Old 01-10-2015, 06:50 PM   #26
rusty76
rusty76's Avatar
Re: My suburban's Twisted Little Sister
I'm along for the ride.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 01-10-2015, 08:45 PM   #27
reaper71
reaper71's Avatar
I'm really liking the frame your doing!!
nice work..
Mark...
reaper71 is offline   Reply With Quote
Old 01-11-2015, 02:01 PM   #28
65sub
65sub's Avatar
Originally Posted by Free Candy Inside View Post
Nice work. I keep checking on this for progress. It's gonna be sick.
Thanks Free Candy. We're making a bit of progress
Enjoy the ride Rusty
nice work..
Mark...
Thanks Reaper. Building the frame is kind of fun.
Here's Fridays progress. We Tig welded most of the perimeter frame, until we ran out of argon. then we tacked some sub assemblies
Dale
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 01-11-2015, 02:53 PM   #29
hotrod66
hotrod66's Avatar
me 2 this should be interesting
Between saying and doing many a pair of shoes are worn out
hotrod66 is offline   Reply With Quote
Old 01-12-2015, 08:10 PM   #30
65sub
65sub's Avatar
Got a new plasma cutter on the weekend. So today we started by cutting the 90* frame bends into two 45* bends. Then we made a temporary gig to tack the sub assemblies
Dale
Old 01-14-2015, 10:35 PM   #31
65sub
65sub's Avatar
We did a bunch of tig welding and grinding on the sub assemblies yesterday. Today we clamped the front corners in place then tack welded them
Dale
Old 01-14-2015, 10:48 PM   #32
Free Candy Inside
Killer work
Free Candy Inside is offline   Reply With Quote
Old 01-15-2015, 10:53 PM   #33
65sub
65sub's Avatar
Thanks rusty
nice work..
Mark...
Thanks reaper Frame work is fun
Thanks for following hotrod
Killer work
Thanks Free Candy I am watching your cool panel build as well
Today we started modifying the front crossmember. First we made a 1/4 X 2 plate with two nuts welded to one side. Welded it to the mounting point for the frame. Then we started cutting the 2X4 frame section
Dale
Old 01-15-2015, 11:05 PM   #34
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Great build you have going on. Its probably to early to tell but how do you like the versa cut 60? I have been looking at it for awhile. It had very good reviews.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 01-15-2015, 11:09 PM   #35
Average Joe
Average Joe's Avatar
Very COOL project! Nice work.
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 01-16-2015, 11:43 AM   #36
65sub
65sub's Avatar
Thanks chizzler So far I like the versa cut 60 it cut 1/2 inch like butter. It does need a good ground to work properly Maybe they all do
Thanks Joe
Dale
Old 01-16-2015, 12:02 PM   #37
pimpston65
pimpston65's Avatar
Originally Posted by 65sub View Post
A lot of clamps, a lot of measuring, a little tack welding and we got the perimeter of the frame tacked together. Then we started on some of the sub assemblies
"SUB" assembly? short for suburban assembly hehe, dude this build is by far the most, i don't even know what to say other then AWESOME!!! fast and can corner with the best, heck you can autocross that beast!!!
pimpston65 is offline   Reply With Quote
Old 01-19-2015, 09:56 PM   #38
65sub
65sub's Avatar
Thanks pimpston I'm glad you're enjoying my efforts. I don't know about autocross but I do sometimes think highway speed limit signs are just suggestions
Todays work. First we made an angle bracket to bolt to the crossmember. Bolted everything together and tacked it to the 2X4 tubing. The next step was to start building the transition between the2X6 and 2X4 sections
Dale
Old 01-20-2015, 11:06 AM   #39
reaper71
reaper71's Avatar
looking really good...
Old 01-21-2015, 09:14 PM   #40
65sub
65sub's Avatar
Thanks reaper
Started working on the front frame rail for the drivers side. In the first picture notice the angle between the horizontal and vertical where the frame rail sits. In the second picture we cut a 3/8 strip out of the bottom of the frame rail and two cuts on the side. Then used clamps to bend side. The third picture is the side tacked
Dale
Old 01-22-2015, 08:35 PM   #41
65sub
65sub's Avatar
Today we finished making the drivers side front frame rail. Cut two crush sleeves and welded them in. Last two pictures are with the front frame rails tacked in place.
Dale
Old 01-22-2015, 08:41 PM   #42
pimpston65
pimpston65's Avatar
i see why you called it twisted, with all those "twists" and turns and the frame rails. like i said if you need a shop hand/whipping boy im your guy!!! what thickness on the frame rails are you using!!!
Old 01-22-2015, 08:44 PM   #43
65sub
65sub's Avatar
Picture one is some of the tig welding on front frame. The last two pictures show the rear inside corner tacked in and some plasma cutting on the rear corvette section
Dale
Old 01-24-2015, 12:02 AM   #44
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
cool so far! frame is interesting, but I can't wait for the body mods!
maybe this is what I should do with my 1990 corvette!
Old 01-24-2015, 12:23 AM   #45
Advanced Design
Advanced Design's Avatar
65sub, outstanding project and really love the frame work! Very creative...and a lotta skill there too. I am all in to tag along.
Advanced Design is offline   Reply With Quote
Old 01-24-2015, 09:00 PM   #46
65sub
65sub's Avatar
Pimpston you will see the reason for the frame design when we get to the body modifications. You're not far away, come and have a look. The 2X8 tubes are 1/8 wall, the 2X4 tubes are 3/16 and the curves are 3/16
Thanks Jon Doing the body mods should be a lot of fun.
Thanks A.D. We've had a good time doing this frame.
Friday's work was just welding and grinding on the front of the frame. Here's three pictures of the finished welding
Dale
Old 01-25-2015, 09:00 AM   #47
Fantastic looking work on the frame. Looking forward to following your build.
Old 01-25-2015, 11:03 AM   #48
rusty76
rusty76's Avatar
Awesome work.
My build thread
Crossmembers CC
Old 01-26-2015, 10:13 PM   #49
65sub
65sub's Avatar
Awesome work.
Thanks guys I appreciate the comments.
First two pictures we put the front suspension back together
Next, after some careful measuring we removed the rest of the corvette frame and left the rear suspension on the table.
The last shot is the first two pieces of the rear frame section
Dale
Old 01-27-2015, 05:42 PM   #50
FrankyV8
Man o man this is one awsome build you got going on here! Gonna be following this! Just out of curiosity why you using a Corvette for suspension?
FrankyV8 is offline   Reply With Quote
