Old 01-26-2014, 02:36 PM   #26
72longbed
72longbed's Avatar
Question Re: The Definitive 67-72 Seat Swap Guide Thread ....
FLT,
I also noticed that you were able to somehow install your 91 seat further back in the cab than most all others?? Even with the gas tank still in there?
Did it require that you change the angle of the seatback to a more 'upright' angle?
72
72longbed is offline   Reply With Quote
Old 01-26-2014, 03:03 PM   #27
Flthead
I put this seat in like 10 yrs ago . Had the truck since '89. Looks like I cut an angled the back of stock '91 bracket. Here's a pic from front of underside of seat looking towards back drivers side. They say memory is the first to go ... It started lol.
Flthead is offline   Reply With Quote
Old 01-26-2014, 03:04 PM   #28
Flthead
Here's an outside view of driver side rear mount
Old 01-26-2014, 03:12 PM   #29
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Flthead, you can put 5 pics per post. Find the first, upload it and then, rather than closing the popup window, find another pic, upload that, etc. Any questions, PM me.
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
ETsC10 is offline   Reply With Quote
Old 01-26-2014, 03:17 PM   #30
Flthead
Sent you a pm on the pic subject. Thanks
Old 01-26-2014, 03:21 PM   #31
72longbed
72longbed's Avatar
I'm just gonna take a guess here ... because I don't have any experience with the 88-9? seats ... but it looks like you also installed the seat in it's 'forward most' position on the sliders?? The seat frame looks to be way back in relation to the seat. Is that correct?
Are you able to slide the seat forward when sitting in the truck? I'll bet not, right?
72
Old 01-26-2014, 03:32 PM   #32
Flthead
I'm the only driver an I'm 6'2. So I put seat as far back as I could go. Seat doesn't slide. When I'm worm food my niece can worry bout that one : )
Old 01-26-2014, 03:38 PM   #33
72longbed
72longbed's Avatar
Thumbs up Re: The Definitive 67-72 Seat Swap Guide Thread ....
Didn't mean anything negative by my observation ... just trying to figure things out from pictures. Been noticing where that front factory hole lines up with others that installed same seat.
I do what is best for me in my trucks too. Why not ... I'm the one who has to drive it!!
Thanks for all the pictures and info FLT ... good stuff!!
72
Old 01-26-2014, 03:42 PM   #34
Flthead
Ya no negativity taken
Old 01-26-2014, 03:48 PM   #35
72longbed
72longbed's Avatar
Lets keep this thing goin folks! I don't know about you'all ... but I'm learning a lot with this Thread!!
Thanks to all contributors so far ... and hope we can hear from more members and guests on what they did, and how they did it.
72longbed
Old 01-26-2014, 05:09 PM   #36
markiemark
Here's mine. was in my truck when I got it. Have no clue what they are out of but it's actually 2 separate seats and the passenger is larger and can fit a 3rd person...and pretty comfy too. But I'm thinking about a recover or getting another set up.
markiemark is offline   Reply With Quote
Old 01-26-2014, 05:15 PM   #37
72longbed
72longbed's Avatar
Wink Re: The Definitive 67-72 Seat Swap Guide Thread ....
From the floor bracket/frame I'm gonna guess GM, 88- ?.
Chime in here you guys that know your GM seats ... am I close?
72
P.S. Good lookin truck, Markiemark, Looks nice in there too.
Old 01-26-2014, 07:03 PM   #38
Originally Posted by 72longbed View Post
Question for Palf70Step:
What did you have to do to the factory Suburban seat frame to bolt it down to our years Cab floor? Did you have to fab any special bracketry?
Will those seats slide back further if the gas tank has been removed from the cab?
Thanks Bill, we'd like to hear from you please.
72longbed
The burb seats were not in any of my trucks, but friends. Putter should still have a thread somewhere in the FAQ area about the install. I am 6' 1" and I fit OK (long as it is not a stock wheel. Very comfortable, way better than stiock. You are a little higher than stock and the regular88-94 bench install that I did. Putter also shorten, well push in his steering column some to get more belly room.
