Old 02-05-2014, 12:49 PM   #26
Uncle Jimi
Uncle Jimi's Avatar
Re: S10 Chassis Swap. Locating the Cab Mounts
Perfect, Thank you!
Just editing the post.... Sincerely Bartman, I've watched it 3 times now... THANKS!
Uncle Jimi is offline   Reply With Quote
Old 02-06-2014, 12:44 AM   #27
av8tr33337
av8tr33337's Avatar
Originally Posted by Uncle Jimi View Post
Perfect, Thank you!
More than welcome
av8tr33337
AKA Bartman Email av8tr33337@yahoo.com
Bartman's Ad-S10 Chassis Swap
http://67-72chevytrucks.com/vboard/s...d.php?t=415418
My First Youtube Video
http://www.youtube.com/watch?v=B6hSt...eature=channel
More Pics of the 51 Project
http://s668.photobucket.com/albums/v...hassis%20Swap/
1951 3100 Pickup
av8tr33337 is offline   Reply With Quote
Old 09-13-2015, 09:37 AM   #28
chopit
chopit's Avatar
What thickness plate is in the drawing? Cant seem to find anything on that.
chopit is offline   Reply With Quote
Old 09-13-2015, 11:12 AM   #29
iowaboynca
iowaboynca's Avatar
i believe bartman referenced using 4" square tubing, 1/4" thick.
If you're looking at starting a S10 build, you should probably reference the info found here:
Skymangs S10 Swap how to
http://67-72chevytrucks.com/vboard/s...d.php?t=632686
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 09-13-2015, 11:23 AM   #30
chopit
chopit's Avatar
Thanks iowaboynca, yes he did, but I want to build the actual mounts in the picture which require bending and bartman just used them as a reference for different mounts utilizing square tubing. 1/4 can be a biotch to bend and thinking a bit overkill.
The reason I asked is because I have been reading all the threads including Skymangs and at some point I thought I remembered reading that the thickness for building the mounts in the actual drawing was 1/8 with 3/16 caps but I am not sure and I've read so many threads cant seem to find it again.
Old 09-13-2015, 12:20 PM   #31
chopit
chopit's Avatar
ok found it in one of Skymangs old threads.
http://67-72chevytrucks.com/vboard/s...d.php?t=613249
"Cab mounts were templated and built from 1/8 wall steel. The top plates are 3/16" steel. As always, I kick my cab stand legs out at a 15 degree angle to reduce the stress of a vertical weld on the frame."
Old 09-14-2015, 04:31 PM   #32
HUSSEY
HUSSEY's Avatar
Here's how I did mine (Post 50, 51 and 65). I liked the idea of cutting them from a piece of 4x4 11 GA tubing, no bending or extra welding.
http://67-72chevytrucks.com/vboard/s...=664837&page=2
I came up with mine from a mix of different users (jeffs51chevy, bartman, 99_to_life, skymangs...)
Downloadable PDFs which are a bit clearer are available at the following links:
https://drive.google.com/file/d/0B29...ew?usp=sharing
My 49 AD Build / S10 Chassis -- Thread -- Pictures -- S10 Conversion Mounts
HUSSEY is offline   Reply With Quote
Old 09-14-2015, 06:01 PM   #33
chopit
chopit's Avatar
Very nice Hussey! def. good idea not to have to sheer and bend for a guy like me with limited resources.
Only question I have is on your plans (awesome also) your heights WITH the body mount bushings (4" front and 3 1/2' + the 1x2 for a total of 4 1/2 back) are similar to the other drawings heights WITHOUT the bushings
Is that just because you are wanting your cab lower or am I missing something?
Are your heights such that altho you need a partial trans tunnel, your driveshaft clears under floor?
I have to find time to read your whole thread now! Looks like an exceptional build.
Old 09-14-2015, 07:31 PM   #34
chopit
chopit's Avatar
Ok I just went back and read more of your thread and got my answers. I think it was post #41
Old 09-14-2015, 07:35 PM   #35
HUSSEY
HUSSEY's Avatar
Yes, I wanted to get the cab a little lower. I referenced 99_to_life project details (post 101):
http://67-72chevytrucks.com/vboard/s...=382481&page=5
4 in. seemed to work out well. I'm also running 2 in. drop spindles up front. It's kind of a balancing act setting the height of the cab, the steering linkage, and motor height. It will require a tranny hump in the floor but wont require a drive shaft tunnel. Any lower I think you'll need to put in a tunnel for the drive shaft.
Old 09-20-2015, 08:29 PM   #36
winchster
winchster's Avatar
Can any of y'all that have done the S10 swap get me the distance from centerline of front axle to center of front cab mount?
'49 AD 5 window deluxe cab sitting on a '78 K5 chassis
Support our troops, stand behind 'em or get in front of 'em.
What country can preserve its liberties if its rulers are not warned from time to time that their people preserve the spirit of resistance?
winchster is offline   Reply With Quote
Old 09-21-2015, 03:34 PM   #37
HUSSEY
HUSSEY's Avatar
Are you using this measurement to locate your cab?
Most builders locate the cab off the oval hole in the chassis. From the front of the oval hole to the center-line of the front cab mount is 4 in. Or, from the front of the oval hole to the edge of the cab mount is 2 in. (assuming you're making the cab mount from 4x4 in. tubing.
Old 09-21-2015, 04:14 PM   #38
winchster
winchster's Avatar
Yes, note my signature line. I'm not using an S10 chassis.
