Old 09-15-2014, 03:58 PM   #26
cg285
Re: Clutch Question
half hour job on a lift. did a zillion at the dealership back in the day. why anyone would choose to work harder, by removing unnecessary parts, makes no sense - on any job
cg285 is offline   Reply With Quote
Old 04-11-2017, 06:19 PM   #27
Port&PolishMan
Port&PolishMan's Avatar
Re: Clutch Question
Holly Thread Revival :
V8 Chevy replaced 235 6 cly. 1954 - 3800 Dual & 4 Speed with PTO - sound like I may something rubbing in Clutch Throw Out ?
Pressure plate Area ?
Can't seem to Pin Point it .. but when I let the Clutch out in Neutral it seems to stop
most times .. just upon start up for like 20 Seconds then goes away - had two other guys look at it there all Scratching Heads . .
Guess I may need to Buy an Owner's Mechanic's Tech . Manual . .
Port&PolishMan is offline   Reply With Quote
Old 04-11-2017, 06:46 PM   #28
padresag
Re: Clutch Question
are you sure that you are in the right forum. shouldn;t this been in the 47-59 section.there is not much in the clutch that can make a rubbing noise unless tou have a bearing in where the pilot bearing usually goes in those tears. throw out bearing can cause noise. how much free play do you have in your clutch pedal?
the other scenario is the input shaft bearing in the trans.drain the gear oil out and see what cuttings come out. the load is off it when it is in nuetral. if you are sitting there with the clutch in does it still make the noise. does the clutch itself work properly
ron
padresag is offline   Reply With Quote
Old 04-11-2017, 08:18 PM   #29
Port&PolishMan
Re: Clutch Question
ron
Yes, sorry got it in Here by mistake , Thank You Thou .
Clutch seems good and all shifts are fine .
Input Shaft Bearing - Yeah , may have to check that Oil . .
Hoping it isn't in the Motor . . just Odd - I thought the Starter was Hanging Up , but the sound is Off ..
I'll do a Sound File ..
https://youtu.be/SWfoJyPSjso
Old 04-11-2017, 08:25 PM   #30
padresag
Re: Clutch Question
put it up on stands or a hoist and listen to it with a stick to your ear and the other end on different places andd isolaye the noixe. sound file is going to solve it.solve it for yourself
ron
