Old 02-28-2015, 08:33 PM   #26
RedRoad
RedRoad's Avatar
Re: Shortening Axles- Dana 60 Rear and 44 Front
I asked a question about dually rear ends and the last post stated that the C&C housing is narrower than the regular dually and SRW versions. If you added SRW hubs to a C&C housing you could get it pretty narrow.
I have not done this myself so measure yourself to be sure
http://67-72chevytrucks.com/vboard/s...65#post7070065
RedRoad is offline   Reply With Quote
Old 02-28-2015, 09:34 PM   #27
CrewCab59
CrewCab59's Avatar
The SRW and C&C axles use the same housings and shafts, with the difference in width being in the hubs. The housings are actuallly identical except for the location of the backing plate flange. Drums & hubs are different, but backing plates, shoes, and wheel cylinders are the same) * The SRW and Van axles use the same hubs, the C&C and DRW axles use the same hubs; Though different, the SRW/Van hubs and the C&C/DRW hubs can be interchanged causing a change to the axles WMS (see pics below) SRW and C&C axle shafts are the same ** Van, DRW, and SRW/C&C axle shafts are all different lengths as follows (long/right side / short/left side):
1972 Custom Deluxe 20 4x4 burb
1971 GMC SWB CST 4x4
1972 GMC k20 4x4 (X- brush truck )
1971 Chevy CST Blazer 4x4
1971 Chevy C/10
1970 Cab Chassis C30 157"
1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica )
1988 Chevy V30 4x4 wrecker challenger 4812
CrewCab59 is offline   Reply With Quote
Old 02-28-2015, 10:13 PM   #28
RedRoad
RedRoad's Avatar
So what WMS do you get when you use a DRW hub/axles?
Also you mentioned a pic but do not see one.
Old 02-28-2015, 11:16 PM   #29
CrewCab59
CrewCab59's Avatar
This is the SRW & Van hub pic.
1971 Chevy C/10
Old 02-28-2015, 11:17 PM   #30
CrewCab59
CrewCab59's Avatar
This pic is a C&C and DRW hub.
1971 Chevy C/10
Old 03-01-2015, 12:07 AM   #31
CrewCab59
CrewCab59's Avatar
Sorry here is the pic.
1971 Chevy C/10
