolly tonight to sit the cab on before it goes to the shop.
What do you guys thing a good price would be for blasting the cab, doors, grill, and bed panels (no fenders)?
1956 Chevy 3600
Old 06-26-2014, 09:09 AM   #42
mvitale27
mvitale27's Avatar
... couple more pics
1956 Chevy 3600
Old 06-27-2014, 08:14 PM   #43
marc55
marc55's Avatar
I am getting ready to do my cab. I got a quote of $50 an hour. I want to do inside and out they said any where from 4-6 hours depending on how much paint is on the truck. I used some paint stripper and also used a 4" angle grinder with wire wheel and hit most of the flat spots myself. Hopefully I am down to about 3 hours.
marc55 is offline   Reply With Quote
Old 06-28-2014, 07:26 PM   #44
mvitale27
mvitale27's Avatar
Attachment 1271395
Thanks for the info. Do you have any other pics of that dolly you have your cab on? I started building one the other night. I have the bottom rectangle and wheels done but I need to figure out the top mounting surface.
1956 Chevy 3600
Old 07-10-2014, 11:18 AM   #45
mvitale27
mvitale27's Avatar
Dropped the truck off at the sandblasting shop this morning. For $500 they are going to blast the entire cab, both doors, inner fenders, door panels, grille, core support and a few other pieces. They also put a coating on after blasting to protect the bare metal from rusting. Should be done in about a week. Time to clean the garage and start working on the frame and suspension.
1956 Chevy 3600
Old 07-13-2014, 06:07 PM   #46
marc55
marc55's Avatar
I built that one with some scrap I had it was kind of flimsy started to break up after climbing in and out of the cab. I am now using some car dollies I had.
Our project are at the same stage right now. I want my cab sand blasted by the end of the month and I am starting on the frame work.
Old 07-14-2014, 02:39 PM   #47
mvitale27
mvitale27's Avatar
Thats funny, we are both doing 4X4 conversion. I cleaned out the garage this weekend so the truck would fit inside finally. I am beginning frame and suspension work this week and I should have the cab back at the end of this week.
1956 Chevy 3600
Old 07-22-2014, 12:06 PM   #48
mvitale27
mvitale27's Avatar
The sandblaster is taking longer than expected but I am in no rush to get the cab and body parts back. I have plenty of chassis and drivetrain work to do. I did spend a weekend cleaning out the garage so there is now room for the truck! Plus I can find all my tools! Hope to install my trans xmember and paint the frame this week. Then it is onto rebuilding my front and rear axles.
1956 Chevy 3600
Old 07-29-2014, 10:03 AM   #49
mvitale27
mvitale27's Avatar
Small update here: Got the truck in the garage and figured I would accomplish the last thing preventing me from painting the frame. So I bolted up the trans to my block and dropped it on the frame to fit the trans crossmember from POL. Looks like I need to cut off the old MC bracket so I should be able to get that done tonight and weld the crossmember. Then finally drop the axles and paint this frame!
1956 Chevy 3600
Old 07-31-2014, 01:25 PM   #50
mvitale27
mvitale27's Avatar
Not an update on the build but I picked up a new daily driver in Mystic, CT yesterday. 2001 Silverado 1500 Extended Cab. Guy was selling it for $3800 then the fuel pump crapped the bed after he ran it out of gas. He reduced the price and I scored it for $1900. I brought a scan tool and compression gauge with me when I checked it out. He used his AAA to tow it to me in RI, about 45 miles away. Once I got it home, I shoved some fuel past the throttle body and turned the key. Started right up and purred like a kitten for about 5 seconds. Here is a picture...
1956 Chevy 3600
