Old 12-10-2013, 08:43 PM   #26
CanadianK10
Active Member
CanadianK10's Avatar
Re: 1968 K1500 V6 Farmer Green
Looks Great!
Subscribed
1967 K10 292, SM65 Transmission & NP205 Transfer Case
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=605048
CanadianK10 is offline   Reply With Quote
Old 12-12-2013, 08:26 AM   #27
walkerb
walkerb's Avatar
AHHHHHHH, progress
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 12-13-2013, 06:17 PM   #28
glimmertwin01
glimmertwin01's Avatar
The Cab is on, and sealed up.... no its not perfect but it is on the truck and the windows are closed and the rear window was installed.... it was 18 balmy degrees with lake squalls but its on... the right cab corner looks like its a tad low... I wont know till i replace the rocker.... crossing my frozen fingers....
67/68 K/20 "The BEAST"
68 K15 V6 LWB.
73 K20 GMC Burb "The Bomber"
74 K/5
74 K20 Custom Deluxe
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Life is what you make it Live each day like it was your last
Old GM Trucks never go out of style
glimmertwin01 is offline   Reply With Quote
Old 12-13-2013, 06:26 PM   #29
67chevy1series
67chevy1series's Avatar
Cool progress! Lol looks sealed enough!
67chevy1series is offline   Reply With Quote
Old 12-13-2013, 06:30 PM   #30
glimmertwin01
considering we measure snow in FEET in the lake effect bands im happy... the cab had 7 inches of snow in it already... blew it out with compressed air. once i install the heater and plug the harness into the plug on the firewall she should run... and i can work on the inside with heat... LOL by monday the thing should be half buried.
68 K15 V6 LWB.
74 K/5
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Old 12-13-2013, 06:36 PM   #31
67chevy1series
Yeah over here I use shop lights.. Those things get so damn hot there like a heater and lights in one... I've caught my clothes smokin a couple times lol
Old 12-13-2013, 11:28 PM   #32
Big bad Green
Big bad Green's Avatar
That cab is nothing my 68 is way worst I'm rebuilding it tho I see the 71 cab has no vin plate are you swaping vins
1968 Chevy K20 Long bed dump truck
1978 Chevy Custom deluxe long bed
1986 Chevy Custom deluxe short bed
1987 Chevy Custom deluxe short bed
1987 Chevy Silverado short bed
1990 Chevy Silverado K5 Blazer
All four wheel drive! All non mutt trucks!
Big bad Green is offline   Reply With Quote
Old 12-14-2013, 12:18 PM   #33
glimmertwin01
yes...shhhhhh. i usually remove the tags before i paint them it makes a cleaner job.
68 K15 V6 LWB.
74 K/5
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Old 12-14-2013, 12:23 PM   #34
glimmertwin01
the roof of the green cab was shot.... literally broken (well rotted thru) above both doors... the lift off was the final kiss of death... only thing i want to salvage is the dash center, and over the last year someone scarfed the radio delete plate...
the blue cab has the custom radio install hack job.. i dont think im gonna put tunes in it as it really doesnt matter... and commercial radio sucks...
68 K15 V6 LWB.
74 K/5
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Old 12-14-2013, 09:00 PM   #35
Big bad Green
Huh interesting so what is it gonna have the 71 vin on it
Old 12-14-2013, 09:36 PM   #36
glimmertwin01
no see the first post.... just changed cabs
68 K15 V6 LWB.
74 K/5
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Old 12-14-2013, 09:57 PM   #37
gdavis
gdavis's Avatar
pictures like these make me glad for the weather we have here in Florida. keep going and happy building there my friend.
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 02-06-2014, 11:15 PM   #38
glimmertwin01
well I spent 2 afternnoons this week on the truck sunny but a crisp 21 degrees, hard to work all day when your fingers dont work well
I got the heater system installed... took the core home and cleaned it and had to re solder the outlet. replaced the control and cleaned and lubed the fan switch... its all in and wired. cleaned the instrument panel including bulbs and contacts,,, all circuits rest out a OK.
Removed the right exhaust pipe from the manifold and had my mechanic bend me a brand new one.... since the old one was rotted. yet to install
installed the clutch rod, petal and suck only to discover im missing the wedge nut that goes into the fork...