Here is Putter's notes for the install he used on his truck and GMAN69's truck
I ended up slotting three of the existing holes in the seat brackets for the driver's side (outer-front, outer-rear and inner-rear) so I could fine tune the alignment (twist it a little), and I drilled a new hole for the inner-front bolt. Then on the passenger side, I used the rear two holes just as they were (spaced up about 3/4"-1" off the floor). The passenger front-outer has a long slot under the slide track (Yes a second row seat slides...for entry into the rear). And for the passenger inside-front, I drilled a new hole. I also cut off both passenger seat front mounting tabs as they were not needed.
Old 01-26-2014, 07:57 PM   #39
72longbed
72longbed's Avatar
Thanks for the info Bill ... very helpful.
I'll see if I can access the Threads where Putter posted his install, and try to upload it onto here. Not sure how to do that, but this would be a good place for a 'link' to those Posts.
Maybe somebody with some site savvy can offer guidance on how to attach a link to his Posts?
Thanks again Bill. I'm interested in Burb seating and also Tahoe because I think they stretch across the interior of our cabs a little further than the 88-94 style? Did anybody else notice that?
72
Old 01-26-2014, 08:14 PM   #40
I had not noticed that with the 67-72 body styles, but have noticed it with the 73-87 trucks.
The burb and truck seats are the same width far as I know. the cabs of both are the same.
Old 01-26-2014, 09:24 PM   #41
markiemark
72
Thanks!!!
Old 01-26-2014, 09:36 PM   #42
70blackfish
more pictures...
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 01-26-2014, 09:42 PM   #43
flashed
My 2 72 trucks have BuddyBuckets in them ,sorry but I cant do pics .
flashed is offline   Reply With Quote
Old 01-27-2014, 01:15 AM   #44
muckyp
muckyp's Avatar
I just recently "finished" my seat install. Drilled eight holes. The inner passenger side holes were the most difficult to locate and get right for me. I placed the seat on the lower portion of the cab floor. After driving a bit, I now think that I need to cut and lower the mounting brackets to bring the seat down a bit. I'm about 5'10" and I feel like I am looking out the top of the windshield.
70 SWB 454/TH400
muckyp is offline   Reply With Quote
Old 01-27-2014, 01:19 AM   #45
Andy4639
Old member
Andy4639's Avatar
Talking Re: The Definitive 67-72 Seat Swap Guide Thread ....
Stock 1989 Chevy truck seat 60/40. Installed with plates under the cab floor along with seat belts out of same model truck. I like the feel of it and I like the height of it. drove the truck 13 hrs out to Arlington Tx this past year and not one time was I stiff when I got out. The seat fits the trucks pretty good.
Seats have held up well over the years. No rips are tears so far going on 20 + years. Pictures are last few months.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-28-2014, 10:53 PM   #46
72longbed
72longbed's Avatar
Andy,
Nice ... Really Nice!!
72
Old 01-28-2014, 10:56 PM   #47
72longbed
72longbed's Avatar
Anybody else want to share what they put in their 67-72's over the years?
Curious minds want to know ......
Old 01-28-2014, 11:45 PM   #48
Andy4639
Old member
Andy4639's Avatar
Andy,
72
Thanks. I really like the way it sit's and have thought about sawapping them but haven't found anything I like yet. These were free to at the time.
Old 01-28-2014, 11:52 PM   #49
K10 STEPSIDE
K10 STEPSIDE's Avatar
2009 Gmc seirra
The only modification I made was shortening the center frame to move the middle seat forward, as shown in the last image. Then it was just drilling holes.
I like the look of those 2013 ltz leather seats, might be time to upgrade to leather soon.
_______________________________________________
A project can be finished, but a car is never done.
1967 chevy K10 step
2002 chevy Impala
Latest Project http://67-72chevytrucks.com/vboard/s...d.php?t=605308
K10 STEPSIDE is offline   Reply With Quote
Old 01-28-2014, 11:53 PM   #50
BigCountryx
BigCountryx's Avatar
This is mine. Needed something to replace the ripped to shreads stock unit so I picked up this cheap out of an 87. I welded flat bar to each corner and drilled holes in order to use the factory bolting points. It sits a little low but at 6'5" it's manageable. Besides it makes it easier to pimp lol. I can slide under the wheel much easier now.
1972 Pale Yella 2WD Blazer ..... 350HO/700R4.... '68 Clipped
1970 Original Paint SWB Farm Truck ..... 5.3/4L80.... 2x HRPT Participant
BigCountryx is offline   Reply With Quote
