04-14-2020, 08:40 PM | #26 |
Re: HD carrier bearing. The odd one.
I also have a leaf spring C10, but has the horseshoe style center support (like the one Corts60 bought.)
Next time I replace mine, I'm going with this one NATIONAL HB88532. It's 1.378" I.D. and was found on some trucks and vans from 1987 to 2006. Just another option to think about since this one seems heavy duty. |
04-14-2020, 09:46 PM | #27 |
Just here to tinker
That looks legit. I’d like to know what the dimensions are from the mounting surface to center bore. I think the factory one is 3.4375 or so.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
04-14-2020, 09:53 PM | #28 |
Post Whore
Great work.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
04-14-2020, 11:18 PM | #29 | |
I used the same Neapco bearing in my truck and it has been working great.
1969 C20 Customer Camper CST, 396, TH400, Factory A/C, Olive Green. |
04-15-2020, 07:30 AM | #30 |
Post Whore
How long ago did you get it and where did you source it?
04-15-2020, 08:54 AM | #31 | |
Just here to tinker
04-15-2020, 11:42 AM | #32 | |
04-15-2020, 03:45 PM | #33 | |
04-15-2020, 04:05 PM | #34 | |
However if his bracket is riveted to the crossmember (as all, I've seen, so far), that may be easier said than done... |
04-15-2020, 04:42 PM | #35 |
Just here to tinker
Well I got it all back together and went out for a test drive. Success! It is nice and smooth. I even through in a new u-joint at the trans slip joint. If I have to do this again, I will probably try flipping the bracket like you guys suggested. I didn't even look at that while I had it apart.
I hope this thread helps someone out in the future!
08-18-2022, 11:09 PM | #36 |
Awesome. I think I missed your final update on this back in the day. Just wanted to add that this is what is so great about the message boards and the ability to find this info at a later date or even on a search engine and why the Facebook groups are just NOT a good place for tech.
