05-27-2015, 11:56 PM | #26 |
Re: Green Beater
im tellin ya in the end i wish i had just done the ls swap
1981 Silverado C10 LS/4l60e My truck may be loud and ugly but I love her like bacon |
05-28-2015, 11:41 AM | #27 |
Re: Green Beater
I actually weighed the cost of a new sbc and 700r4 against the cost of a LS swap and the benefits of each and came to the conclusion that a LS swap was the right path for me but everyone and every situation is different brother.
74 Stepside"Steppin Wolf":78mm Turbo LQ4/4L80e,BTR stage 3 Truck cam,3.73 12 bolt with Detroit True-Trac Project Steppin Wolf Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=670303 My Youtube channel "Bad Luck Garage" https://www.youtube.com/channel/UCRP...XkeEPCu_HmRfuw |
05-28-2015, 11:43 AM | #28 |
Re: Green Beater
Of course the fact that I have no intention whatsoever of ever selling the truck played a big role in that decision as well.
05-28-2015, 12:19 PM | #29 |
Re: Green Beater
If I didn't have to smog my truck I would consider a ls. I just don't have the funds for doing it the smog legitimate way, I would have to take it to a referee ect.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
05-28-2015, 08:12 PM | #30 |
Re: Green Beater
well going to pull the thm350 out tomorrow after work and rebuild it over the weekend. i have a friend that runs a transmission shop and he said bring it over saturday and he will walk me through it but i have to do the actual work myself
05-30-2015, 03:32 PM | #31 |
Re: Green Beater
so my friend at the transmission shop lied. he didn't let me do a dang thing lol
trans is rebuilt and already back in truck. haven't drove it yet other than to back it up and clean up my mess at work. but i can say that reverse works a lot better lol. Wife is going to drive me back to work tomorrow so i bring it home.. told her that i guess i need to start looking for something to trade it for and she threatened to divorce me lol
05-31-2015, 11:41 AM | #32 |
Re: Green Beater
thats gettin er done!!!
05-31-2015, 03:14 PM | #33 |
Re: Green Beater
it is oh so nice to have a proper reverse gear again.
i also backed my timing off a couple of degrees and engine is running even better. still need to lean out carb a little but i am really enjoying driving my truck right now
06-20-2015, 11:45 PM | #34 |
Re: Green Beater
truck is running good. headers are leaking, of course, so need to fix that. also need to get around to replacing turn signal cam and turn signal lever that have been riding around in my front seat for two weeks.
07-17-2015, 09:29 PM | #35 |
Re: Green Beater
last weekend i tore apart the steering column to repair idiot damage by the previous owner.
ignition switch was mounted wrong making it where truck would only start with column straight and they took out and threw away the turn signal cancellation cam. replaced the broken turn signal lever while i was at it. put in 2 new u joints today. as far as i could tell truck still had factory u joints and rear one had started popping/snapping.
07-25-2015, 03:06 PM | #36 |
Re: Green Beater
Factory u-joints? wow!
Current Build 89 s10 ecsb 2wd 4.3/700r4 50k OG Miles Instagram- shaggin_s10 '86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt (Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD |
08-17-2015, 09:11 PM | #37 |
Re: Green Beater
Been having some issues with the truck here lately. Mainly idle issues plus my brakes suck and i am going to admit why.
I chose way to big of a camshaft for the engine. 231 duration @.050 and .480 valve lift. engine only has 9 to 1 compression. I knew better and even told myself not to do it but i already had it so figured what the heck. Now i need to pick another cam and do a weekend swap...hopefully with out having to pull engine to do it. Recommendations are greatly welcomed rest of engine as follows 9 to 1 compression stock bore 2 bolt main stock bottom end 1992 swirl port heads dual plane intake hei dist. headers th350 trans w/3.08 rear gears
08-17-2015, 09:53 PM | #38 |
Re: Green Beater
truck sees mostly high way driving at "about" 55 with some light hauling.
i am eye balling the cs1014r cam or one near that spec http://www.fme-cat.com/overlays/part...aft&brandId=SD
08-22-2015, 01:08 AM | #39 |
Re: Green Beater
http://m.summitracing.com/parts/cca-12-234-2
I am running a comp xe256 in my 350 and it runs great and has a good operating range they say idle to 5500 but it's more like 1200 to 6500 I plan on putting motor in a 2wd when I get one but I have put nearly 25000 miles on it in a lifted 4x4 and had no issues with idle or brakes. I have had an auto trans and now have a 4spd behind the motor and it's likes both. Also it will work with all of your 4bbl carb options q-jet, holley, or edelbrock.
