Old 01-03-2015, 12:23 PM   #26
First c10
First c10's Avatar
Re: 68 axle swap and lift
Good morning guys,
I did a little research on the 68 lifting problems. The parts that ORD quoted are just Tuff Country springs nothing out of the ordinary that I can see. Just that the rear are 52" and the front need spacers at the shackles. Other than that the 69-72 lift is the one to use. Tuff country has the lift kit #14612KN. It has the 52" rear springs I will try to measure my rear stock springs today and let everyone know my findings.
Msgross, I looked over your build great job. My 68 frame is not dimpled for a power steering box so I will be going the spacer route and will be updating all the brake lines and installing a new master with prop valve for the 73 front axle I will be installing.
Thanks for the comments
Scott
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 01-03-2015, 03:38 PM   #27
msgross
msgross's Avatar
cool, I remember looking into a lift years ago but wasn't finding many options. My springs were in good shape but the bushings were shot so I just installed poly's, add-a-leaf and ORD longer shackles.
I like the look of a 4" with 33x12.5's though.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 01-17-2015, 01:26 PM   #28
First c10
First c10's Avatar
Hey guys been busy at work.
So I measured the rear leafs and they are 56" in a 68. Must be original because the mounts are riveted in. Anyone else have a 67-68 with 44 front leafs and 56" rears?
GO GO!!!
Old 01-17-2015, 02:03 PM   #29
mud.man.rj
mud.man.rj's Avatar
There sure are a lot of differences from 67-72, a lot of uninformed think all are the same, nice to have the help on this site, sure makes a difference for a build.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 01-18-2015, 12:00 PM   #30
It seems whoever I buy springs for a 69-72 truck from, they always ask 52" or 56". I always wondered what trucks got 56" because mine have always been 52". I had 56" Tuff Country 4" EZ-rides on my '91 Suburban. They definitely have a spring for you. Those would bolt right up. I sold mine to a member for his 69-72 Blazer that he was going to move the brackets back on, for a better ride and/or off road flex
Old 01-18-2015, 12:26 PM   #31
First c10
First c10's Avatar
From what I found from talking to the lift companies the 56" were on the k20 trucks and suburbans but rare on k10 trucks. My guess it's because it's a lwb truck. Also when I talk with the lift companies they all say the 69-72 kit will fit the front of the 67-68. So my question is why don't they say it in there discriptions instead of 69-72? Confusing!
GO GO!!!
Old 01-18-2015, 02:42 PM   #32
msgross
msgross's Avatar
spring width I think...
The Garage:
Old 01-18-2015, 03:15 PM   #33
whtgmc68
whtgmc68's Avatar
When I installed a 6" lift to my 68 LWB, I woulnd up calling Sky Jacker and giving them my factory leaf spring lengths and they sent me a full set of Soft Ride springs. The rears bolted right in but the fronts required the use of a 6" rear shackle. The longer shackle made the front a little higher than the rear so I installed an add-a-leaf in the rear and now the stance is perfect. I can't remember the part numbers that were on the springs since it has been 4 years since I did the lift.
I would think they could do something similar for a 4" lift.
whtgmc68 is offline   Reply With Quote
Old 01-18-2015, 06:45 PM   #34
msgross
msgross's Avatar
zero rate springs from ORD are also a good way to get 1" of lift, and you can move the axle back to center in wheel well, while not changing ride comfort.
The Garage:
Old 01-18-2015, 06:55 PM   #35
First c10
First c10's Avatar
My front spring width is 3" and of course tapers to 2.5"and the axle than back to 3". All the people I talked with say just add a thick washer or get bushings with thicker shoulders to make up w difference for the width.
I have an email into suspension connection in regards to getting a kit with the correct length rear springs and front bushing widths.
GO GO!!!
Old 01-19-2015, 02:59 AM   #36
argonaut
argonaut's Avatar
Today I measured the rear springs on my Dad's 68 GMC C10. Springs were 52" long, with the center pin located 24" from the front eye and 28" from the rear eye. They measured 2-1/4" wide.
I'm not 100% sure but I'm assuming that these would be the same as K10 rear springs.
Maybe this will help with something.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 02-20-2015, 02:53 PM   #37
First c10
First c10's Avatar
*Update to this thread*
I ended up calling Tough Country and they instructed me to call Suspension Connection(which I found out later is directly across the street from TC). They said that they don't have a package with 56" rear springs but to call SC and they could make the change from the 52" to 56" they also were able to remove the steering arm from the package and not charge me the difference in the bigger springs as I didn't need the raised steering arm because I had a dropped pit-man already. The package was delivered yesterday and thought I would updated this thread... I also started a build thread .
http://67-72chevytrucks.com/vboard/s...d.php?t=659275
GO GO!!!
Old 02-25-2015, 11:43 PM   #38
First c10
First c10's Avatar
In case anyone wants to know what I ordered to lift the 68 k10. Well it's not installed yet but it is ordered. Page 1
GO GO!!!
Old 02-25-2015, 11:43 PM   #39
First c10
First c10's Avatar
Page 2 of 2
GO GO!!!
Old 02-26-2015, 12:47 AM   #40
mud.man.rj
mud.man.rj's Avatar
Good for you, exciting cool parts are coming. I ordered ner rims and tires for my 86 4wd, but 6 weeks for all of it, hard to wait that long, $3,500 total. Will be nice to see pic's when you get it installed.
5.0 4spd std.
7" lift w 35's.
