Old 06-27-2014, 07:38 AM   #26
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Name that bolt/nut/screw size
Gravel guard uses Phillips head bolt, 1/2" nut, and a star washer as shown on this 72 example I believe is untouched since left GM
Old 06-27-2014, 07:39 AM   #27
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Hatch handle uses tapered head Phillips head screw 1.25" long
Old 06-27-2014, 07:42 AM   #28
Dale99
So 1/2 nut would mean 1/4 threads IIRC?
That screw looks like it would be a #8 or #10??
Thanks for the pics!!!
Dale99 is offline   Reply With Quote
Old 06-27-2014, 07:44 AM   #29
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Sorry not sure re: the sizes otherwise but happy to help with pics
Old 06-27-2014, 07:51 AM   #30
Dale99
I looked up, it would be 5/16 threads on gravel guards.
Old 06-27-2014, 07:58 PM   #31
Dale99
Hatch handle screw is #8-1.25"
Old 06-27-2014, 08:34 PM   #32
70gmcjimmy
GMCDAC
70gmcjimmy's Avatar
Yeah that's the "normal" standard. 1/4" bolts have a 7/16" head and nut, 3/8" bolts have a 9/16" and a 7/16 bolt has a 5/8". There are possible variations like those 12 point hood latch bolts but these are normal I.D. for buying bolts.
Instead of "tapered" those screws would be called "countersunk" I have an unmolested '70 Jimmy partially tore apart that may provide some info you are wanting on this thread.
The rear seat hold down bolts are a 7/16" fine thread, as well as the seat belt bolts front, rear and the threaded holes in the roof where a shoulder harness was possible.
Great thread!---DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild!
1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish!
1955 GMC 100 2nd design driven almost daily!
Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09
GMC driver for 30 years!
70gmcjimmy is offline   Reply With Quote
Old 06-27-2014, 10:08 PM   #33
Dale99
70gmcjimmy, some of the questionable bolt size/threads have been answered. But your more then welcome to post any others. Skim thru and read all the post since it wont let me go back and edit the first posting.
Old 06-27-2014, 10:11 PM   #34
Dale99
screw/bolt head types.
Old 06-27-2014, 11:48 PM   #35
70gmcjimmy
GMCDAC
70gmcjimmy's Avatar
Well, sorry. I just went off some of these posts from earlier today. Have read it all but memory isn't so good at my age I guess.
DAC
Old 06-30-2014, 11:08 AM   #36
Rickenbach
Visor to windshield post screw
5/16-18 jackson panhead phillips screw, around .75 or 1.00 long. Very hard to find, however thanks to user bluek5, he found a place here. At the moment they are out, but I have a feeling if many people start placing an order, some will come into stock.
http://www.msc-stainless-fasteners.c...on-screws.html
Anyone know what screw is used to hold the hatch handle to the hatch?
I tried to order from MSC and they sent me to www.totallystainless.com. These guys seem to have everything.
Rickenbach is offline   Reply With Quote
Old 08-17-2014, 04:58 PM   #37
WhiteWhale
WhiteWhale's Avatar
ttt
WhiteWhale is offline   Reply With Quote
Old 08-17-2014, 09:02 PM   #38
My7d1
My7d1's Avatar
very helpful thread... will add when i can also be helpful!
My7d1 is offline   Reply With Quote
Old 11-01-2014, 12:15 PM   #39
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I'm trying to dig out the correct mount bolts for the OEM spare tire carrier to post example pics...I know I need one more (body shop lost one).
Old 11-01-2014, 01:52 PM   #40
Senorx
Senorx's Avatar
I have none of the bolts for my spare tire carrier, so I'll be waiting eagerly for this info. I appreciate you taking the time to do the research. My spare tire carrier goes to powder coat next week and I want to get the bolts done as well.
Senorx is offline   Reply With Quote
Old 11-01-2014, 04:58 PM   #41
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Still digging - I know I have some. They are similar to these seat bolts removed from a suburban but IIRC the head was larger and not as tall, fine thread maybe 1/2"?
Old 11-01-2014, 05:00 PM   #42
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Examples of carb stud and wing nut to attach the air cleaner to the carb
EDIT: The stud is 6 7/16" in length
Old 11-01-2014, 05:02 PM   #43
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Rubber upper rad heater hose w part # and tower clamps (from my 72 K1500 GMC but should be same for K5) - a segment of the metal hose can be seen.
Old 11-01-2014, 05:03 PM   #44
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Bracket to affix the power steering hoses to the frame
Old 11-01-2014, 10:12 PM   #45
Dale99
Spare tire bolts are 7/16-20 X 1.00 with outtie star washers. They are 5/8 socket. I broke one of mine off and going to have to tap and find another.
Old 11-01-2014, 10:17 PM   #46
Dale99
The screws that hold the cap onto the top of the door are #8x.50 Countersunk oval.
Old 11-01-2014, 10:28 PM   #47
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks Dale! Any pics to add?
Old 11-01-2014, 10:47 PM   #48
Senorx
Senorx's Avatar
Sweet! Thanks. I need to locate 4 of these.
Old 11-30-2014, 08:20 PM   #49
Senorx
Senorx's Avatar
Can anybody post a picture of the double wall top to bed rail OEM bolts?
Old 12-02-2014, 11:08 AM   #50
Chulisohombre
Chulisohombre's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=362908
This is post for body mount bolt size and length that I found. Another guy asked and I found this.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
