Old 05-11-2014, 03:36 PM   #26
Advanced Design
Advanced Design's Avatar
Re: 48 Burb, bagged, 5.3, 20 year wait
We pulled the seats, running boards, fuel tank and steering column / box in preparation for lifting the body hopefully next week end. At some point after the 'Burb was painted purple, the third seat was in it as the mounting studs are still there, the wing nuts were laying on the carpet and seat rail impressions were noticable in the carpet. Guy I bought it from likely pulled the third seat before throwing the 'Burb on Ebay.
Found some rust at toe board to floor pan joint on left side after removing the screwed in patch panels. Again not too bad. The rockers and door bottoms are solid.....now where did I put that clutch head screw driver I made when building the truck...?
Advanced Design is offline   Reply With Quote
Old 05-12-2014, 01:49 PM   #27
99 to Life
99 to Life's Avatar
Im in on this, can't wait to get a burb. so so sick I just love em.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 05-12-2014, 10:30 PM   #28
Advanced Design
99 to Life...I agree, have wanted a 'Burb since before the SUV craze hit.
Rare Monday night in the shop. Removed the side glass and found rust through behind the pinch weld in three of window openings.....that Texas dust must have been built up there holding moisture.
The seats are in good shape....we may end up using them...at least until after the first long road trip.
Old 05-12-2014, 10:34 PM   #29
99 to Life
99 to Life's Avatar
your 48' is mad cool. those seats outta the burb look crisp. I don't know what I'd choose to buy or build first, a burb or COE, its neck and neck. Luv em both. I was planning on doing up my 53' belair for the fam cruiser, I think it would be much more wise to just do a burb!!
Old 05-13-2014, 09:41 AM   #30
youngrodder
youngrodder's Avatar
AD.. This must be a farily common area for rust. I had one window open each side rust simular to yours. I plan to run all three rows of stock seats. Mine came with the rare (missing) 3rd seat. The main reason for this build was to get the whole family down the road. There is only 4 of us but they leaves room to invite more to ride along. They may not be as comfy as newer seats but to me I just think they fit the look so much better.
Looking good
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 05-13-2014, 11:05 PM   #31
Advanced Design
Thanks 99 To Life - Both are cool and choosing one is tough. I see fewer 'Burbs at events.
Marc - I wanted to build this one for a family cruiser too and I took so long getting to it the Grandsons will be going along. Daughter and her husband looked it over and are insisting on the original seats as they said (like you) they are cool and just look right. Nice score on having all three rows of seats.
Wife and I assembled the body cart tonight...will be handy. Soon I hope.
Old 05-14-2014, 09:43 AM   #32
youngrodder
The cart looks nice. I assume you bought it. If so, where did you pick it up at?
I need to buy/make something simular for mine.
Marc
Old 05-14-2014, 11:42 AM   #33
Advanced Design
Marc,
Bought the cart from Autotwirler https://www.autotwirler.us/ made in Indiana. In fact, when I picked it up they needed to weld up a couple additional pieces and they were hot off the welding fixture.
Each body mounting point is adjustable left / right, up / down, and fore / aft. Initially bought it to support the '35 Chevy body due to its wood structure and it should work well for the 'Burb.
Old 05-14-2014, 11:50 AM   #34
youngrodder
Marc,
Cool thanks for the info. It looks like a nice cart. I have one that I might see about modifying to use for the Suburban first.
Marc
Old 05-14-2014, 04:49 PM   #35
Iceburgh
Iceburgh's Avatar
My burb was rusted in the same area so I agree with Marc.
The cart is not a bad price if you use it again. I used one my FIL had and used 4x4 for mounting post
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
Old 05-17-2014, 10:11 PM   #36
Advanced Design
Dozens of screws later the ugly headliner is out.
Found some raggedly cut access panels for the rear fender bolt nuts....needed since the captured nuts were rusted out.
