Old 01-03-2015, 09:53 PM   #26
1969Chev
1969Chev's Avatar
Re: Trac bar question... Help!
Ive been waiting for almost 3 months for they to send me the extra stuff i need for the bar.
Originally Posted by Stranny64 View Post
Yeah, that bar isn't right. I have there tech peoples number if you want to shoot me a message.
1969 CST/20 396/TH400 Tach Posi
1969Chev is offline   Reply With Quote
Old 01-03-2015, 10:10 PM   #27
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
Originally Posted by 1969Chev View Post
This is how my bar was sent to me
Looks like you are missing a bolt , a rod end ,jamb nut a shim for the left side trailing arm and a bracket for the right trailing arm.
Those parts are usually packed very tightly at one end of the box and they don't fall out when you turn the box upside down.
I had a customer call me and said he was missing those parts also and I had checked it before I sent it to him. He went back and checked the box and they were stuck in the bottom. ..... Just a thought.
ksbrktracer is offline   Reply With Quote
Old 01-04-2015, 12:21 AM   #28
1969Chev
1969Chev's Avatar
I have the bracket and shim and bolt and nut. But what im saying is that they didn't send me a complete trac bar.
Old 01-04-2015, 11:55 AM   #29
ksbrktracer
TNT-MOTORSPORTS
If you got all of the stuff above , sounds like they may have shorted you a rod end. I can see if I can get you one. I am placing an inventory order on Monday.
Looks like you may be missing the bushing also.
Also that is the bent bar for the big rearend cover.
Old 02-20-2015, 03:28 PM   #30
Stranny64
Stranny64's Avatar
Re: Trac bar question... Help! UPDATE!
Hello, I have a update. Mario from CPP had a wider trac bar mount made for me. They sent me the prototype and I test fit it and painted it. It was just a tick tight to go on, nothing a hammer couldn't help with. The bar itself did not line up. I ended up cutting the bar apart in a couple places, beveling the ends, lining it all back up, re welding it, and painting it. Not sure if the stock mounting bracket location is the same on a c10 as a c20, but it works now. Here is a pic.
Thanks again to CPP and all of you for helping me out!!!
1968 Custom Camper C/20, rebuilt original 327 with 350 hp., turbo 400 with shift kit, factory AC truck, original patina rust free paint from Oregon, 2/4 lowering springs + 1" blocks, GM 2500 8 bolt rally's with dually center caps with Firestone Destination 245/75-R16's. (My 50th birthday present from my wife!!!)
Stranny64 is offline   Reply With Quote
Old 02-20-2015, 03:29 PM   #31
Stranny64
Stranny64's Avatar
Pic
Old 02-20-2015, 03:29 PM   #32
Stranny64
Stranny64's Avatar
Pic 2
Old 07-31-2016, 01:04 PM   #33
crakarjax
crakarjax's Avatar
For my C-20 I ended up chopping the bottom off and turning it into gussets for the sides, should be plenty strong. I didn't realize that CPP would make a custome bracket, that's cool! They still don't offer it as a real option or mention it on their site/catalog though. If your C-20 is like mine, the driver side mount is further forward than a C-10 mount... since my mount is already off I'm going to switch to a C-10 mount. It looks like CPP hadn't investigated the C-20 options at all while designing this. A heim on one end would facilitate both mount styles.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
