Old 11-20-2014, 11:06 PM   #26
Daaaanz67
Re: Checking interest in a bolt in DBW Pedal bracket
That looks good I have an 06 pedal but its plastic. It came out of a tahoe. This should work for my style?
Daaaanz67 is offline   Reply With Quote
Old 11-20-2014, 11:21 PM   #27
Hart_Rod
Hart_Rod's Avatar
Originally Posted by jessemthompson View Post
I have to check my pedal while on home on leave next month. If it works, I am definitely in for one.
Ok. LMK.
Originally Posted by Houston Ben View Post
Looks good Rob, I hope you get one for the Squarebody!
I think so. Can you post a picture of your pedal?
Hart_Rod is offline   Reply With Quote
Old 11-21-2014, 11:36 AM   #28
KEWLKATDADY
Just to verify that this is going to work for my application.
I'm putting a 6.0l into my '67 c10. The motor and DBW truck pedal I'm using is from a 2004 2500HD.
1967 C10 custom
KEWLKATDADY is offline   Reply With Quote
Old 11-21-2014, 12:02 PM   #29
Hart_Rod
Hart_Rod's Avatar
It should. Please post a picture of your pedal so I can verify it's the same as the pedal I used to mock this up.
Old 11-21-2014, 01:01 PM   #30
kitsbeach
kitsbeach's Avatar
Rob which do you like the look of better the corvette or the truck pedal? Is the corvette one more similar to our stock 67-72 look.?
I'm interested but probably a year away.
Kitsbeach (Ken)
1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills"
kitsbeach is offline   Reply With Quote
Old 11-21-2014, 01:54 PM   #31
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I have a different style pedal....the all plastic (truck?) one. Since my setup is also genIV, will this work with the pedal I have or would I need something different?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 11-21-2014, 02:29 PM   #32
Hart_Rod
Hart_Rod's Avatar
You can use the stock 71-72 pedal pad on either DBW pedal. I like the way Corvette pedal mounts better. Unfortunately you can only use the Corvette pedal with Gen IV motors.
If your motor is a Gen IV, you can swap to the 05+ corvette pedal and use my other bracket. You just have to swap 2 wires on the pedal plug. Please post pictures of your pedal and the pedal plug.
Old 11-22-2014, 01:06 AM   #33
Daaaanz67
This is my pedal I used the bracket that came with it all I had to do was bend the bottom portion of the bracket to match the angle of the floor and used some spacers behind the bracket and the fire wall. The pedal is a little high but is lower than the brake pedal. It functions very well. Still interested in your bracket.
Old 11-22-2014, 12:05 PM   #34
Hart_Rod
Hart_Rod's Avatar
I'm pretty sure you can switch to the 05+ corvette pedal and use the pedal bracket that I have in my gold 68. You'll just have to swap 2 wires. Do you have a separate TAC module?
Look at this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=631165
Old 11-22-2014, 02:07 PM   #35
Daaaanz67
Yes it's separate from the main ecu.
Old 11-22-2014, 02:11 PM   #36
Daaaanz67
Gen III motor out of 06 tahoe
Old 11-22-2014, 03:51 PM   #37
Hart_Rod
Hart_Rod's Avatar
Interesting. The plug looks like the flat plug for the gen IVs. Could u post a couple more pics of just the plug?
Old 11-22-2014, 08:51 PM   #38
Daaaanz67
Which end plug did you want to see. I actually have the vin that came out of the ecu identifying the vehicle it came out of. Bought everything as a package deal from a private sale. Didn't have to piece anything together. I did have to buy a tac. Module but used the vin and worked perfect.
Old 11-23-2014, 11:16 AM   #39
Hart_Rod
Hart_Rod's Avatar
The end and the side, just curious. Since its a Gen III, you won't be able to switch to the corvette pedal. I'm sure my bracket would work, but I would leave the pedal mounting holes blank so you can position it as you see fit. LMK.
Old 11-24-2014, 10:09 PM   #40
Hart_Rod
Hart_Rod's Avatar
OK guys. I ordered 10 of these from my machine shop. Price is $60 shipped. Let me know if you want one and I'll add you to the list at the top of the page.
Old 12-03-2014, 11:25 AM   #41
Hart_Rod
Hart_Rod's Avatar
Started a for sale thread over here:
http://67-72chevytrucks.com/vboard/s...d.php?t=651123
Old 12-13-2014, 10:28 AM   #42
Hart_Rod
Hart_Rod's Avatar
5 brackets left.
Old 12-19-2014, 06:54 PM   #43
Hart_Rod
Hart_Rod's Avatar
bump
Old 12-21-2014, 01:27 PM   #44
Willie Makeit
Willie Makeit's Avatar
had the chance to see one of your brackets installed last night. Great fab work and even greater engineering. Looks and works AWESOME!
Two thumbs up!
Willie Makeit is offline   Reply With Quote
Old 12-21-2014, 04:13 PM   #45
Hart_Rod
Hart_Rod's Avatar
Two thumbs up!
Glad you like it! Please post pictures if you have any.
Old 12-28-2014, 01:45 PM   #46
zacthrasher
zacthrasher's Avatar
Are the 04 and down corvette pedals similar to the 05 and up pedals? I have a gen 3 motor for my 67 and was wondering if you ever test fit the older corvette pedals.
Thanks in advance!
My 67 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=473825
zacthrasher is offline   Reply With Quote
Old 12-28-2014, 02:10 PM   #47
Hart_Rod
Hart_Rod's Avatar
Thanks in advance!
Can you post a picture of the pedal? What motor do you have?
Old 12-29-2014, 11:46 AM   #48
Houston Ben
Houston Ben's Avatar
Any progress on the squarebody one?
Houston Ben is offline   Reply With Quote
Old 12-30-2014, 01:20 PM   #49
Hart_Rod
Hart_Rod's Avatar
Not yet. I thought there would be more demand for the 67-72 one. Not sure how much demand there will be for the squarebody. Might not be worth making them.
Old 01-09-2015, 09:21 PM   #50
jessemthompson
Here is the pic of my pedal. Idk if your bracket with work for it.
jessemthompson is offline   Reply With Quote
