Old 10-24-2014, 02:22 PM   #26
Orangetonicclicc
Orangetonicclicc's Avatar
Re: "Almost Heaven" 67 - swb- Lilly
Originally Posted by rkintn_68 View Post
Starting on the fuel cell and lines ... Would love to hear advice on which
way to go with the type of fuel lines and the best fuel cells ... I am looking at -
JEGS Performance Products#555-15348
20-Gallon Fuel Cell•0-90 Ohm GM Fuel Level Sender Included
•(2) -08AN Male Outlets
•(1) -08AN Male Vent
•(1) -08AN Male Rollover Valve Fitting
•24" L x 20" W x 10" H
•Black Powder-Coat Finish
Would you use hard line,(Fuel & Transmission Cooler Line Coil •Galvanized Zinc ) 5/16"? 3/8"? or the Pro-Flo 350 Braided Hose ? And wat size diameter ?
is 08AN diameter OK ?
I'm interested to know the samething. I have some 3/8 Stainless steel but you need a certain flare to make the connections plus I have to bend everything. I kind of like Pro-Flo350 Braided Hose route! No Brainer doing it that way!
Orangetonicclicc is offline   Reply With Quote
Old 12-18-2014, 08:13 PM   #27
rkintn_68
rkintn_68's Avatar
Merry Christmas to all !!! have not done much to the truck lately ...
my painter guy backed out on me , so have not had the cab painted ...
I need some advice on the wiring , is the http://www.summitracing.com/parts/prf-10112
or is this one the easier one to use ? http://www.ebay.com/itm/331394910421...%3AMEBIDX%3AIT
72 GMC K 1500 SWB W/ 68 CHEVY FR/CLIP -- SOLD
70 CHEVY C/10 LWB x 2 ----- SOLD
67 CHEVY SWB IN PROGRESS " ALMOST HEAVEN "
Build thread :
http://67-72chevytrucks.com/vboard/s...15#post6826315
rkintn_68 is offline   Reply With Quote
Old 12-19-2014, 01:20 PM   #28
swamp rat
swamp rat's Avatar
Heres a thread that may interest you on the wiring kit, may help make a decision.
http://67-72chevytrucks.com/vboard/s....php?p=6959818
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 12-25-2014, 02:28 PM   #29
rkintn_68
rkintn_68's Avatar
thankyou , the links helped a lot , I will probably just get the whole kit
from Brothers ...
here are some pics of the progress so far ...New , Chrome SB Chevy 110 GPH 7.5 PSI Fuel Pump W/ Chrome Mounting Plate & Bolts 350, AGR Performance Billet Steering Boxes, Lokar KD-2400HT GM TH-400 Stainless Steel Electric Kickdown Cable Kit Brush Fini , SS tran cooler lines , fuel cell ,GM CHROME 120 AMP 1 ONE OR 3 THREE WIRE SBC BBC CHEVY ALTERNATOR ES-1001-C ,Holley 600 CFM Polished Aluminum Carburetor - Electric Choke (Part #0-80457SA, rebuilt TH 400 , 66 327 V8 , SS braided brake lines , 1967-1972 chevrolet c10 truck suburban chrome brake booster and master cylinder,Steering U-Joint / Vibration Damper, Polished Stainless, 3/4DD X 13/16-36 100% Genuine Borgeson,Borgeson Universal Steering Shaft Steel Alloy Universal Each 409418,Borgeson Univ Steering U-Joint Stainless Steel Polished 3/4" 36-Spline 3/4" DD ,SBC Small Block Chevy 305 327 350 400 BLACK Coated Block Hugger Shorty Headers,Black Cast Iron High-Flow Water Pump •1969-76 Small Block Chevy (Long Water Pump) Black Cast Iron , Accel 8021 - Accel 8.8mm Ignition Wires,fuel line Pro-Flo 350 Braided Hose•-8AN
1970 1971 1972 Chevy C/K Series Pickup Champion 3 Row Aluminum Radiator CC369
Build thread :
Old 12-25-2014, 02:53 PM   #30
rkintn_68
rkintn_68's Avatar
more pics , MERRY CHRISTMAS !!!
Build thread :
Old 06-07-2015, 01:08 PM   #31
rkintn_68
rkintn_68's Avatar
Still waiting on paint , so I just put another cab on so I could get
everything working ... So first thing I did wrong was blow up my tank by
not venting it , busted a weld , gas sprays out ... second I cant get my
steering right , it gets hung up wen u turn left or right and u have to jerk it
back , t I thought bad column but I had a new rebuilt one , so I put it in ,
same thing , not the column ... Any Ideas ???
