Old 10-12-2014, 05:01 PM   #26
240zdogg
Re: 1968 GMC P-10 Ice Cream Truck
Originally Posted by P10-001 View Post
Looks good!
I went with led signal lights instead on mine. Anything was an improvement on mine!
Sweet.... i love to see the air ride done, ill keep that company in mind. I have 3 other projects im trying to finish also,70 240z,81 maxima wasgon and my P10,with a bum budget. Super cool on the LED headlights also, i brought a set but there 5 3/4 size so if you seen the headlight missing in my pic....im trying to convert it to fit
240zdogg is offline   Reply With Quote
Old 10-12-2014, 05:02 PM   #27
240zdogg
Sorry here the pics of my lights....
Old 10-12-2014, 05:04 PM   #28
240zdogg
Question.... were did you get your diamond plate panels at?
Old 10-12-2014, 07:01 PM   #29
P10-001
P10-001's Avatar
I got them from a local metal supply. They are 1/8", 4'X8' and they ran about 185 a sheet.
1968 GMC P-10
P10-001 is offline   Reply With Quote
Old 10-12-2014, 07:41 PM   #30
240zdogg
Cool, thanks again...keep me updated.
Old 10-14-2014, 12:56 AM   #31
P10-001
P10-001's Avatar
Not a ton of progress today. I got the firewall primed and painted.
I'm thinking of going with custom gauges, the oem one seems like more trouble than it's worth.
I've also been looking at how much higher the front fenders are than the rear. I think it might look good to drop them about 6".
Any thoughts?
1968 GMC P-10
Old 10-15-2014, 03:53 PM   #32
240zdogg
Smile Re: 1968 GMC P-10 Ice Cream Truck
Just got my radiator shoe horn in today, 3 row aluminum i got off freezebay as a blem, had to cut the side mounts off but the top will work just fine. Also had to grind the support at the top to allow the hose to fit thru. " radiators4less " here the size... Core Size: 16 3/4 x 20 3/4 x 2 1/4
3 Rows Of Tubes
Tank Size: 2 3/4 X 21 - Both
Inlet Hose Connection: 1 3/4 Driver Side
Outlet Hose Connection: 1 1/2 Passenger Side - Curved Upward Slightly Side
Transmission Oil Cooler: NO
OVERALL DIMENSIONS
23" HIGH X 23 3/8" WIDE
MOUNTING BRACKET BOLT HOLE SPECS
22 1/8" WIDE CENTER TO CENTER
11 3/4 HIGH CENTER TO CENTER
Here what it fits......
1953-1954
DODGE CORONET
MOST ENGINES / CHECK HOSE PLACEMENT
1953-1954
MULTIPLE DODGE CARS
Got it as a blem for $99.00 with free shipping.
Old 10-15-2014, 04:20 PM   #33
P10-001
P10-001's Avatar
3 Rows Of Tubes
OVERALL DIMENSIONS
1953-1954
DODGE CORONET
1953-1954
MULTIPLE DODGE CARS
Looks good!
Mine has a newer radiator in it already, it's mounted to the grill support. I'm probably going to use an electric fan on it. I got rid of the old radiator support. There is a lot more room in there now.
1968 GMC P-10
Old 10-15-2014, 08:19 PM   #34
240zdogg
Looks good!
Thanks buddy,seen yours,looks great also. Im going to have to do the electro fan also,its a 14incher. If i remember right autozone has he relay to activate it,ill post a pic if need,i just have to go and get it. Your right,you get rid of that support..... its huge in there.
Old 10-16-2014, 10:54 PM   #35
P10-001
P10-001's Avatar
Wired up my halo headlights today
1968 GMC P-10
Old 10-20-2014, 11:06 PM   #36
P10-001
P10-001's Avatar
Got my air suspension in today, started taking the front end apart. Seems daunting, but one piece at a time I guess.
1968 GMC P-10
Old 10-20-2014, 11:23 PM   #37
Lees68GMC
Lees68GMC's Avatar
I'm having a sudden, strange craving for an Eskimo Pie or a Drumstick
68 GMC SWB Vortec 5.3
98 Chevy Blazer ZR2
94 Mazda Miata, LS2 6 speed, sold
"No matter what happens, nobody gets out alive"
Lees68GMC is offline   Reply With Quote
Old 10-20-2014, 11:35 PM   #38
P10-001
P10-001's Avatar
I understand, but I can't eat my own supply....
1968 GMC P-10
Old 10-21-2014, 10:17 PM   #39
240zdogg
Sweet, you can get with green? major ticket herein cali.... nice looking.
I had o change my LED to HID,it was too much work to adapt the smaller LED light.
Old 10-21-2014, 10:20 PM   #40
240zdogg
Looking forward to seeing done....
Old 10-21-2014, 10:22 PM   #41
240zdogg
Had a question, im having a charging problem, any pics of your alt wiring set-up P10-001?
Old 10-22-2014, 12:01 AM   #42
P10-001
P10-001's Avatar
I can look to see if I have a diagram of mine.
Is your alternator a single wire or does it have a single wire plus the two wire plug? (Internal regulator)?
Starting from scratch was the best way with how badly mine was done by the previous owner.
1968 GMC P-10
Old 10-22-2014, 06:26 AM   #43
BigDaddyV
BigDaddyV's Avatar
I'm in for this build. Love the truck
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase
1955 Chevy Stepside "Dudley"
My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288
1972 Chevy C10, Project "Chevro~Layed out" Nether Storm
Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523
BigDaddyV is offline   Reply With Quote
Old 10-22-2014, 06:12 PM   #44
240zdogg
Its single wire with two wire plug.
Old 10-22-2014, 06:12 PM   #45
240zdogg
Thanks BIG DADDY....
Old 10-22-2014, 06:15 PM   #46
240zdogg
Finally put my shifter in, hope my seat lines up so i can shift shifter her...
Old 10-23-2014, 12:13 AM   #47
P10-001
P10-001's Avatar
Started really getting into the air bags today. I got the front end torn down and realized that it makes too much since to do a disc brake kit now and replace tie rods and ball joints. I'm still looking to see where I want to get a arm bushings from. I got the driver side bag mounted and mocked up.
The next big question is where I should mount the tank and compressors, my plan for under the truck won't work. Not enough room. I'm thinking behind the passenger seat against the wall.
1968 GMC P-10
Old 10-23-2014, 12:14 AM   #48
P10-001
P10-001's Avatar
I like the shifter!
Do you think it's too far back?
1968 GMC P-10
Old 10-26-2014, 08:39 PM   #49
240zdogg
I like the shifter!
Killer job on the front end,and the air ride....im next.
The shifter is a little offset to the rear a bit more then stock, its the T5 chevy S10 with the spacer plate so i had to flip the bend forward to offset it forward a bit.... it worked out just fine. Im adjusting my seat back a bit do to the steering wheel is a bit high for me, but not now.
Next week, im going to get my fabric for the seats and paint them before i install.... pics soon.
Old 10-26-2014, 08:52 PM   #50
240zdogg
BTW: Guys and Gals, im going to sell my wheels/rims now via "selling forum". check them out, im selling them what i think is cheap cuz 1 has a very very small lip ding (in pic) and there 5 lug chevy patten, i have a 6 lug on my P10 and i like the 6 lug over the 5 lug and have no need for these wheels.
