Old 06-19-2014, 06:31 PM   #26
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: 1952 Chevy Vette Roadmaster LT1 Farm Truck Build
Absolutely amazing work bro. Amazing! I love that visor. Wish I had one for mine. Really looking forward to more progress.
--Josh
Old 06-19-2014, 07:04 PM   #27
fabguy
Elev8r Man
fabguy's Avatar
Build looks REALLY sweet!!!
1955.2 C4 Carry-all / Suburban ---> 55.2 Build Thread!!
1958 Fleetside SWB ---> 58 Fleetside Build thread
1939 2 door sedan
My F.B. project page.
fabguy is offline   Reply With Quote
Old 06-19-2014, 07:31 PM   #28
FarmerSid
FarmerSid's Avatar
Thanks guy's for the comments. Worked on fitting of the outer cowls tonight for a bit. A bit of hinge tweaking to get the doors flush front and back and top and bottom.
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 06-19-2014, 09:48 PM   #29
MIKESAD50
Nice work!
I'll be following
MIKESAD50 is offline   Reply With Quote
Old 06-19-2014, 11:11 PM   #30
oldman3
oldman3's Avatar
Wow, the amount of work to the cab is unreal, super nice job on everything...Jim
oldman3 is offline   Reply With Quote
Old 06-20-2014, 07:38 AM   #31
FarmerSid
FarmerSid's Avatar
Thanks again guy's. The sheet metal was worse than I thought. I ended up making my own new front cab mounts and rocker patches.
C4 IFS & D44 IRS
5.3 HO L33
Old 06-23-2014, 11:11 PM   #32
STOCKISH
STOCKISH's Avatar
How are you making out up there Bro? Any progress lately?
--Josh
Old 06-25-2014, 08:09 PM   #33
FarmerSid
FarmerSid's Avatar
Getting gaps set has been a chore. Trying to get them to 3/16" or the thickness of a paint stick. Two full days last weekend on one door has pushed the limits of my patience so I decided to pull away for a few days and work on my ATV's. One needed the carb cleaned and the other needs both inner rear CV joints.
These after market parts are something to be desired. The inner to outer cowl part is the biggest pile of ........ I've ever seen.
C4 IFS & D44 IRS
5.3 HO L33
Old 06-26-2014, 08:44 PM   #34
pgf545
pgf545's Avatar
I actually had to do some sectioning to get my gaps close and they still aren't perfect.....lol. If you ever look at an original truck the gaps are not real close, these were original farm trucks and only us hotrodders are crazy enough to want decent door gaps. I have looked at a lot of these trucks at shows and most of them the gaps are less than perfect. I did the best I could and am moving on.
Bernie
52 Chevy Truck (Dad's)
http://67-72chevytrucks.com/vboard/s...d.php?t=206021
pgf545 is offline   Reply With Quote
Old 06-26-2014, 08:49 PM   #35
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Very nice project.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 06-26-2014, 10:17 PM   #36
Advanced Design
Advanced Design's Avatar
Nice work and I am really enjoying the build! Thanks for sharing.
Advanced Design is offline   Reply With Quote
Old 06-27-2014, 07:36 AM   #37
FarmerSid
FarmerSid's Avatar
Thanks all! One thing I am finding that may help out others that have to replace the rear panel and outer cowls. When installing the doors to set gaps, spend more time on the front outer cowls setting the gaps with the door and save the trimming and such for the rear panel and door gaps. You don't have to remove the door each time to do cutting and welding. You do for the where the outer front cowl and door meet. It's also easier to hammer and dolly any welds on the rear panel. That's what I have found so far.
Anyway's, a bit of a story I forgot to mention earlier. When I started smoothing the fire wall, I removed the 4" cover plate on the passenger side of the firewall and look what I found.
Pretty cool! It's the same key cut as the one I got with the truck. First owner probably hid in there when it was brand new.
C4 IFS & D44 IRS
5.3 HO L33
Old 06-30-2014, 07:22 PM   #38
FarmerSid
FarmerSid's Avatar
Not much but a bit of an update. Got the door openings smoothed out now that the rear cab panel in welded in and done. Door jamb looks nice with no seams. rear panel is a bit thinner than the rest of the panels. Almost buggered up and scrapped the right outer cowl as the curvature to the door and being flush to the door is way off. With so much welding on it, it looked like crap. I pulled out my shrinker stretcher and made a new piece so now I think I can save it. Not done yet but on the right side but the drivers side looks like it's going to be a pain too.
