#26 |
Re: 1965 C10 Long Bed
Nice!
1965 Short Fleet http://67-72chevytrucks.com/vboard/s...d.php?t=637478 1983 Short Fleet (Under construction for my 13 year old son) 2008 GMC Denali 2012 Harley Roadglide Follow me on Instagram: Ru_django ![]() |
#27 |
Man it got stupid cold last night. I was going to presses wash the 65 and see past that dirt. However, I decided it was way too cold to get wet. Guess I will wait till this weekend. Hopefully the weather is better.
1965 C10 Project |
#28 |
Well decided to mess with the C10 today.
Grinder the welds on this plate in the bed. And removed it. And there is an original bed under there ![]() ![]() ![]() ![]() Cleaned the engine bay a little. And there is an engine in there. ![]() ![]() Also picked up a complete 1986 K member. To do my front disc conversion when I get to that point. ![]()
1965 C10 Project |
#29 |
![]() Join Date: Aug 2013
out with the old bed and in with new umm old bed hehe, u gonna keep the patina? also when u get to the front in you gonna sell the bits to the forum members
#30 | |
Rear bumper and springs in the 86 k member are spoken for already by a couple guys who helped me out with info and parts hookup.
1965 C10 Project |
#31 |
Well so far I was entertaining possibly putting the c10 body on my bagged s10 frame.
I have seen it done with one. It looks ok, However to make it look right you would need to get custom ordered rims with 1" backspace to make it fill out the fenders to look right. I laid the front clip over my old project s10 frame to get a good look at it. I don't like it. And don't feel like forking out close to $3000 on custom rims to make it look right. So took a pressure washer and cleaned off the front of the c10 frame to get it ready for my 5 lug,disc and bag swap. Also snapped a couple shots of the front cab corners. It looks real good shape. Some wise guy hooked a chain the the radiator support some time in the past. Ripped it loose on one side. So I will have to fix that. S10 frame laying. ![]() C10 front clip on the s10 frame, looks ok at this angle. However if you seen it in person. You wouldn't like it. ![]() ![]() Here you can see it needs about 5" offset to look right. Pretty much removing all the back space. ![]() C10 frame pressure washed ![]() ![]() Front cab corners ![]() ![]()
1965 C10 Project |
#32 |
Sheet metal all looks real solid. Welcome and nice project!!!
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#33 |
Sell the S-10 to the 47-54 AD guys. There are a TON of S-10 frame swaps on that end of the forum
GOD BLESS AMERICA! |
#34 |
Soooo that's what the front cab corners originally look like?! Haha, not here where I'm at. Your truck looks solid!
#35 |
Post Whore
![]() Join Date: Mar 2013
WOW!!!! I see an engine! LOL!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#36 | ||
Thank you Quote:
Yes I think this engine has been rebuilt. I found a tag on it by the tranny.
1965 C10 Project |
#37 |
Ok, can anyone find out what the gear ratio is of this rearend?
I just got it saturday from a guy. Told me it was a 342. Just wanting to double check. ![]() ![]() ![]() ![]()
1965 C10 Project |
#38 |
do know how many teeth are on the pinion part?
#39 |
Have not counted it yet. just was wondering if it can be found out by those numbers.
1965 C10 Project |
#40 |
take the 12 which is the pinion teeth and the 41 which is the ring teeth and divide and come up with 3.42's
1964 BBC 402 4x4 ![]() ![]() ![]() ![]() |
#41 |
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Wow!
Very solid cab! It looks a lot like mine when I started. Not very many to be found out there like that! Nice truck!!!
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=512904 |
#42 | |
1965 C10 Project |
#43 |
Well I picked up my steeliness today! Ordered upper bag plates and step notch.
And hit scrap metal yard to end up with enough iron to make a fab table. ![]() ![]() ![]()
1965 C10 Project Last edited by Lowl!f3; 04-04-2014 at 08:41 PM. |
#44 |
Yep
#45 |
1965 C10 Project |
#46 |
Got the other 3 legs on today.
Need to cut angle braces for the legs. Then flip it over so I can put some pads under the legs. ![]()
1965 C10 Project |
#47 |
I love it!!!
#48 |
Moved the 65 to the driveway to clean out all the old wood and pressure wash the frame under it. Had a friend of the family helping me out a little.
Next up will be trying to get some of the parts ready to be put on. Anyone know where to get the rubber for the radiator support on the bottom? I'm missing 1. Someone hooked a chain to it at some point ripping the lower support loose. Going to have to remove it and repair it. And need a rubber support. ![]() ![]() ![]()
1965 C10 Project |
#49 |
Post Whore
Progress!
#50 |
The object is to Get er done and your doing it
