#26 |
Re: 64 c10 build
Did you get the slider mounts? How's the quality on everything? Those are the one's that I've had my eyes on.
#27 |
Re: 64 c10 build
they do slide. Everything seems to be good, except the installation instructions.
You can find me on Instagram @neveno_cten |
#28 |
Re: 64 c10 build
Thanks Rickoner after checking out your thread and how good your floors looked, today as soon as I got home me and "white knuckle garage" started tearing into mine. We got the rockers off both sides. I've have all the patch panels for a few weeks I've just been dreading doing it.. I've kept myself busy doing other things on my truck..
#29 |
Re: 64 c10 build
My Phone won't let me upload more then 1 picture per post.
#30 |
Re: 64 c10 build
Good luck! Been there done that! I'm onto the rockers now. Have to redo the bottom of the doors and acquire fenders before I can do anymore.
#31 |
Re: 64 c10 build
We put the bed on this morning! Just a test fit to check wheel spacing and ride height.. The cab that's on my truck we just put on for the LS motor placement and to get it off my extra frame.. I'm using the extra frame under my cab while we do the patchs on the floor.
#32 |
Re: 64 c10 build
Started cleaning up the firewall. Waiting on the door pillar patchs to come in befor we go any further on the floor. While removing some of the loose paint we discovered some of the original markings 2 tone and beige!
#33 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: 64 c10 build
Those wheels are slick...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#34 |
Re: 64 c10 build
Thanks!
#35 |
Post Whore
![]() Join Date: Mar 2013
Re: 64 c10 build
Looks good!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#36 |
![]() Join Date: Apr 2010
Re: 64 c10 build
Is it going to be bagged or static? If static, how much drop will you be running?
Wade |
#37 |
Re: 64 c10 build
Static for now bags later. 4.5 in the front and 7 in the rear..We'll see how it works. I hoped it would be lower.
#38 |
Re: 64 c10 build
What is the color on your wheels? Looks like an off white.
Wade |
#39 |
Re: 64 c10 build
that is so sick. where'd you get the gm transport wheels?
#40 |
Re: 64 c10 build
The wheel paint is single stage PPG fawn 22425. I bought the wheels at a Chevy dealership.
#41 |
Re: 64 c10 build
Thank you
Wade |
#42 |
Re: 64 c10 build
Subscribed
#43 |
Re: 64 c10 build
We got the floor cleaned up and removed the gas tank brackets without damaging the original paint on the back of the cab. Also got all the holes on the firewall welded up that won't be used on the 5.3 swap and filled the gas filler hole. Still need to patch the floor
#44 |
Re: 64 c10 build
What did the seat come out of?
My build thread General JD or Ole Jack http://67-72chevytrucks.com/vboard/s...d.php?t=632318 |
#45 |
Re: 64 c10 build
They are the rear seats out of a 2010 crew cab f*** super duty..
#46 |
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Re: 64 c10 build
The seat looks super-nice, but no adjustment?
I guess it will be allright if you are the only driver, and it fits you...
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=512904 |
#47 |
Re: 64 c10 build
Thanks!! My bench seat was all the way back and i was good. ...and I may work on an adjustment.
#48 |
Re: 64 c10 build
What brand is the radiator?
#49 |
Re: 64 c10 build
It's made by Entropy its a LSX conversion radiator.
http://www.entropyrad.com/1963-1966-...-radiator.html
#50 | |
Re: 64 c10 build
WOAH!!!! ![]() ![]() ![]() |
