Old 04-14-2015, 01:59 PM   #26
Duluth67
Re: Order of operations? '67 K20 Engine, Trans, T-case
I think I misinterpreted "front clip" and just went for the front stuff you see in the pictures, this was probably more work and it is less exposed o-well. Still a lot of work to do, and the tcase may be the hardest part
Duluth67 is offline   Reply With Quote
Old 04-14-2015, 02:18 PM   #27
motorcritter
motorcritter's Avatar
Leaving the fenders on can expose them to damage, but caution and patience avoids that sort of thing. I'm assuming you've got a 'high hump' transmission cover, that should be tall enough, although the shifter port hole may be different for a 420 vs a 465 (never had to deal with a 420). no1udknow, I was referring to being able to take the whole assembled clip off at once- a daunting proposition. Bit by bit, it is no sweat. Now the fun part is when I would pull an engine by hoisting it up by chaining the engine, standing underneath and cutting the motor mounts, letting the hulk fall down around me, engine hanging overhead and me standing in the now empty engine compartment, grinning profusely. That really freaked out the customers watching their engine get pulled.
If 'that which does not kill me, makes me stronger', then I should be Superman by now!
motorcritter is offline   Reply With Quote
Old 04-14-2015, 07:48 PM   #28
leftybass209
leftybass209's Avatar
That's great you got it figured out! Next time remember, the order of operations is
Step 1: Grouping symbols (),[],{} ||
Step 2: Exponents ie: 2 to the 3rd power
Step 3: Multiplication or Division, which ever is first from left to right
Step 4: Addition or Subtraction, which ever is first from left to right
I haven't had much luck figuring out how this applies to working on vehicles, but my math professor swears it's the only way to get the answer correct.
leftybass209 is offline   Reply With Quote
Old 04-14-2015, 08:41 PM   #29
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
If you don't battle the tcase crossmember when installing it back in the frame, your frame rails are bent and spread out. Yours sounds normal.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 04-14-2015, 09:01 PM   #30
Duluth67
On the topic of order of operations, do you suggest getting the crossmember bolted in first then get the t-case up there?
Also, what makes getting the bolt holes to line up easier? Punch? Bottle jack against frame?
Old 04-14-2015, 10:00 PM   #31
motorcritter
I've used one of those bird-head line-up tools to get things straight. Lashing the whole mess to a transmission jack can give you a degree of 'adjustability', but it's still an ungainly lump, and one of the 'not fun' parts of the operation. It's still easier than putting the transmission/transfer case assembly up to the bell house. That's an operation of nearly endless frustration. DAMHIK.
