12-20-2014, 10:12 PM | #26 |
Re: 5 speed LS 72 Blazer build
What are you? Some sort of painter? This is not your first rodeo. Nice truck! No rust at all? What a great start! Gonna be beautiful if this keeps up which I'm sure it will.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
12-22-2014, 11:29 AM | #27 |
NO, I know my limitations! I work on a lot of insurance rebuilders, and I have a really good paint guy that takes great care of me. He did all the work, but let me closely supervise the project. I just saw the hood and top completed the last couple of days, and they look fantastic.
12-22-2014, 11:37 AM | #28 | |
The Dirty Dingo mounts and cross member kit were a life saver. got the motor mounted last night. it fits perfectly. I'm super excited that I can now move on to the rest of the build knowing that is done and done right. Thanks for turning me that direction! I would highly encourage anyone working on a similar build to use Dirty Dingo; they shipped fast and were super friendly. As I was assembling the cross member, I couldn't help but think I got quite a bargain, too. I am going to have to relocate my A/C compressor , but DirtyDingo sells a mount kit and compressor that I will probably use when that time comes. There are other, more important things to get done first! |
12-28-2014, 07:39 PM | #29 |
Nice supervision I really like the color. I am also putting a 1999 5.3 LS motor and tranny in my 72 Jimmy. I used motor mounts from Pacific Fab there installed and looks good. I bought the adapter to use the 4 speed automatic from the donor. The exhaust manifolds from the 99 have clearance issues with the frame I picked up a set of a GTO they hug the motor closer so the frame does not have to be modified.
12-30-2014, 12:49 AM | #30 |
Motor in and mounted! Now on to tranny cross member. Any of you guys have any experience using the factory cross member with the bracket /mount on the NV4500? My second picture is of the crossmember. Notice the 2 holes. They are too wide and too big to use them as bolt holes for the tranny mount. I was just going to have them welded shut and drill new holes. Any other suggestions?
12-30-2014, 12:55 AM | #31 |
That is an exhaust manifold bolt broken off in the head, with an easy out broken off in it. What do you all recommend for getting that out?
On another note, I haven't tried mounting exhaust manifolds back to the motor yet, buy several guys have told me that they won't fit without notching the frame-which I won't do, or changing manifolds to some from the GTO or Camaro/firebird. Anybody have experience with this? |
12-30-2014, 01:44 AM | #32 |
You can drill it out and use a Time-sert.
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
12-30-2014, 08:09 AM | #33 |
I have heard that the Trailblazer manifolds work well without mods. I hate easy outs! I would load that engine up and just let a machine shop take care of that. Lord knows "I" would just make it worse. Take the x-member too.
Nice progress BTW!
12-30-2014, 12:43 PM | #34 |
2WD Jimmy
It will be very difficult to drill out that tap (tool steel). This is what I did. You can see the broken tap. I placed a nut over the broken tap and built up some .040 tig rod inside the nut. It backed right out.
12-30-2014, 03:45 PM | #35 |
Thanks for the idea, Tom. Since my bolt is recessed into the hole, is there any way to keep the weld from adhering to the hole? I'm not much of a welder, but it seems to me that this method wouldn't work for me because any weld that I put in would stick to the sides of the head inside the hole. Please correct me if I'm wrong.
12-30-2014, 08:34 PM | #36 |
Registered 1971 K5
Came out really nice!
What Blue is that? |
12-30-2014, 09:00 PM | #37 |
12-31-2014, 10:30 AM | #38 |
Aluminum head so it won't stick, it will be tricky to get adequate penetration without damaging aluminum. When steel and aluminum corrode together (electrolysis) it is very difficult to separate. Take your time, good luck. Tig would help a bunch, might be able to catch just the tap and then be able to drill bolt.
12-31-2014, 10:54 AM | #39 | |
2WD Jimmy
It might take a couple of tries but you can do it no problem with a tig. Btw... you cant weld to the aluminum, and the aluminum is unlikely to melt as it is a huge heat sink. |
12-31-2014, 12:07 PM | #40 | |
01-01-2015, 10:56 AM | #41 |
2WD Jimmy
01-07-2015, 10:17 PM | #42 |
I could do it with a baby MIG, I have done several with my little 135. Just make sure you weld straight in 90 degrees to the head.
Weld won't stick to either the Alum. or Cast....... On Cast it works really slick. |
01-08-2015, 01:32 AM | #43 |
Thanks for the idea, Pat. Since I don't have a welder and none of the other options seemed viable, I just decided to pull the heads off and have that bolt removed at the machine shop. An expensive fix, for sure; but at least I know I don't have to worry about head gaskets, valve cover gaskets, or intake manifold gaskets going out!
01-09-2015, 12:39 AM | #44 |
While waiting for my heads to come back from the machine shop, I decided to start working on the fuel delivery system. I've had several guys tell me that I need a high pressure(at least 50-60 PSI capable) in-line pump to go along with the fuel filter from a 2003ish Corvette-it has a return and therefore built in pressure regulator, so I've been told.
I'm looking for a quality pump capable of doing what I need it to without breaking the bank. Any suggestions? |
01-15-2015, 03:17 PM | #45 |
Looks like we'll get heads back on this weekend and t-case mounted to trans. Should also finish up the fuel delivery system. 2 items remain before I will start it up! First, a wiring harness- I would prefer to find a stand alone, but I don't want to break the bank. Second, exhaust; my truck manifolds won't fit with my frame, so I need to find some from a GTO, Trans AM, Z28, Vette, or even Trailblazer SS. Anyone know of any available for a bargain?
01-21-2015, 11:38 AM | #46 |
Nice looking rig! looks like you're moving right along. I kinda miss building mine, time for a new build I guess!
Blazer Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=483399 |
01-27-2015, 07:37 PM | #47 |
I had good luck at a junk yard, was able to get a set of corvette manifolds, but they interfered with the motor mounts. $100.00 and I exchanged for a set of GTO manifolds with the heat shields.
01-28-2015, 02:02 AM | #48 |
Thanks for the heads up. I found a set from a trailblazer SS that fit quite nicely-- got a steal on them, too: $80 for manifolds, cats and Y pipe.
01-28-2015, 02:06 AM | #49 |
Among the next challenges! I have to figureout how to modify my cross member or use w different one, in order to allow the front drive shaft to clear. I can almost hear this thing running, but there is plenty left to do before it goes on the road!
01-28-2015, 11:18 AM | #50 |
Looks like a fun build!
* Call me NOT the website number* Justin Novick (773) 303-8251 Sales/Support Entropy Radiator / Engineered Cooling Products "The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com |