Old 05-17-2014, 10:19 PM   #37
Advanced Design
Thirty five years ago I would work on my 1969 Mach 1 in this same spot on dirt using heavy wood blocks (same ones we used for holding up heavy equipment) for support stands.
Gotta say working this way is much nicer.
Old 05-17-2014, 10:27 PM   #38
99 to Life
99 to Life's Avatar
I luv it all, keep it coming
Old 05-18-2014, 01:26 AM   #39
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Great looking project man !!
I am working on a '52 and was wondering if you could give me dimensions of the drivers seat ??
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 05-18-2014, 08:42 AM   #40
youngrodder
good progress. Most of my rear fender bolts were broekn off. I had to drill and tap just about every one. I love your hoist...... quite envious.
Keep at it.
Marc
Old 05-18-2014, 12:21 PM   #41
FarmerSid
FarmerSid's Avatar
I have a hoist too and it's a Gods send.
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 05-18-2014, 06:31 PM   #42
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Yeah, were not all as cool as you Sid! lol. Progress looks awesome!
--Josh
Old 05-18-2014, 08:31 PM   #43
Advanced Design
John-
Hope these help - pics are a bit fuzzy. The overall width as shown for the driver (and middle passenger - people were smaller in 1948!) is @ 36" and the dimension across the seat track is @20" and height is about 4 1/2". And am sure you are aware there is a raised platform for the driver seat. If you need something more specific please let me know.
Old 05-18-2014, 08:47 PM   #44
Advanced Design
Guys-
Really appreciate the words of encouragement. My closest car buddy lives over an hour away so we don't usually get much shop time together. Really good friend stopped by the shop Saturday (we use to build cars together 30+ years ago) and he doesn't get it anymore.
"What, you started on another one?" "What color are you going to paint it?" "Whadd'ya mean you might just drive it like this?" Blank blink blink stare...
Anyway the lift is great and was a 50th birthday present from the wife....wish it would have been a 40th. Always knew a lift would make things easier and until this one came along I didn't really understand until I experienced it myself.
Didn't want to leave the 'Burb dangling all week so we placed it on the body cart. The cart would be overkill for one project and since I have more vehicles on the list it is worth it. Will be real useful to drop the two front mounts, slide the cross member back and support at the rockers while I replace the rusty front metal.
Grandsons were helping today.
Old 05-18-2014, 08:52 PM   #45
Advanced Design
Tucked the 'Burb body back in the corner and moved the frame in place to remove the body mount and running board brackets for installation on the new frame.
Old 05-18-2014, 11:41 PM   #46
oldman3
oldman3's Avatar
Little guy in the green hoodie " Crap, even with these glasses I can't read the size". When your old like me you catch these little items and think of yourself...Jim
oldman3 is offline   Reply With Quote
Old 05-18-2014, 11:45 PM   #47
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
John-
Great, thank you much !!
My buddy has the 52 GMC, and I have a 62 GMC
His came without seats, so he is on the hunt !!
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 05-19-2014, 01:40 AM   #48
79azc10
Wow looks nice so far , I love the look at the truck as well
79azc10 is offline   Reply With Quote
Old 05-24-2014, 08:54 PM   #49
Advanced Design
John - I have more pic's with dimensions for you. Please PM me and I will send them over full size for better resolution.
No Burb work was accomplished today other than moving the frame back off the lift to use it for the 56 Chevy. Wrapping up a pesky fuel leak and a few other minor items for the HRPT.
Old 05-30-2014, 08:12 PM   #50
Advanced Design
We had zero time in the shop this week and I was able to pick up some rust free front fenders, left inner fender well, radiator support and latch panel.
The fenders on the 'Burb were really solid and the right one was pretty bent up. The left one is good. Seller would only let these go as a set...I couldn't resist since rust free is hard to find here in the rust belt. Just buying them was much quicker than the truck build when I spent months looking for nice ones.
Green doesn't really match the faded purple...and if we don't paint the Burb we are building something cool and different or ugly and different. Probably more ugly and different.
Plan to get back on the frame tomorrow.
