Old 04-13-2015, 08:35 AM   #26
Advanced Design
Advanced Design's Avatar
Re: One mixed up 51'
Good progress, soon will be a roller.
Advanced Design is offline   Reply With Quote
Old 04-13-2015, 10:37 AM   #27
Coldshot
Coldshot's Avatar
Thanks, I hope to get it there so I can start the body work
Coldshot is offline   Reply With Quote
Old 04-27-2015, 11:12 AM   #28
Coldshot
Coldshot's Avatar
Got the back started on the weekend. Just got the first of two new crossmembers tacked it but it's started non the less.
So one more up a foot or so and some connecting beams between them and I can mock up the back part of the subframe.
Old 05-01-2015, 12:33 AM   #29
Coldshot
Coldshot's Avatar
Ran out of wire again as I was welding up the crossmember. Desided to do some parts cleaning after that and got quite a pleasant surprise.
I washed the IRS finally then did a quick once over with a wire wheel.
Now I knew the upper A arms were aluminum but had no idea they would buff up like that!
Old 05-04-2015, 01:32 AM   #30
Coldshot
Coldshot's Avatar
Got the IRS starting its way into the back this weekend. Had to put that 1 more crossmember in, then made some brackets to bolt to the subframe and lifted it in, centred, levelled and tacked the back ones up.
It turns out I could have had the crossmembers a bit lower but it still works good. I have 2 more cross peace's to go between the crossmembers that will join up with the mounting brakets, then a few gussets for extra measure.
Now into the front mounts!
This peace is still up for debate, still not sure if it looks t bulky? It will work for sure as there will be another on the inside of the frame and then boxed. It won't really be seen so im 90% sold. Feel free to give me ideas for these, nothing to complicated I only have steel plate to work with.
Old 05-04-2015, 02:27 AM   #31
ghettoluxury
ghettoluxury's Avatar
Looking good. You could cut a triangle out of the inside to get rid of the bulky look and still keep the strength.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 05-04-2015, 09:07 AM   #32
Coldshot
Coldshot's Avatar
Thanks, I've thought of that but cuz I'm boxing it water would end up collecting in there. Could put drain holes I guess.
Old 05-07-2015, 12:08 AM   #33
Coldshot
Coldshot's Avatar
Got some more done today. Cut out the mounts and put together the back half, cut out the bit of frame in between for needed clearence. Turns out I had to move it up another 4.5"
Solved the bulky looking peace problem I had tho cuz it's much smaller now.
Old 05-07-2015, 08:16 PM   #34
lower50's
lower50's's Avatar
Very cool build!! I love mixing vehicles. My 67 Jeep is made up of 14 different vehicles and works great. My 52 GMC is made up of 3 vehicles and so far is working good. Keep up the good work
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 05-10-2015, 02:21 AM   #35
Coldshot
Coldshot's Avatar
Got the mounts all tacked in yesterday and dropped the IRS back out to weld and pretty it all up.
Once that's all together I'll line everything up perfect and weld the nuts in there final spots.
Should be done that pretty quick I hope
Old 05-10-2015, 04:03 PM   #36
SkeeterBilt
SkeeterBilt's Avatar
rad, keep the pics coming
SkeeterBilt is offline   Reply With Quote
Old 05-12-2015, 09:29 PM   #37
Coldshot
Coldshot's Avatar
Thanks, got a bit more done. So more pics!
Welded up the mounts and checked it all up. Got my first crack at mocking up some strut towers.
Ok for a first attemp I think. Got more adjustments for sure tho.
Feels good to see all the new suspension hanging off the frame finally
Old 05-13-2015, 08:05 AM   #38
lower50's
lower50's's Avatar
That looks so cool !!
1951 MG TD
Old 05-13-2015, 12:37 PM   #39
Coldshot
Coldshot's Avatar
Thanks, can't wait to get past the chassis tho. After mocking up that first tower I realize what little truck bed I will have lol, not that I thought I was gonna get much. Only things going in the back will be stuff from ikea and track and car show supplies so I think I'm good.
Old 05-13-2015, 08:47 PM   #40
Coldshot
Coldshot's Avatar
Second try with the towers and its much better.
Start cutting I guess
Old 05-13-2015, 11:28 PM   #41
SkeeterBilt
throw some bags back there and then you wont need strut towers.....
Old 05-14-2015, 01:58 AM   #42
Coldshot
Coldshot's Avatar
If I wasn't building it to autocross I would. I'm building the towers in order to utilize the massive supra aftermarket suspension options. There's lots and they are cheap.
I think my next project I'll try bags
Old 05-14-2015, 06:29 PM   #43
solidaxel
solidaxel's Avatar
Originally Posted by ghettoluxury View Post
Supra suspension, that is an interesting choice.
YES, watching !!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-15-2015, 01:04 AM   #44
SkeeterBilt
yea i know, haha. some guys use the accu-air bags for autocross. be able to adjust your suspention for differnt courses
Old 05-15-2015, 06:04 AM   #45
Coldshot
Coldshot's Avatar
I did look into bags for what I'm gonna do. Would love to have a switch for ride height but those systems are not cheap
But like I said, next build.
I really want to do a cab over
Old 05-15-2015, 09:15 PM   #46
SkeeterBilt
yea that accuair stuff is biig money. more than a regular bag kit which is a lot of money. im digging the suspension. keep on truckin
Old 05-17-2015, 11:36 PM   #47
Coldshot
Coldshot's Avatar
So I did some cutting and tacking today.
Here is what I got done so far.
Everything is going good, all level and lined up
After more research I figured out my front strut hieghts and DAMN they are tall.
But I realize that in the supra the are pretty much equal with the top of the motor so they are just tall.
Gonna have to get more steel for those so I'm just focused on the rear for now.
Old 05-18-2015, 09:38 PM   #48
Coldshot
Coldshot's Avatar
Did a little more today.
Trimmed the little extra off the sides of the top, layed a few more beads to keep it all together better and drilled out the top on one side to mount up the strut. Just gotta do the other sides holes and it will be time drop the IRS out again to weld everything up.
Old 05-18-2015, 10:19 PM   #49
ghettoluxury
Not buch bed space left. Good thing it's a sport truck.
Old 05-19-2015, 04:21 AM   #50
lower50's
lower50's's Avatar
Love the look of the towers, it will really confuse ppl.
1951 MG TD
