Old 01-05-2014, 09:04 PM   #26
Sodell
Sodell's Avatar
Re: 87 SWB ..Pearl..
And got another coat of primer on the fender.
[IMG][/IMG]
[IMG][/IMG]
Scott
87 Chevy 2WD SWB, 88 4x4 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=610652
Sodell is offline   Reply With Quote
Old 01-06-2014, 09:30 AM   #27
Low Elco
It's cleaning up good!
Low Elco is offline   Reply With Quote
Old 01-06-2014, 08:31 PM   #28
Sodell
Sodell's Avatar
Thanks!
Scott
Old 01-12-2014, 07:42 PM   #29
Sodell
Sodell's Avatar
Cleaned, sanded and painted the vents. I used the felt side of some small Velcro stickies to keep the vents from sagging.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Scott
Old 01-12-2014, 07:47 PM   #30
Sodell
Sodell's Avatar
New door hinges installed, and door adjusted.
[IMG][/IMG]
I have seen several posts where someone could not replace the top hinge and would only replace half of it. The only thing you have to do is remove the drivers side air vent and the bolt is just through the hole in the fire wall. Mine has a plug I removed and the bolt was pretty easy to get too.
[IMG][/IMG]
Scott
Old 01-13-2014, 10:44 PM   #31
Hankster
Hankster's Avatar
Good looking truck! I like the rallys!
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 02-01-2014, 08:39 PM   #32
Sodell
Sodell's Avatar
[Got some clear on the fenders today, paint is chugging along.
IMG][/IMG]
Scott
Old 02-16-2014, 11:00 PM   #33
Sodell
Sodell's Avatar
Thanks!
Scott
Old 02-16-2014, 11:02 PM   #34
Sodell
Sodell's Avatar
After a few months, finally got the cab and doors straight. Primer on, color soon to come.[IMG][/IMG]
Scott
Old 02-17-2014, 02:10 AM   #35
y5mgisi
Second Chance Program
y5mgisi's Avatar
Subscribed
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 02-17-2014, 09:15 AM   #36
naphtali5725
naphtali5725's Avatar
looking good
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 02-17-2014, 10:30 PM   #37
Sodell
Sodell's Avatar
Originally Posted by naphtali5725 View Post
looking good
Scott
Old 02-17-2014, 10:31 PM   #38
Sodell
Sodell's Avatar
Originally Posted by y5mgisi View Post
Subscribed
Thanks!
Scott
Old 02-17-2014, 10:37 PM   #39
Sodell
Sodell's Avatar
Another coat of primer and 10 more hours of sanding and the cab is white. Next comes the clear and more hours of wet sanding..
[IMG][/IMG]
[IMG][/IMG]
Scott
Old 02-18-2014, 09:25 AM   #40
Greenlee
Greenlee's Avatar
Looking good. Nice work!
I found a good way to keep the A/C vents from falling down. I put an o-ring on each side and they are nice and smooth and stay put now.
Greenlee is offline   Reply With Quote
Old 02-18-2014, 11:25 PM   #41
Sodell
Sodell's Avatar
The o ring is a good idea. I had not thought about that.
Scott
Old 02-18-2014, 11:33 PM   #42
Sodell
Sodell's Avatar
Got the clear on today, I can start putting the cab together.
[IMG][/IMG]
Moth in the clear, lol
[IMG][/IMG]
Scott
Old 02-19-2014, 02:32 PM   #43
Malo83
Cruzzzn' Vet
Malo83's Avatar
Great work, found this off another post
Malo83 is offline   Reply With Quote
Old 02-19-2014, 04:33 PM   #44
Sodell
Sodell's Avatar
Thanks, I always forget how tedious body work is until I get back into it.
Scott
Old 02-21-2014, 07:43 PM   #45
Sodell
Sodell's Avatar
In muffler jail until Monday
[IMG][/IMG]
Scott
Old 02-22-2014, 10:19 PM   #46
Sodell
Sodell's Avatar
Exhaust is done..
[IMG][/IMG]
Scott
Old 02-23-2014, 02:54 AM   #47
rs74
rs74's Avatar
Originally Posted by Sodell View Post
Exhaust is done..
[IMG][/IMG]
I use to have turn downs like that on a cutlass years ago. I end up putting them pointing on a 45 degree angle because they sturred up alot of dust and also the resonated really back turned towards the ground.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 02-23-2014, 12:23 PM   #48
Sodell
Sodell's Avatar
These 40's are not too loud., I have seen a lot of square guys dump then like this. I planned to have them dump out just before the wheels and have the pipes cut diagonal with the body. I will most likely take it back and have that done later after I get the bed on.
Scott
Old 02-25-2014, 11:27 AM   #49
Claytona08
Claytona08's Avatar
Hey Scott, Nice build up to this point!
http://67-72chevytrucks.com/vboard/s...d.php?t=580955
http://youtu.be/JYoQJYTXKqI
1984 Chevrolet Scottsdale C10 "Project Platinum C10"
1971 Chevrolet Chevelle "Project Car"
Claytona08 is offline   Reply With Quote
Old 02-25-2014, 08:30 PM   #50
Sodell
Sodell's Avatar
Thank you Clayton, I am trying to do most of the work myself. Man, this cold weather is certainly keeping things slow going. I have yet to wet sand and buff the cab, waiting for a nice weekend. Still have to do the bodywork on the hood, the painted piece below the grill, the bed, and the tailgate. I found a decent tailgate and bed so I hope there wont be two months of work, maybe a month.. lol.
Scott
