#26 |
Re: 1987 GMC V1500 LS Swap help
My suburban had all metal lines with a stainless flex near the motor and tank
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
#27 |
#28 | |
meowMEOWmeowMEOW
Since your donor is return style, I'll assume that the plan is to keep it that way, which is fine. I guess I should mention that if you did decide to have a fuel cell made (or bought one sized), you may be able to drop your sending unit/fuel pump assembly into the fuel cell, using the lock ring like stock. PLUS, if you use a fuel cell of similar depth or dimension, then you don't need to worry about "scaling" its readings. If you keep that sending unit, then the rearmost section of your fuel lines can be reused (use the Evap as a vent). Splice the hardline to some new parts-store hardline, or into your old hardline if its 3/8 and in good shape (and NOT aluminum!). Run that to the front (pretty much a straight shot along the frame rail), and up the firewall. Once you've got that in place, you can use the donor Nylon lines and PTC, or one of those parts-store Nylon line repair kits. Depending on if the donor's bends fit/line up, you may end up needing to use some parts from the repair kit....in which case just using the repair kits itself to make a new line might be easier. That was a little wordy, but you get the idea.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#29 |
Sounds like a good plan BR3W!!
#30 |
I looked some more at the D.S. frame rail for running fuel line... It is basically bare and empty.. It is real tempting. However, I would like the fuel to be on the p.s. that way it can level out my 190 lb ass in the drivers seat lol. I don't want it to lean
![]() I did some cleaning today though. ![]() ![]() Doesn't look too terrible... I mean it did have close to 150k on it. Run her till she goes then swapping in something bigger ![]() ![]() ![]() I did find this tho... Apparrently it was already sheared and just hangin in there... The rear ones seem to have already been broken too? How the hell to get out. Aluminum scares me. ![]() ![]() oh well... ![]() Whats this for? ![]() Also it isn't perfectly clean.. What do yall use for paint? I mostly use duplicoler or rustoleum brands. Also opinion on painting trans? My plan is just to pretty much paint the block black.. Cant decide what I want to do about timing cover, oil pan, valve covers, and accessory brackets.. Do yall paint them, they dont seem to clean up easy and just oxidize like a few months down the road. |
#31 |
meowMEOWmeowMEOW
I painted my whole trans (as always, check my build!), and the block. No problems as long as you don't paint INTO the diptstick hole or over the electronics.
For the inside of the engine, you can try to steam clean it....or just run it and put a few cans of seafoam through it....like...a BUNCH of cans for that much crap. The black "paddle" bracket thingy is to protect the fuel rail from getting smacked against stuff....I left it one ![]() I have a DIY media blaster locally, so I can just blast it a few days before paint, without too much delay. I've made it one process; media blast, take home, wipe with solvent, dry, paint with primer. After that I can give it however long before color.
#32 | |
I'm not too hell bent on this being super nice... This is my purpose built truck... When I get my CCSB square body now that one will be made to be pretty! |
