Old 03-14-2014, 10:31 PM   #26
Crew Laid
Re: 1980 C20 Crew Cab Build Up
Originally Posted by Guilty By Design View Post
Steve does awesome work
Yeah Steve definitely does awesome renderings. He actually showed me some of the steps it takes to do a rendering.......I'll let him do the renderings, its a lot of work.
Crew Laid is offline   Reply With Quote
Old 03-14-2014, 10:37 PM   #27
Crew Laid
Well I made a road trip today to pick up some panels that I had ordered.
SUV hatch full of parts. There are floor pans is this pic but unfortunately they're going to go back since they are wrong.
New cab corners.
2 of 4 reg cab rockers that we are going to alter to fit my crew cab. Yes, I know it would be easier to just get crew cab rockers but, the quality was not up to my friend Tylers standards so we got 4 reg cab rockers for the price of 2 crew cab rockers.
Old 03-19-2014, 12:06 AM   #28
hick
I assume you came into Edmonton for those eh? AMP Panel on yellowhead?
If you ever need a part picked up and run out Id be happy to do it for you. I live in Edmonton but spend most of my free time in Vermilion (when I get free time), so if i am headed out its no big deal.
I just sold my truck for a jetta so its not much use, but you never know.
780-686-3226
1989 3+3 2wd Dually. 454 BB. Factory loaded for the day, including Alcoa rims.
hick is offline   Reply With Quote
Old 03-23-2014, 12:38 AM   #29
Crew Laid
780-686-3226
I actually get my panels through Tyler at Hooligans in Camrose. He probably gets them trough them though.Thats good to know if I do need anything I'll definitely let you know.
Old 03-23-2014, 12:46 AM   #30
Crew Laid
Well it was -9 celsius here today so I decided to start tearing the interior out of my truck today.
The front seat is out.
Started to tear down the driver side door since I have to replace it.
Rear seat is also out.
Tore the front section of the carpet out. I would of tore the rear section out but the front lower seat belt bolts are seized so that stopped me from removing it.But all the other belts are out.
Old 04-04-2014, 06:24 PM   #31
Crew Laid
Well some more panels showed up yesterday. My correct floor pans are now here.
The remaining 2 reg cab rockers are now here as well.
My cab supports were supposed to be here too but they were left behind. I'll pick the up when I go to grab my 3 new doors. I will be resuming teardown on my truck tomorrow. I will post pics once we are done the swap.
Old 04-04-2014, 11:00 PM   #32
y5mgisi
Second Chance Program
y5mgisi's Avatar
Subscribed.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 04-05-2014, 11:48 PM   #33
Crew Laid
Originally Posted by y5mgisi View Post
Subscribed.
Thank you I appreciate that.
Old 04-05-2014, 11:58 PM   #34
Crew Laid
Well I finally got a couple of my friends together to help me teardown my truck a little bit.
Here is where I left off in the fall last year.
Teardown resumes.
My friend had just finished removing the bolt that is in behind the door. He stepped away to put the bolt into the bolt bag and the fender folded over like this.
Here you can see how rotten the lower section was.
Just some random teardown pics.
My pile of scrap metal. I still need to remove the a/c condenser.
After messing with one of the seized seatbelt bolts for almost an hour we just cut the head off of it and it fell out the bottom. The rear carpet it now out.
Here is how it sits now.
Old 04-11-2014, 11:50 PM   #35
Crew Laid
I finished stripping the rest of the interior out of the truck last night.
The front floor pans were worse than I expected actually.
The rear floor is really good. I only found one small rust hole beside the seat belt bolt hole.
I know these are very common to find but this is the very first time I've found a build sheet in any of my projects. The truck was build in Baltimore. It was sold to a dealer in Hague Saskatchewan.
Old 04-15-2014, 12:24 AM   #36
Crew Laid
Still slowly tearing my truck down. Finished up tearing a few last things out of the interior of the truck.
Dash pad and gauge bezel are out. I'm going to fibreglass the dash pad to smooth it out. I have to replace the gauge bezel since it is all cracked and broken.
Does anyone know the exact purpose of this air chamber that attaches to the p/s kick panel?
Someone had decided to install a fire extinguisher on the rear pillar so I'm going to get rid of it.
I'm going to clean it up, fill the screw holes from the bracket and paint it.
Old 04-15-2014, 12:31 AM   #37
Crew Laid
I'm going to be eliminating the factory A/C system since it doesn't work anyways. Where I'm from if the vehicle is equipped with something it has to functional in order to pass inspection so I'm just going to save myself the hassle and get rid of it.
Good bye compressor.
I'm going to find a non a/c donor truck to get the proper p/s pump pullet and mounting bracket.
The A/C heater box is all broken underneath so it is going away.
I'm going to clean up the firewall where it mounts before I install the new heater box.
Old 04-15-2014, 01:18 AM   #38
COS399
COS399's Avatar
I believe that chamber is used to open and close the fresh air vent on the P/S by using a vacuum.
COS399 is offline   Reply With Quote
Old 04-15-2014, 01:01 PM   #39
Igorsgonemadd
Yep.....what he said.
Igorsgonemadd is offline   Reply With Quote
Old 04-15-2014, 11:09 PM   #40
Crew Laid
Oh okay. Thank you for answering my question fellas.
Old 03-10-2016, 05:29 AM   #41
hayesperformanceplus
Performance Shop Owner
hayesperformanceplus's Avatar
....I missed this thread...
I'm in Edmonton......
1980 GMC C25 Sierra Classic with 20,000 ORIGINAL MILES (32,000Km's) & Matching numbers
1977 GMC C35 Sierra Classic Crew Cab 454 A/C with 21,000 Miles & Matching numbers
1980 Chevrolet Silverado K20 400 4spd 4X4 74,000km's
1980 GMC C25 Sierra Classic CREW CAB, All Options, with 49,000 Miles
1979 GMC C15 Sierra Classic 454
1989 GMC R3500 CREW CAB
2003 Grand Prix GTP
1998 Regal GS
hayesperformanceplus is offline   Reply With Quote
Old 03-10-2016, 07:08 PM   #42
travlinman
U missed it cause its 2 yrs old! Lol ...wonder if it ever got finished
94 ls swap silverado
65 Pontiac
78 c30 crew cab dually (parted and gone)
82 c30 crew cab dually ( now building )
91 r30 crew cab dually (parted and gone)
69 swb-sold
71 lab sold
all in progress......__
..........._______ |__\__
..........|__(O)______(O)] ........................
travlinman is offline   Reply With Quote
Old 03-10-2016, 08:28 PM   #43
tinydb84
tinydb84's Avatar
He is still around. He has a shop doing some really nice work on it. Its on Instagram: Crew_Laid80 if you want to look at it.
David
Instagram: myfabguy
Old 03-10-2016, 09:10 PM   #44
....Ya late on the draw.... lol
Super! Love to see it....
2003 Grand Prix GTP
1998 Regal GS
