Old 04-06-2015, 07:16 PM   #26
J Knight
J Knight's Avatar
Re: Need help with Tires
Originally Posted by lando713 View Post
Thanks for breaking all that down for me, I really appreciate it. The 28X12X15 was an original option believe it or not but I was wanting to make sure I didn't have to do any other modifications for them to fit. But this is exactly why I asked so I could get all the information I need and get the proper fitment. So, with the correct backspacing the 28's should fit no problem right?
And according to Jegs the reason I went with a 12 inch wide tire is because it has the "recommended" wheel widths listed there
The 28/12/15 should fit perfect with the 15x10 wheels with 5in bs, they are the same width as 295/50/15(12.2in) tire just 2in taller.
http://www.jegs.com/i/Mickey-Thompso...oductId=758838
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 04-06-2015, 08:34 PM   #27
Titomars
Titomars's Avatar
Originally Posted by SCOTI View Post
You indicate your truck is lowered. How is it lowered & how much is it lowered?
A 275/60-15 is 28" tall (w/variance per mfr).
3 inch front, cut springs, 2 inch rear, 3 inch drop shackles (1 1/2) remove 2 leaves from each spring pack (1/2). When I choosing tires I am damn sure the specs for the T/A's were 27.2, but I see they are 28 on an 8 inch rim. Mine will sit a bit lower due to rim width. So more like 27.5 I figure. Regardless my favorite rear tire size in the 70's and 80's was a L60/15 and the 275R60's are basically the same size. Back in the day I liked G60's up front on fullsize cars So I went with the 245R60's which are the same as a G60.
Yes I still think in alpha numeric tire sizes
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
Titomars is offline   Reply With Quote
Old 04-07-2015, 02:25 PM   #28
lando713
Thx will let y'all know how it comes out. Wheels take about 5 weeks they said
lando713 is offline   Reply With Quote
