01-18-2015, 11:00 AM | #26 |
The Older Generation
Re: First LSx swap in progress
Thanks Guys. AD: My wife says I have too many trucks. I told her I didn't know you could have too many trucks.... LockDoc
02-08-2015, 10:14 AM | #27 |
OK, a little progress. I was limited on what I could do for a while because of some minor surgery but I'm back at it. I decided on the Hooker headers and got them ordered. They look good. Painted the firewall and frame and will undercoat the lower part of the firewall today. As soon as it warms up and more of the snow melts I move it outside and pressure wash the front cross member so I can repaint it. I know, I know, why didn't I do it before I put it in????.. Getting closer to setting the engine in... LockDoc
02-08-2015, 09:19 PM | #28 |
Leon, your going to like those Cast Headers. Hoping that surgery wasn't for any thing too serious.
02-09-2015, 11:19 AM | #29 | |
Thanks Ray. I will get your Camaro manifolds back to you. Surgery was just for sinus and nasal passage problems. LockDoc
02-09-2015, 10:56 PM | #30 |
No hurry on the manifolds, I don't have a big use for them. Whenever it works for you.
02-14-2015, 08:36 PM | #31 |
Well, I set the engine in today but I'm not real happy with The POL engine mount frame brackets. The drivers side fits like a glove and all of the bolts dropped right in, but the passengers side is another story. The top bolt holes line up with the holes in the frame but the bracket is a good 1/2" above the frame rail, and the cross member holes don't even start to line up. I'm wondering if I could just cut the piece of tubing off that the long bolt for the rubber mount goes through, bolt the frame bracket to the frame & cross member, lower the engine down with the rubber mount all assembled and then weld the piece of tubing back to the frame mount. That might be the easiest way to correct it. I have the engine in the I-6 position but I may have to move it forward because the large hole in the valve cover for the crankcase vent hose is against the firewall. First two pictures are where I trimmed the frame for the frame mount brackets. Third one is with the engine installed, fourth is the non-fitting frame bracket. LockDoc
02-14-2015, 08:37 PM | #32 |
The Hooker Cast headers fit really good with lots of clearance. In the second picture you can see the outlet in the valve cover close to the firewall. LockDoc
02-14-2015, 10:22 PM | #33 |
wondering why i cant see your "attached images"
02-14-2015, 11:49 PM | #34 |
I've been having the same issue today too.
Engine looks good sitting in place Lockdoc...too bad about the right side mount...one more issue to overcome. |
02-14-2015, 11:56 PM | #35 | |
Try logging off the site and logging back on. I have had the same problem tonight but when I leave and come back they show up. I'm sure it has something to do with the server upgrade that is taking place....
LockDoc
02-17-2015, 02:22 AM | #36 |
Dang Leon, how many trucks are in your fleet? and subbed.
Jack Personal Fleet: Family Fleet: 1955.5 Panel 1959 Apache 1968 ShortWide 1969 ShortStep |
02-17-2015, 02:09 PM | #37 |
I wonder if one side is 67-72 and the other is for a square? Im led to believe a square's frame if 1/2" taller at that point. Me being me, I'd pull 'em both and hacky choppy till I had a matched set.
Also, POR makes a manifold gray that works great. Almost a year on ours, looks like the day they got painted.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
02-17-2015, 11:36 PM | #38 |
Roto Reuter thats the name...
Leon, thanks for the link to your LS swap. I'm going to be doing one as well. I have a lot to learn about the electrical components of these swaps. I'm old school… and this part of it is new to me. I'll be following this one. Nice looking build.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
02-17-2015, 11:53 PM | #39 | ||
I have nine trucks at this time, of those 5 are running driving trucks and I am currently working on two of the others.
Only because you asked.... Quote:
LockDoc
02-18-2015, 07:01 AM | #40 |
It's alsways something.....
Leon, Can you move your engine mounts to that forward hole on the frame?
With the engine position slid back that far, the top of the bell housing may be hitting the pinch weld on the cab floor. Just a thought.
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e |
02-18-2015, 03:37 PM | #41 | |
I probably could. I have about 3/4" between the pinch weld and the top of the trans, the TH350 cross member bolted into the front set of holes in the frame with no problem, and the short TH350 drive shaft I had fit perfectly. I checked all of that stuff out before I drilled the new holes for the mounts. I wanted to keep it as far back as I could hoping that the low mount A/C compressor would clear. I will find out pretty shortly here as I am headed out to try it. LockDoc
02-19-2015, 11:39 AM | #42 |
Well, the A/C compressor fits but it doesn't. It's pretty tight. I am going to check out the aftermarket top mount ones although I would like to keep it low.. Power steering box is bolted in place and connected to the cross link. I need to get the dash painted before I can install the tilt and do the inside wiring loom for the LS. I got the stock under dash wire loom modified, since it was a I6 3ott I had to add a neutral start circuit and rewire the cluster plug from idiot lights to gauges, so it's ready to go back in. I'm going to remove the windshield tomorrow so I can check for rust around it and get the dash ready to paint. LockDoc __________________
02-19-2015, 11:57 AM | #43 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-19-2015, 12:04 PM | #44 |
You don't want to use the F body compressor anyway since it is a variable compressor. It will work, but not great by any means. I wish I had put a Sanden in my Nova when I did the swap years ago, but got cheap and tried the Camaro one. It never worked as well as I had hoped.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
02-19-2015, 04:16 PM | #45 | ||
Thanks, LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 05-12-2015 at 11:54 AM. |
02-19-2015, 04:33 PM | #46 |
Leon, just be aware from the start if you go with the Holley bracket that there is more to buy than just the bracket at $150 or so. The installation kit is another $100 (on my LQ4, there are two major components in the installation kit and one of them you can't use.... grrrrr) Then you have to have a new idler (forgot exactly what that cost but I think it was around $60, then you also have to have a new belt. So, what started off at $150 for the bracket ended up being around $350 when all was said and done. The bracket fits and operates well, but it is expensive. HTH
02-19-2015, 04:37 PM | #47 | |
I have a SD7 compressor in that pictures it's a little smaller than the 508. The 508 will balance you alternator setup a little better.
02-19-2015, 09:31 PM | #48 | ||
LockDoc
02-20-2015, 02:03 PM | #49 |
As it's a 67, are you converting it to later p/s? Wonder if going into an ls swap, and 81-up box/hose would work better? Assuming you know the trick about the big lug on the back of the pump.
02-20-2015, 02:50 PM | #50 | |
I put a '76 PS box on it. I was just going to convert the later hoses to the earlier box. Not sure what you mean about the big lug. LockDoc
