Old 01-10-2015, 02:55 AM   #26
argonaut
argonaut's Avatar
Re: '66 C10 5.3/4L60 swap questions...
I'm going to watch and learn from you. Planning a 5.3L swap in my burb next year.
I'm wondering why Gooker said that you shouldn't run under 1/4 tank of fuel if using the stock tank with an inline pump.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 01-10-2015, 03:07 AM   #27
scottybaccus
scottybaccus's Avatar
It's because the lack of a baffle tray surrounding the pick-up tube will result in fuel running away from the pick-up in turns and under hard acceleration. That sucking of air will cause power loss, if not outright stalling, and the frequent air chugging will prematurely wear the pump.
The reason this becomes an issue with efi is that an efi pump runs wide open, delivering enough fuel for max power at all times. The excess during low power needs is directed back to the tank.
Scotty Baccus
scottybaccus is offline   Reply With Quote
Old 01-10-2015, 03:23 AM   #28
argonaut
argonaut's Avatar
Hmmmm, good point. First I was thinking that you could just install a couple of new fittings for supply and return into the bottom of the tank. But that wouldn't necessarily solve the issue. Then I realized you could install a small accumulator upstream of the pump to keep a modest volume of fuel to buffer those extreme lateral-g moments.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 01-10-2015, 03:30 AM   #29
scottybaccus
A bottom sump is most effective, if shaped to limit starvation in corners. Simply plumbing to the bottom of the tank will only result in added risk of debris in the line s, without resolving the starvation.
An accumulator sounds like a good idea, but will actually fail. These pumps are made for pushing, not pulling. Any ingestion of air would lock the accumulator and inhibit fuel lift out of the tank. The air acts as an elastic element, causing fuel to surge and retreat with every pulse of the pump.
Scotty Baccus
Old 01-10-2015, 03:42 AM   #30
argonaut
argonaut's Avatar
Scotty, you certainly have a good point. I have never opened up one of these high pressure pumps to see what type of pump is used. Are they positive displacement or centrifugal? Non positive displacement pumps will not tolerate air pockets and are not effective at pumping air. So i assume that this is what they are. However I believe that the accumulator would work fine so long as you locate it strategically to utilize the effects of gravity and hydrostatic pressure, and do a proper charging of the accumulator and air purge during install. I would mount the accumulator in the frame rail (lower than a stock in-cab tank) to ensure it stayed flooded. Unless of course you ran the tank completely empty...
Anyway, I don't mean to threadjack.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 01-10-2015, 04:22 AM   #31
scottybaccus
You can have a new tank, pick-up and in-tank pump for about $300. Is it even worth the effort?
Scotty Baccus
Old 01-10-2015, 10:26 PM   #32
chris1044
Originally Posted by victorallen View Post
I have no real info here. I'm only posting to say this truck has the perfect stance. Nice build!
chris1044 is offline   Reply With Quote
Old 01-11-2015, 09:36 AM   #33
Mathew21
Mathew21's Avatar
I'm still at the part collecting stage for my 5.3 swap. Do you have a reccomendation on tank, pick up and in tank pump?
Thanks, Matt
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 01-11-2015, 10:22 AM   #34
66LSx
66LSx's Avatar
Thanks, Matt
I went with Boyd Welding thru AZ pro performance... (Always... and only always ask for their sales guy Travis... no bull****-A+-prompt service and followup)
I have absolutely NO regrets on the Boyd Welding tank. one of my better 'spend a little more....get better quality'
The Boyd welding EFI tank comes with the Aeromotive Stealth 340 in-tank pump...... LOVE it... its in-tank.. and is super quiet. My fuel pressure guage hasn't moved off of 58 PSI.... win win and win.
While its a little more... you'll be hard pressed to find a Boyd tank owner thats 'less than impressed'
1966 C10 SWB Fleet
5.3L LM7 Vortec / 4L60e Swap
1966 C10 w/ 5.3L/4L60e Build Thread
2012 GMC Sierra 5.3L 4x4 CCSB
66LSx is offline   Reply With Quote
Old 01-11-2015, 01:25 PM   #35
scottybaccus
Have a look on RockAuto at the '87-'91 Blazer tanks. They come in 25 gal & 31 gal for various years. The dimensions are on the spec sheets linked to the part descriptions.
These have efi baffles installed, and cost under $100. The matching efi pick-up/sending unit will mount the pump in the tank, and cost about $80. I like the Spectra Premium brand for both.
Fuel-Pumps.net, or Tanks Inc., sell a 255 lph high pressure Walbro pump. It should be under $125, delivered, and uses the same install kit as the gm tbi pump that would be in these tanks.
Scotty Baccus
Old 01-11-2015, 02:25 PM   #36
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Originally Posted by 66LSx View Post
I used:
CPP Sheetmetal Motor Mount perches... love them.
CPP Trans Cross Member... worked good
Poly Mounts
Dirty Dingo Engine Mount Sliders.... Love them
Doug Thorley 324y-c headers....love them
Used a boyd welding fuel tank with an aeromotive stealth 340 intake pump
LOVE everything about it... (in-tank so much quieter)
Used a PSI Conversions engine harness (which is modeled after an F-body car)Harness worked great!
Used an entropy LSx radiator
Enjoy... the 5.3L/4L60e in stock form is even a beast
Video #1
Video #2
Looks good ...
Brakes were upgraded too, I hope
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 01-11-2015, 05:05 PM   #37
Mathew21
Mathew21's Avatar
Thanks 66LSx I originally planned on running a Boyd tank. I will wait and see if I can swing it on my budget.
Great information Thanks.
Old 01-21-2015, 10:49 PM   #38
victorallen
victorallen's Avatar
Good information, thank you all. I have a Boyds tank in the orange truck and love it. I had it made to my specs and it turned out perfect. I'm wanting to build the next one on a budget and also as a learning experience so I plan on using a factory style tank if possible.
Argonaut, I appreciate the comments too, the more information and questions asked the better! And thanks Chris1044 for the compliment!
victorallen is offline   Reply With Quote
Old 07-29-2016, 12:19 AM   #39
russellrox
Exclamation Re: '66 C10 5.3/4L60 swap questions...
Originally Posted by TopFuel1966 View Post
Yes the compressor will fit down low without cutting anything as long as you change the connector block to one that's configured like shown in the attached photo......
Where did you get the adapter block in the picture you posted?
russellrox is offline   Reply With Quote
Old 07-29-2016, 03:44 AM   #40
TopFuel1966
TopFuel1966's Avatar
Nostalgia A/C Parts
http://nostalgicac.com/fittings-hose...t-out-644.html
TopFuel1966 is offline   Reply With Quote
Old 11-22-2018, 04:27 PM   #41
Bringit187
I know this is kinda old but how far fwd did the motor have to move fwd on the mounts they have several locations
Bringit187 is offline   Reply With Quote
Old 08-10-2019, 07:46 AM   #42
Ipafrank
I just got a2004 Silverado donor 5.3l LM7/4l60e/m30 to swap out the 250 2sp pg. in my 66 C10 LB
Any helpful tips,info. would be greatly appreciated. Also headers are being installed. Any other engine mods,are in the future.
Was also wondering if the 04 fuel tank /pump can be used.
Would like to replace the split driveshaft as well.
I have the complete 04 crew cab Silverado.
Ipafrank is offline   Reply With Quote