Build thread :
Old 06-07-2015, 05:54 PM   #32
Xeen
Xeen's Avatar
There are a few different possibilities for why the steering could be hanging up.
Believe it or not the centerlink can be installed backwards and you won't realize it until later when you start having interference issues and tire scrub.
The other possibility is the steering box needs adjusted, it is made so that you can adjust the tightness of the gears inside, it sounds like yours is way too tight and you need to loosen it just slightly, now keep in mind that a little goes a long ways adjust it by 1/8 of a turn at a time, here is a link to a video so you can see how to do it.
https://www.youtube.com/watch?v=W5Ck4eANgII
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 06-08-2015, 05:39 AM   #33
rkintn_68
rkintn_68's Avatar
Thank you Brian , I 'll check that out ...
Build thread :
Old 12-13-2015, 06:58 AM   #34
rkintn_68
rkintn_68's Avatar
Over a year later , still not done , gotta get new bed and paint it !!!
interior getting close ...
Build thread :
Old 12-13-2015, 08:36 PM   #35
preacher anthony
Are you not going to use the bed in the photo? I'm looking for a fleet side shorty myself. If you are selling the one in the photo, send me a PM and some pics. Thanks
preacher anthony is offline   Reply With Quote
Old 12-13-2015, 08:48 PM   #36
rkintn_68
rkintn_68's Avatar
sorry bed not for sale, its off another truck, just using it for mock up...
Build thread :
Old 12-13-2015, 10:34 PM   #37
preacher anthony
Okay, thanks
Old 12-14-2015, 02:46 PM   #38
Hart_Rod
Hart_Rod's Avatar
in...
Hart_Rod is offline   Reply With Quote
Old 12-20-2015, 11:49 PM   #39
rkintn_68
rkintn_68's Avatar
Little more interior done ... All new glass , weather stripping , vent windows...
Build thread :
Old 12-20-2015, 11:56 PM   #40
Clavo106
sweet!
Clavo106 is offline   Reply With Quote
Old 12-21-2015, 01:31 PM   #41
nds1968
nds1968's Avatar
Looking good, did you ever get your steering issues sorted out?
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
Old 12-21-2015, 03:30 PM   #42
rkintn_68
rkintn_68's Avatar
yes , just went back to the original gear box and all problems solved ...
Build thread :
Old 12-22-2015, 06:04 PM   #43
nds1968
nds1968's Avatar
Ah man, I have an AGR box. Hope it doesn't give me trouble. I'm liking your glove box door....
Nate
Old 12-25-2015, 09:05 PM   #44
Possmguts
Possmguts's Avatar
Do you have a part number on those front rotors?
And WHERE DID YOU GET THAT GLOVE BOX DOOR??
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 12-26-2015, 07:00 AM   #45
rkintn_68
rkintn_68's Avatar
Not sure about the rotors , I bought chassis from a board member,
http://67-72chevytrucks.com/vboard/s...d.php?t=600288
Have not seen many of the glove box doors , I just happened across
this one on Ebay ...
Build thread :
Old 12-26-2015, 09:37 AM   #46
hillbilly_deluxe
Keep moving forward. Truck looks killer
hillbilly_deluxe is offline   Reply With Quote
Old 12-31-2015, 07:51 AM   #47
rkintn_68
rkintn_68's Avatar
Can not get my hood lined up everyway I move it is wrong !!!
Passenger side is up high in front and wider gap on fender , crazy ???
Will the billet hinges solve my problem ? Any advice is appreciated...
Build thread :
Old 01-15-2016, 05:14 PM   #48
New_70'C10
New_70'C10's Avatar
Just found your build and subscribing. It's looking good with everything you're doing to it. As for the hood; something that long moves a long way with just a little bit of adjustment. For the side to side gap have you tried loosening one bolt (one bolt not one side) at a time on the hood to hinge bolts (not hinge to fender)? I'm sure you've done everything we're going to ask you but its hard to know since we're not there.
1970 SWB CST; 307ci, 200-4R, (Slow Motion)
New_70'C10 is offline   Reply With Quote
Old 01-15-2016, 05:22 PM   #49
Possmguts
Possmguts's Avatar
could even be in the core support side to side if the gap at the cowl is good... ? maybe
Old 01-15-2016, 06:12 PM   #50
FOSTER21
That probably the best gap you'll get on the passenger side
FOSTER21 is offline   Reply With Quote
