Old 11-19-2013, 07:02 PM   #26
theastronaut
theastronaut's Avatar
Re: Winter Beater Build- '66 BBW Custom Short/Fleet with Heat!
Originally Posted by NEWFISHER View Post
That's my Mantra with my whole build!
Truck's looking good! Check with your local offroad and 4x shops, get on pirate4x4.com and other forums for the rear jeep springs and you may find a free set.
I posted in a few "for sale" groups on facebook that are local, someone should have them close by. We do a good bit of glass work for a local shop that installs lift kits, they should have a set.
I picked up a pretty nice gas tank for $20 bucks today, and deluxe heater with inside air duct, controls, and cables for another $20. Not sure yet if I'll convert it to a deluxe heater or save that for Goldilocks.
Shot of the inside of the tank. I'll clean it with muriatic acid to get the rust out before installing it.
Also peeled back the newer seat covers to find that the original cover is still there. Hopefully the base is decent enough to live with, the vinyl cover that's on it is pretty nasty looking.
theastronaut is offline   Reply With Quote
Old 11-20-2013, 09:16 AM   #27
greg65
greg65's Avatar
Subscribed. nice original seat.
1965 c-10 swb
1997 c-1500 extended cab
2004 tahoe
1993 mustang gt
BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653
greg65 is offline   Reply With Quote
Old 11-20-2013, 10:16 AM   #28
C/10 King
C/10 King's Avatar
Super nice find!!!
C/10 Rene
1966 Short Fleet "The Hag"
1967 CST Short Fleet "Dark Poly"
1971 Short Fleet
1970 Jimmy Custom 2 WD "Golden Ticket"
1972 Blazer 2 WD "Retro Blaze"
C/10 King is offline   Reply With Quote
Old 11-20-2013, 12:03 PM   #29
60-66
60-66's Avatar
[QUOTE=theastronaut;6372829]I posted in a few "for sale" groups on facebook that are local, someone should have them close by. We do a good bit of glass work for a local shop that installs lift kits, they should have a set.
When you run the muriatic acid through the tanks are you coating the inside with anything after to prevent rust again ? I need to do a couple Suburban tanks.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 11-20-2013, 12:08 PM   #30
1963c-10
1963c-10's Avatar
I would have gotten rid of the slider too....don't care for them personally unless theres a camper on the back.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 11-20-2013, 07:43 PM   #31
theastronaut
After muriatic acid, I flush it with water and baking soda, them PPG DX 579 and DX520. Did a tank 9-10 years ago and it's still good.
Yeah, it just looks out of place on the truck.
Old 11-20-2013, 07:49 PM   #32
theastronaut
Picked up a pair of free jeep springs today and also a fuel sending unit. Going to pull the seat, tank, and old fuel lines tomorrow after work.
This is the look I'm going for, except I'll keep the original caps.
Originally Posted by boucher racing View Post
- cut 1 1/2 coil off front springs and removed bump stop bracket (free)
- installed TJ Jeep springs in rear with 2" drop blocks ($100)
Old 11-20-2013, 09:32 PM   #33
duallyjams
duallyjams's Avatar
Then drive the wheels off of it.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 11-21-2013, 09:35 AM   #34
Low Elco
I love the Cropwell truck.
Low Elco is offline   Reply With Quote
Old 11-21-2013, 08:39 PM   #35
theastronaut
Pulled the seat and tank tonight, then cleaned all the trash out... in the rain.
The interior is nasty, definitely my least favorite part of the truck. The floormat is in decent shape though, so I'll pilfer it and use it in Goldilocks until reproductions are made or I find a NOS mat.
Old 11-21-2013, 08:42 PM   #36
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Well at least your rust issues don't seem to bad...my has holes all along the rocker panel.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 11-21-2013, 08:42 PM   #37
duallyjams
duallyjams's Avatar
What no worth while memorabilia
James
IG duallyjams
Old 11-21-2013, 08:52 PM   #38
theastronaut
I just haven't shown that yet... it has it's share.
Nothing noteworthy. There was a slim stainless ruler that we'll keep, that's it.
Old 11-21-2013, 10:41 PM   #39
BMERDOC
BMERDOC's Avatar
Have you ordered all your Porterbuilt stuff yet? As I understand it that stuff takes a while to come in.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 11-21-2013, 10:44 PM   #40
Jmorales3181
Jmorales3181's Avatar
nice find!
My frame Layin 63 short bed project
http://67-72chevytrucks.com/vboard/s...d.php?t=551353
Jmorales3181 is offline   Reply With Quote
Old 11-21-2013, 10:56 PM   #41
theastronaut
I'm not sure what you're taking about? The wait time on the Porterbuilt TJ mild rear drop kit was pretty short, had them only two days after I placed my order on Craigslist. I already had his "Choose Your Drop" front coil kit in the barn loft, lost the instructions that said "Cut X amount of coils for X amount of drop" though. Would appreciate if anybody could pm those ASAP!
Old 11-21-2013, 11:35 PM   #42
duallyjams
duallyjams's Avatar
PDf on it's way
James
IG duallyjams
Old 11-21-2013, 11:36 PM   #43
BMERDOC
BMERDOC's Avatar
I had the "Choose your drop" instructions on a PDF on my last computer but a bad beer accident nixed that. Sorry!
So you went with the TJ coils? I have heard so much either way about using them for a rear drop. Some have said they did a good drop, others said they didn't do anything. Almost everyone speaks of the loss of payload ability. I think its truck dependent. Meaning, how much the truck was used and what kind of sag it has. You truck looks to be in great shape and sits pretty high so it will be a good candidate to settle the TJ coil mystery once and for all. Take measurements!
Nick Carter
Old 11-21-2013, 11:38 PM   #44
BMERDOC
BMERDOC's Avatar
^^^Duallyjams beat me to the PDF punchline! LOLOL!
Nick Carter
Old 11-22-2013, 12:28 AM   #45
C@rnut001
Your truck looks like it is in pretty good shape overall. Get the few things done to it and then drive the wheels off of it...I hope to find one like it someday, good luck with your new find!
C@rnut001 is offline   Reply With Quote
Old 11-22-2013, 11:50 PM   #46
Jeff La
Man truck looks really good, can't wait to see the rest
Jeff La is offline   Reply With Quote
Old 11-29-2013, 07:46 PM   #47
theastronaut
Worked on the fuel lines today and cleaned the tank.
We bought Eastwood's tubing flare set awhile back as haven't used it yet so I tried it out on the pump-to-carb line. Works great!
After bending, flaring, and installing line from the FLAPS.
New pump, flex lines, and filter.
Drying out the tank.
Found out why the shifter doesn't work...
Old 11-29-2013, 08:52 PM   #48
duallyjams
duallyjams's Avatar
1) your not stuffed from Thanksgiving
2) it's always fun to get to use new tools
3) still has the ground strap from the valve cover to the firewall
James
IG duallyjams
Old 11-30-2013, 09:58 AM   #49
mano
mano's Avatar
Very nice truck
mano is offline   Reply With Quote
Old 12-06-2013, 04:51 PM   #50
theastronaut
I had my share, just didn't overdo it! Got to use the flare tool again today- well worth the money spent. It's the easiest way I've ever seen to flare lines. The truck does seem to be pretty unmolested, lots of original details all through the truck.
Originally Posted by mano View Post
Very nice truck
Thanks!!
The filler neck and grommet came in today so I painted the tank and got it ready to install. Should have it in and running tonight.
