Old 12-10-2014, 07:20 PM   #26
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Got the air bags mounted today. The truck now can go up and down and roll on 4 wheels umm I mean 6 wheels
I'll get a vid soon
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 12-10-2014, 08:21 PM   #27
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: My 52 GMC Build
Looks very nice!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 12-16-2014, 12:42 PM   #28
05snopro440
05snopro440's Avatar
Re: My 52 GMC Build
Originally Posted by alaska gasser View Post
Not throwing any rocks, but I'm wondering if that 4 link is going to work properly and safely with the upper bars at that angle instead of straight above the bottom ones?
Originally Posted by lower50's View Post
No worries. Its a double triangulated 4 link, its used to keep the axle centered in the frame more. 4X4's use it in extreme. I had to use it due to my limited space and not enough angle left and right. Didn't want a pan hard bar. I talked to the shop that shortened my axle. The only down fall is it increases the height of my roll center. The truck will lean in the corner more but i figured with a 1000 lb motor up front I don' think the back will do much.
Triangulated 4-links are more forgiving for install and geometry as well. They're fairly popular in hot rods too, not the double triangulated as yours is but just the top bar. Your setup looks good, I am excited to see more of this build.
My 455 Buick powered '46 GMC Build Thread
My '46 GMC on Photobucket
05snopro440 is offline   Reply With Quote
Old 12-17-2014, 10:59 PM   #29
WIDE LOAD C-30
Re: My 52 GMC Build
What a cool build. I own an AD and a '94 factory turbo IDI crew cab dually. My F-350 has a 90cc injection pump, BB code injectors, waste gate adjusted for 15psi(on the stock head bolts and 216,000 mile head gaskets), Hypermax cowl induction with a K&N air filter, Banks down pipe/EGT+boost gauges and 4" straight pipe side exhaust.
What turbo is that?
What other mods got done to the E4OD?
Whats plans do you have for fueling?
A cam swap would be real easy right now.....google R&D IDI Performance.
'55 3100 1st Series
WIDE LOAD C-30 is offline   Reply With Quote
Old 12-18-2014, 09:57 AM   #30
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Got the frame and axle painted. Starting to look like a truck
Thanks Wide load c-30. Its a HX35 from a cummins. I found its a good size for what I'm doing. I'm running 3" mandrel bent sst out the side. I have an electric 35 gph fuel pump. Other than that I'm just turning up the lift pump. For the trans I put in a Transgo tugger kit. It was rebuilt about a year before I got it. I'm also using a US Shift Quick 1 controller that allows me to control anything the trans can do. Its going to be manual shift auto. I've looked into a cam but I want to see what the stock set up will give me first. My goal is 300hp and 500lb-ft if I get close to that I'll be happy, but who knows down the road I may do a full motor build.
1951 MG TD
Old 12-24-2014, 01:12 AM   #31
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Amazingly my steering shaft missed the motor without any major mods. I moved the end if steering column over to the drivers door 1.5" and am going to center the column between the gauges.
1951 MG TD
Old 12-29-2014, 01:33 PM   #32
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Finally got a vid put together, showing what I have done so far and motor running. Enjoy
http://youtu.be/N0C3SOCJPCA
1951 MG TD
Old 12-29-2014, 02:13 PM   #33
Daze57
Daze57's Avatar
Re: My 52 GMC Build
very nice work so far -- it should be a awsome ride when done !
Daze57 is offline   Reply With Quote
Old 12-29-2014, 03:34 PM   #34
Dieselwrencher
Re: My 52 GMC Build
Great work! The engine really sounds nice and it looks way easier to work on than any other turbo'd IDI!
Ryan
Old 12-31-2014, 04:23 PM   #35
1948GMC
1948GMC's Avatar
Re: My 52 GMC Build
I like it if I had the money I would go diesel as well
1948GMC is offline   Reply With Quote
Old 01-06-2015, 11:43 AM   #36
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Got steering column mounted just before Christmas.
Working on putting the lower cowl back on and then on to fenders, but its slow going right now really cold here 10F feels like -6F not much heat in garage. A bit warmer next week.
1951 MG TD
Old 01-06-2015, 11:48 AM   #37
lower50's
lower50's's Avatar
Re: My 52 GMC Build
I wanted to do something different!! Got a really good deal on the whole drivetrain, could not say no.
1951 MG TD
Old 01-13-2015, 01:50 AM   #38
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Well got the one cowl tacked on. Then got the fender modified. I cut 3" off the bottom because I'm rising the running boards and first test fit. WOW haven't seen the fender in it in about 8 years.
1951 MG TD
Old 01-18-2015, 12:30 AM   #39
71'tahoe
71'tahoe's Avatar
Re: My 52 GMC Build
Cool build!!
71'tahoe is offline   Reply With Quote
Old 01-18-2015, 06:36 PM   #40
CodyHicks
CodyHicks's Avatar
Re: My 52 GMC Build
Dope
CodyHicks is offline   Reply With Quote
Old 01-19-2015, 10:29 AM   #41
hotrodelrod
hotrodelrod's Avatar
Re: My 52 GMC Build
Definitely a cool, original build! I'm in!
hotrodelrod is offline   Reply With Quote
Old 01-19-2015, 11:00 PM   #42
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Got front end bolted together for the first time in about 9 years. I'll Have some more pics in a few days.
1951 MG TD
Old 01-20-2015, 07:01 PM   #43
sparks54
sparks54's Avatar
Re: My 52 GMC Build
Great job. The truck is looking pretty cool. I can't wait to see some future picture... Keep them coming!!!
QUARTER TURN BEFORE IT SNAPS.....
1954 Chevy Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=584702
sparks54 is offline   Reply With Quote
Old 01-20-2015, 07:06 PM   #44
lower50's
lower50's's Avatar
Re: My 52 GMC Build
More pics all the parts are fitting together really well!!
I had to trim a hole into the inner fender to fit the power steering pump. Made it just big enough to fit, I'm thinking I'll cut it bigger and make a cover on the inside
Now I'm working on a frame cross member to hold the grill. It's just kind of in place now.
I also figured out how big and where the rad is going. Looks like in front of rad support and will go down between frame rails. Then the inter cooler will go in front of that just behind the grill.
1951 MG TD
Old 01-20-2015, 07:41 PM   #45
ghettoluxury
ghettoluxury's Avatar
Re: My 52 GMC Build
It's coming together nicely.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 01-20-2015, 09:36 PM   #46
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thanks everyone. I'm glad you all like what I have done so far.
1951 MG TD
Old 01-23-2015, 06:58 PM   #47
lower50's
lower50's's Avatar
Re: My 52 GMC Build
So here is the front frame horns cut off ready for the cross member.Name:  IMG_6333.jpg
This is the cross member I made. It's 2X4 1/8" wall, then the grill will bolt on top of the lower part and bumper to the sides of that.
1951 MG TD
Old 01-23-2015, 07:03 PM   #48
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Here is the grill bolted on. Still have to do some front end adjustments to fix the grill gap.
I bolted on the visor so I can get a good look at it with all the parts on.
Looks so sweet
1951 MG TD
Old 01-23-2015, 07:05 PM   #49
lower50's
lower50's's Avatar
Re: My 52 GMC Build
The mail man brought me some goodies today!!!!
1951 MG TD
Old 01-26-2015, 07:20 PM   #50
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Made some brackets to mount the bumper. I wanted it tucked in a bit from stock and on the ground.
Still have to put the splash apron on
1951 MG TD
bagged, build, diesel, gmc, hot rod