Give me a bone guy's! Should I be grinding away at the door edge to get my gaps set? This is the hardest thing yet on this build.
C4 IFS & D44 IRS
5.3 HO L33
Old 06-30-2014, 07:40 PM   #39
oldman3
oldman3's Avatar
Sid, I ground the edge of my doors for better gaps. In my case the "A" pillar had nice line and so did the back part of cab. I used a paint stick to get my gaps. Some places I had to weld to make smaller and some places I had to grind down oversize and then weld back up. To dress the edges of the door I used a long file to bring back to size, so stick would clear....Jim
Old 06-30-2014, 08:47 PM   #40
FarmerSid
FarmerSid's Avatar
Thanks Jim. How much did you have to grind off the doors? A wooden paint stick that I have is 3/16" thick but the gap looks a bit much. I have a aluminum auto body paint stick that is a bit thinner and i like the looks of that gap better. By the looks of things I'm gonna have to grinds off about an 1/8" off the door if not more. The belt line gaps are perfect. Both outer front cowls have to be cut and pulled out and cut and pulled forward to get a decent gap along the front of the doors..
C4 IFS & D44 IRS
5.3 HO L33
Old 06-30-2014, 11:26 PM   #41
oldman3
oldman3's Avatar
My paint stick was about 1/8" I think. Sound like your door and body were worse than mine, but on the pass. side some parts were ground down an 1/8" or more and then rewelded. I didn't have to move any of my front cowl, but the cab corners had to be worked a lot (repop stuff)...Jim
Old 07-28-2014, 12:45 PM   #42
Algoma56
Great project, and great writing and photos. I bought C4 pieces off of Kijiji last spring for a Nomad project. Trying to find someone with OEM dimensions for the C4 stuff, so I can plan the conversion ahead of time.
Algoma56 is offline   Reply With Quote
Old 08-07-2014, 08:57 AM   #43
STOCKISH
STOCKISH's Avatar
Hey Sid, how's everything going up there buddy? Hope everything is going well.
--Josh
Old 08-08-2014, 02:16 AM   #44
Nut Case
Nut Case's Avatar
I'm just starting to follow this build. My project (soon to start is a 57 GMC that I have purchased 93 vette IFS & IRS) I would like to get the drawings for the IFS that you are using to fab your own cross member. I willing to sweeten the request if necessary to get these drawing and dimensions. Please let me know. I made a deal with my wife, I will build her a head board for the master bedroom before I can start this build. I promised that I would after finishing our son in law's 52 F1. But that doesn't stop gathering information. So let me know. Thanks
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 08-08-2014, 08:23 AM   #45
solidaxel
solidaxel's Avatar
Very Impressive, a lot of decisions to be made and a farm to run, still have time for a great project.
Keep up the good work!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 08-08-2014, 11:13 AM   #46
48ChevBagged
48ChevBagged's Avatar
Awesome job.
48ChevBagged is offline   Reply With Quote
Old 08-12-2014, 09:28 PM   #47
68 Four on the Floor
68 Four on the Floor's Avatar
your work is awesome Cid. That crossmember is sweet. Why build one and not use the stock C4?
68 Four on the Floor is offline   Reply With Quote
Old 08-12-2014, 09:30 PM   #48
STOCKISH
STOCKISH's Avatar
The stock crossmember doesnt fit well in the AD trucks and doesnt look very good either.
--Josh
Old 08-12-2014, 10:02 PM   #49
tobins 52 gmc
tobins 52 gmc
nice work
tobins 52 gmc is offline   Reply With Quote
Old 09-09-2014, 08:14 PM   #50
FarmerSid
FarmerSid's Avatar
Hey all! Thanks for the comments and call to make sure I'm alive and kick'in. Been a bit I know. I'm still here and have made a bit of progress. I will update you all tomorrow when I have some more time. Till then.......
C4 IFS & D44 IRS
5.3 HO L33
