Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 02-06-2015, 02:37 AM   #26
Thunderwagen
Re: 1990 GMC RCSB Turbo LS Swap
I got the front rotors swapped out to the new ones and bolted up the front wheels.
I have a set of under bed notches coming from chassis by john. As soon as those get here I will get the rear knocked out.
1990 GMC Sierra
http://67-72chevytrucks.com/vboard/s...d.php?t=617587
Thunderwagen is offline   Reply With Quote
Old 02-09-2015, 03:21 PM   #27
HondaMartin
Nice Build! Good luck with it!
1993 OBS Chevy SCSB , 88k miles, 4.3 Auto (waiting on a 383 Stroker) "AR-15, Its like Barbie for men!" - Mark Reed
HondaMartin is offline   Reply With Quote
Old 02-18-2015, 10:21 PM   #28
tinsoldier
tinsoldier's Avatar
Please post pic of the manifold, I am interested in one.
tinsoldier is offline   Reply With Quote
Old 02-18-2015, 10:43 PM   #29
Thunderwagen
It's in the 5th pictire down on post 2 or you can go to trick performance website
1990 GMC Sierra
Old 06-11-2015, 12:10 AM   #30
Thunderwagen
Well I got a little bit done on the rear. Still need to finish it up. I got most of the frame stripped, just need to do the inside of the rails. Got poly bushings installed on the leafs and shackles, installed the 9.5 14 bolt, ditched the drums and got the Impalla SS rotors machined to fit the axles. Installed the flip kit and caltracs and clearanced the frame for the notches.
Now I need to burn in the notches, pick up some steel to build a new rear cross member so I can ditch the spare tire one. Weld on the caliper brackets and mod the lines for the new rear disc setup. Finish cleaning up the frame and rear then paint. Then install the shocks and Hotchkis sway bars. Hopefully I can get all that banged out sometime soon.
1990 GMC Sierra
Old 10-21-2015, 02:29 PM   #31
Chris95GT
Bump.
Any more progress?
1991 C1500 ECSB - 5.3 LS 4L80E 14bsf - Gone but not forgotten
1999 C2500 GMT-400 Crew Cab Short Bed - 6.0 LQ4 - 4L85E
2003 Denali XL - Wifeys Ride
2008 K2500HD Duramax Sierra Crew Cab Short Bed - Daily
Chris95GT is offline   Reply With Quote
Old 10-30-2015, 05:50 AM   #32
Thunderwagen
I really haven't gotten anything else done on it. I have been buying parts but my chick started a side business building and selling custom pet feeders and I got sucked into building them. She thought she would only be selling one or two a week and it has turned into anywhere from 10 to 20 a week. Between working 70 hours a week and building the feeders I just haven't had time to mess with it.
She is supposed to be shutting down the orders for the holidays so I'm hoping to get the motor and trans in it for the last time so I can finish up the hot and cold side of the turbo. Then I just need to do the fuel system, wiring harness and some odds and ends. Hopefully I will have some progress going soon
1990 GMC Sierra
Old 10-20-2017, 03:38 PM   #33
bigboyitm
Just found this thread and noticed it's been a few years since you posted. Any updates on it? What is done looks good. I'm working on fixing my 91 GMC RCSS
bigboyitm is offline   Reply With Quote
Old 04-10-2018, 11:09 AM   #34
Big Daddy Bear
Big Daddy Bear's Avatar
Giving this thread a little wake-up kick, would like to see how this project wrapped up if possible.
No bolt or nut in the world will remain tight if you turn it to liquid!!!
Big Daddy Bear is offline   Reply With Quote