Installed the column after replacing a worn out rag joint... discovered the steering box has about a 1/4 turn of slop... the steering output shaft moves up and down as well as in and out... time to find another box... or rebuild or get a rebuilt unit
since its a 71 cab im retaining the parking brake from it... my cable works just need a couple things to attach it to the petal assembly...
I snagged some rustoleum hunter green to paint some areas in the cab i repaired prior to putting my replacement tank in...
the green is a little greener than the OE code 505 paint... wish it was a perfect match... you can see it on the drivers kick panel and drivers cab corner.
day after our "snow storm" leaving a nice 14 inches of white fluff...
68 K15 V6 LWB.
74 K/5
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Old 02-07-2014, 12:12 AM   #39
WIDESIDE72
WIDESIDE72's Avatar
It was 27f here in sunny central Texas today. No snow but ice possible tomorrow.
WIDESIDE72 is offline   Reply With Quote
Old 02-07-2014, 01:16 AM   #40
glimmertwin01
too cold for TX..
68 K15 V6 LWB.
74 K/5
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Old 02-26-2014, 12:10 PM   #41
glimmertwin01
OK update time... I am Parting a solid 69 2wd C1500 It is supplying a nice set of OE fenders, tail gate, and maybe a cab... I know i already swapped a cab but.... call me crazy but this one is solid other than the floor supports need replacing...
I have no issue with cutting the floor to accommodate the the high hump... I know its crazy but.... Im snagging a complete solid cab with doors and interior for 500 or less. and the cab / doors will match the fenders... too bad it doesnt have a 67-68 hood. one bed side is fix able the pass side isnt. but would be good for a beater I guess...
Heres the latest discovery... the manual steering box is sloppy. (1/4 turn) play. the sector shaft moves up and down and in and out in the case.
Simple fix. Locate a nice used one... ( anybody have one? contact me)
PITA fix Locate a PS pump and bracket assembly and swap the manual box for a PS unit.
any thoughts suggestions? let me know....
68 K15 V6 LWB.
74 K/5
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Old 04-19-2014, 08:27 PM   #42
glimmertwin01
got the front assembled and wired... all the linkage etc all set found a better grille in the yard since the white one was deformed from prior use. fisher plow is off...
ready to remove the box... I will assess if it is worth putting bed sides on it or replacing it... I have a long step but since the VIN indicates its a fleet.... i might not use it..
I could use some help locating a steering gear rebuild kit or a good replacement.
here are some pics with the new fenders...
68 K15 V6 LWB.
74 K/5
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Old 04-23-2014, 12:55 PM   #43
glimmertwin01
I got her started! after checking wires on the points connections...she came to life....
I am working on a new throttle cable assembly for it since its a 71 cab/ petal. i need to shorten a stock cable, since i looped one to the throttle bracket and it binds due to the tight radius... the instrument panel lights up nice after cleaning it and the "generator" light is on... i am contemplating a 10si upgrade to eliminate the regulator...
68 K15 V6 LWB.
74 K/5
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Old 04-24-2014, 10:27 PM   #44
glimmertwin01
changed out the front harness, extended converted the alt.lead to accept a 10si Internally regulated 75 amp delcotron..cleaned some contacts...and NASA we have ignition and LIGHTS!!!!
68 K15 V6 LWB.
74 K/5
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Old 04-24-2014, 10:50 PM   #45
67chevy1series
Looking good such a cool truck
Old 04-24-2014, 11:21 PM   #46
glimmertwin01
hard work.... hard to find parts for....and not rusty..... about 1/2 way done it is a cool ol girl
68 K15 V6 LWB.
74 K/5
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Old 04-28-2014, 10:32 PM   #47
glimmertwin01
she is grumpy and full of groans, creaks and odd noises, but i took her out in the yard for her maiden voyage after yrs of sitting and neglect. Popped a straight lt green hood on her. finished fabricating a custom throttle cable... and hooked up the t case lever. next up... greasing the girl. remove the bed to replace bed sides... bend and install new brake lines... rebuild each drum brake and install the master.
More pics...
68 K15 V6 LWB.
74 K/5
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Old 04-29-2014, 07:07 AM   #48
walkerb
walkerb's Avatar
Looks solid! Cant beat almost matching bias!
Old 04-29-2014, 12:07 PM   #49
glimmertwin01
the 4th Hercules 7.50x16 is in the bed loose needs to be mounted.
68 K15 V6 LWB.
74 K/5
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