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 Last edited by bmchevy1979; 08-22-2015 at 01:24 AM. |
08-22-2015, 07:33 AM | #40 | |
Re: Green Beater
I have essentially the same grind, 231°@050/0.470"/108LSA/104ICL, and had to do a world of changes to make it work: 10.9:1 compression, Full re-jet of Rochester, aggressive ignition re-curve, different valve springs, high-stall torque converter, deeper rear gears. It sounds awesome, but it's maybe not a truck cam. Either of the two that were posted would be a LOT better, especially with the 3.08 gears and a stock converter.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
08-22-2015, 01:12 PM | #41 |
Re: Green Beater
i like the one Bmchevy posted better than the one i did. will start rounding up parts in next week or so to get this done. This time using my brain instead of my ego to pic a more compatible cam lol. this is one of those things going to be filed in my rather big DA file.
(da stands for yup you guessed it)
09-07-2015, 09:03 PM | #42 |
Re: Green Beater
Cam swap went ok today other than having to buy a new radiator cause my old brass/copper one had split a seam. went with the cr1014r speedpro camshaft. truck runs smoother but still has a nice sound to it, the throttle response is much better at lower rpms now and it only takes one foot to operate the brakes. should have went this way to begin with. on a side note the truck is also quieter with a deeper tone.
09-08-2015, 12:44 AM | #43 |
Re: Green Beater
Not to bad thats not far off the cam I mentioned should run good how's the power band on that cam similar to what I mentioned or does it taper off sooner
My truck is mild mannered noise wise until you lay into it then she comes alive. Pissed off alot of hondas when they want to race against a lifted 4x4 and they dont even get a car length on me before I start pulling on them Lol or they never get ahead those are the guys that think they have more top end and I'm already going 55 most of the time I dont even need to to down shift but when that big ass truck comes flying around them at 6000 rpm the look on there face is priceless
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 Last edited by bmchevy1979; 09-08-2015 at 12:55 AM. |
09-08-2015, 08:16 PM | #44 | |
Re: Green Beater
hoping for a gain in fuel mileage too. time will tell on that one.
12-03-2015, 12:34 AM | #45 |
Re: Green Beater
quick check in and few quick updates. none of which involve pictures sadly.
late in october i switched out the reman quadra jet for a new 670 street avenger holley. needs re jetted but still improved over the rochester in drivability. replaced dash speakers as i blew mine. found pair of kickers on sale for 21 bucks. much better. finally hooked up the lights on my mechanical gauges while i had dash apart to do speakers. installed new rear brake shoes and resurfaced drums today.old rear shoes had less than 1/8th of inch left. noticed that if you take my truck over 66 mph need falls to 80 and stays there until you slow back to 55-60. this will need to be addressed as i am in no need of a ticket right now.
12-05-2015, 06:24 PM | #46 |
Re: Green Beater
ok so problem. rear brakes are inactive and can not get proportioning valve to recenter. going to have to pull it off next weekend and see what i can do
12-15-2015, 09:37 PM | #47 |
Re: Green Beater
did not get to touch truck last weekend as planned. instead spent saturday doing brakes on my parents truck. will hopefully get to it this weekend. need to warranty out my starter too as it cranks really slow at times. optima battery test good at 967 cranking amps.
12-18-2015, 11:56 PM | #48 |
Re: Green Beater
rejetted street avenger today. had 65s and 68s in it. moved the 68s to the front and stuck 72s in the rear. off idle bog is gone and partial throttle acceleration is improved. still feels like struggling at wide open a little. need to get a adjustable timing light and see if a distributor recurve is in order.
12-21-2015, 09:50 PM | #49 |
Re: Green Beater
Hurray!!! I now have rear brakes.
I attempted to repair my rear brakes on the 19th but could not get fluid to them. I made sure to recenter the proportioning valve by pulling the light switch out and using a dart tip move valve to "neutral". I began disconnecting lines looking for my stoppage as I moved up stream but ran into a snag when the main steel line would not disconnect from the rubber line at rear axle. The nut had already been rounded by some one and pliers just would not get her done so i buttoned it up and made plans to repair latter. I have not had rear brakes for last year, so what is one more day right? Well today I cut the end off the steel line and replaced the nut and rubber line. Still no fluid to be found. So I moved up front to the proportioning valve and pulled line there. Nope nothing. OK, next I pulled the line coming into the valve from the master cylinder off. Nope nothing. This made no sense as on the 19th i had bleed at the master cylinder just to make sure it would pressurize. I put my vacuum bleeder on end of line down at proportioning valve and got nothing. Finally, being fed up, I pulled the line loose at both ends. What I found was a short sheet metal screw inserted in the brake line for the rear AT THE MASTER CYLINDER. Once removed and all lines reattached it took only about 5 minutes to bleed out the rear brakes. The truck now feels like will stop on a dime. What I find amazing, besides me taking a year to fix this, was that some one would block off the rear brakes completely instead of spending 15 bucks on some rear shoes. I found receipts in the truck showing all new front brakes being done shortly before I traded for it. Also, I changed my cam for better vacuum because the brakes sucked and on way home today I began wondering if i had found this and improved the brakes would I still have changed cams?
12-28-2015, 01:25 AM | #50 |
Re: Green Beater
Glad to hear you got the brakes worked, I by passed my rears so I can't say anything... lol
