Old 11-11-2014, 11:56 PM   #26
nheller76
nheller76's Avatar
Re: 1978 chevy bent frame NEED HELP.
I Just changed my steering box and it helped with that problem. It may just be jammed up in the box but its not a huge $ part and its a good project to cut your teeth on. This is a great place to ask questions on how to do it. I got my part from Rock auto, it was a reman of the exact same box that was in my truck.
Faith and Patience with my truck, that is what i pray for every day!
See my build http://67-72chevytrucks.com/vboard/s...d.php?t=580013
nheller76 is offline   Reply With Quote
Old 11-12-2014, 10:35 AM   #27
frankenglide
I just want to make an observation here. Im not exactly sure what "re centered" means. If this truck took a hard enough hit to recenter the the steering then I believe you would have to have a badly damaged/twisted shaft or pinion gear in the box. Until I understood the extent of the damage I wouldn't drive this truck anywhere except to the shop. I hope I'm wrong. Just my .02. Stan.
frankenglide is offline   Reply With Quote
