Old 09-14-2018, 11:12 PM   #26
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Crate GoodWrench 350 Questions
Originally Posted by Warrens69GMC View Post
1978 Big 10, 165hp 350, TH350, 3.08 and 28" tires. Doesn't do too bad, except loaded and going uphill.
You might need 3.42 rear gears.
66 C20 Service Truck:
Old 09-14-2018, 11:25 PM   #27
SunSoaked
SunSoaked's Avatar
Or a Duramax transplant
SunSoaked is offline   Reply With Quote
Old 09-15-2018, 09:20 AM   #28
Warrens69GMC
Warrens69GMC's Avatar
I have a 1995 LT1 and 4L60E from a camaro, thinking of 3.73 gears as well.............🤔
Old 09-15-2018, 08:47 PM   #29
LostMy65
LostMy65's Avatar
I've been doing research, is it true they built it with really low compression so the engine could use low octane gas?
Old 09-15-2018, 10:10 PM   #30
Warrens69GMC
The goodwrench 350? Yes that is partially true. They wanted a economical engine that could be put in most 1985 and under cars and trucks and pass emission standards everywhere. If the made a 350hp 350, it might not pass some emission requirements.
Old 09-16-2018, 09:45 AM   #31
AcampoDave
AcampoDave's Avatar
Agreed, mostly stock 283 with 225/75/15 tires and 3 on the tree. 3.08 is great
AcampoDave is offline   Reply With Quote
Old 09-16-2018, 11:24 AM   #32
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
My 78 big 10 is just like yours, stock 350/TH350 and 3:08, and will hold 70 with the AC on using the cruise going uphill with out any trouble.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 09-16-2018, 12:12 PM   #33
Warrens69GMC
I agree. I was referring to it loaded AND going uphill. Like with a 1500 slide in camper and another 700lbs worth of stuff inside.
Old 05-10-2021, 12:32 PM   #34
LostMy65
LostMy65's Avatar
I'm not sure why I missed this post before.
That totally makes sense. I just couldn't figure why they would deliberately build it to be a dog - It needs to pass emissions in every State in every car.
Here in Oregon anything around 1974 and older doesn't have to do an emissions test.
Old 05-10-2021, 01:34 PM   #35
LostMy65
LostMy65's Avatar
Is there a way to know what horsepower version my GM Goodwrench 350 is?
I found this in another thread:
https://www.mortec.com/location.htm
Old 02-09-2022, 06:10 PM   #36
LostMy65
LostMy65's Avatar
Is a stock gm Goodwrench 350 good 'as is' for a truck application where you are mainly concerned about fuel economy and low end torque?
Old 02-09-2022, 08:49 PM   #37
SunSoaked
SunSoaked's Avatar
Mediocre. I had to swap to vortec heads, cam and headers so it could get out of it's own way.
Old 02-09-2022, 09:03 PM   #38
AcampoDave
AcampoDave's Avatar
I think its fine however, these days a roller cam seems to be the hot ticket because of the new oil. I do fine with a 283 for just driving around so that 350 should be great for driving around. Especially if you have dual exhaust and a nice aluminium dual plane intake. I dunno I've seen many a smokey burnout from a stock Goodwrech 350 in a classic truck.
Old 02-09-2022, 09:50 PM   #39
Warrens69GMC
ZZ shortblock, summit vortec heads and a dual plane intake is the ticket right now
350, crate, engine, goodwrench
