Old 05-16-2016, 10:38 AM   #26
solidaxel
solidaxel's Avatar
Re: 1987 Fuel Sender Conversion for LSx Swap
I used AN fittings also but I silver soldered steel AN fittings to both ends of the fuel system, 87 pick up tank and return fuel system
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 07-01-2016, 01:41 PM   #27
lowrodderchev
lowrodderchev's Avatar
for you guys that used the 87 sending unit will any gauge work with it? I did this on my 75 blazer I need to replace the gauge but wasn't sure if I could just keep the 75 gauge or do I need to get a 87 gauge
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 07-01-2016, 03:12 PM   #28
aggie91
I'm just glad to be here!
aggie91's Avatar
I am not 100% sure, but it should. I think that the 87 and 75 gauges use the same resistance range. I know that my 84 gauge worked with the 87 sender....
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 07-01-2016, 04:11 PM   #29
solidaxel
solidaxel's Avatar
The 87 sender worked n my 78 also, the old one was busted for 20 years !
LS 3 4L70E
Old 07-01-2016, 04:15 PM   #30
lowrodderchev
so you were ok running a 78 gauge to a 87 sender? classic parts is having a 10% off sale I'm going to order a new gauge save me like $5 or $6
Old 07-01-2016, 06:44 PM   #31
72MARIO
72MARIO's Avatar
The Gm fuel gauges were all 0-90ohm till mid 1990s you shoud not have any problems with the fuel gauge
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 07-01-2016, 08:57 PM   #32
solidaxel
solidaxel's Avatar
Well I haven't run out of gas yet!!
I no longer have to put gas in the truck every 100 miles
The LS gets better mileage, but now I do not have a speedometer, I like the fuel gauge better!
LS 3 4L70E
Old 07-01-2016, 09:00 PM   #33
lowrodderchev
LOL same boat but ive been using a GPS app on my phone. thanx for the help
Old 08-26-2018, 06:46 PM   #34
Joe69C10
Joe69C10's Avatar
Bringing back an old tread! Great write up. This will help me alot. Question: You are using the corvette style filter w/ return that you can mount near the tank. I'm swapping a truck 5.3 with the return already on the truck intake.
Would I just use a regular filter that is not a return style? and run two long fuel lines from the intake? Since the truck intake has a regulator built in along with return.
Joe69C10 is offline   Reply With Quote
Old 08-26-2018, 11:02 PM   #35
Jstock85
this will definitely help me as well. Aggie91 did you ever find out if the purple went to the gauge and grey went to power or vise versa?
Jstock85 is offline   Reply With Quote
Old 08-27-2018, 12:40 PM   #36
aggie91
aggie91's Avatar
This was set up for the return style lines on the intake. I did not use the corvette style return filter.
I just ran two -6 lines from the tank up to the rails. One for supply and one for return. That set up worked with a pump upgrade to a Walbro 400 style pump and made over 515 ft lbs of torque before blowing a head gasket...
Karl
The LST Challenge:
Old 08-27-2018, 12:43 PM   #37
aggie91
aggie91's Avatar
Gray is power to the pump.
Purple is the sender wire to the gauge.
Karl
The LST Challenge:
Old 08-27-2018, 01:56 PM   #38
Jstock85
Cool. Thank you! Did you cut the plug off and solder wires?
Old 08-27-2018, 03:14 PM   #39
Jstock85
Grey to the wire going to the fuel pump relay and purple to the fuel gauge?
Sorry meant to put that in the other post...
Old 08-28-2018, 02:12 PM   #40
aggie91
aggie91's Avatar
Yes.
For the plug, I got the matting connector and pins and put that together on the wires going back up front to the cab area.
Karl
The LST Challenge:
Old 08-28-2018, 04:39 PM   #41
Joe69C10
Joe69C10's Avatar
Yes, purple to fuel sending unit for gauge and grey to power fuel pump. Purple is typically the sending wire color on alot of GM's.
I would look for the plug so you can just plug it into the fuel pump. My friend was able to buy one through Autozone I think?
Old 08-29-2018, 08:23 AM   #42
Jstock85
Ill do that Joe. Thanks
Old 08-31-2018, 09:53 AM   #43
Jstock85
Do you know where I could get that plug from? Brand? PN? What that plug is called? That sort of thing.
Old 04-05-2019, 09:02 AM   #44
72GreenMonster
72GreenMonster's Avatar
Aggie91
Great post and thank you.
I will be running this exact setup
Questions all answered.
Everyone on this site contributes!
So Thanks Again
72 GMC Sierra 2500
72GreenMonster is offline   Reply With Quote
Old 04-08-2019, 09:19 AM   #45
aggie91
aggie91's Avatar
You are more than welcome!
I will be doing this same thing again this summer on another '84. Only twist will be this one is running dual tanks, so I will need to update the selector valve and those hoses too.
Karl
The LST Challenge:
Old 11-01-2019, 11:42 AM   #46
rodstored-72
chevy truck fan
rodstored-72's Avatar
Aggie,
have you moved forward on the duel tanks yet? I am in the beginning process of the same thing. I am interested in how you might/did go about wiring for both tanks so the tanks are not going at the same time?
thanks in advance
rodstored-72 is offline   Reply With Quote
Old 11-01-2019, 02:52 PM   #47
skyphix
Its a 2 pin weatherpack connector... Amazon has them. I'm also going to check my local parts stores for them.
Eric
1980 C10 SWB
2003 Chevy Suburban 2500 LT
skyphix is offline   Reply With Quote
Old 11-04-2019, 06:15 PM   #48
aggie91
aggie91's Avatar
Originally Posted by rodstored-72 View Post
Aggie,
thanks in advance
Summer did not go as planned. Completed the LS swap and only did the one tank. I'm not sure when I will get to the other tank, but I will be posting pics and descriptions on Henry's build thread when I do.
for now, here is the best thread I have found on the subject:
http://67-72chevytrucks.com/vboard/s...d.php?t=754061
Info on the Pollak Selector Valve:
This is the selector valve:
http://products.pollakaftermarket.co...n-valve/42-159
Can handle up to 65psi fuel pressure.
This is the kit they offer that comes with the selector valve, a DPDT switch, the connector for the valve and a switch plate that has main & aux indications.
http://products.pollakaftermarket.co...n-valve/42-300
The link has another link to a installation sheet with a great diagram for installation. the factory wiring and dash switch can be used to control the valve also.
Another good thread starting on Post 129 with pictures of the valves and hoses:
http://67-72chevytrucks.com/vboard/s...=516817&page=6
Karl
The LST Challenge:
Old 11-04-2019, 06:28 PM   #49
aggie91
aggie91's Avatar
Here is a kit with both the male and female connectors and terminals. I think I bought just what I needed from another place.
https://www.amazon.com/Delphi-Packar...905826&sr=8-36
Karl
The LST Challenge:
Old 11-05-2019, 12:22 PM   #50
skyphix
Yep - exactly those. I ended up ordering a set with pigtails so I don't have to worry about buying the special crimping tool or screwing up the crimp (my luck) by using a standard crimper. I got mine from Del-City - service has been good but shipping was a killer. Oh well.
Eric
1980 C10 SWB
fuel pump, fuel system, lsx, swap
