Old 04-14-2015, 04:36 AM   #26
mechanicalman
Re: spark plug choice
Originally Posted by 1967chevy c10 View Post
I like accel sorty plugs. There good if you have headers do to tight space.
Used them on my 88 formula 350 after I put Edelbrock headers on it: Life-savers.
mechanicalman is offline   Reply With Quote
Old 04-14-2015, 04:51 AM   #27
mechanicalman
Originally Posted by blown&0chevelle View Post
Thanks guys. I still have the old point system if I was to change to hei is their anything I would need besides the distributor?
Your wires need to be specific to HEI cap, female wires cap end like the spark plugs, points cap takes a male end. You can use 7mm wires if they are made for an HEI, the factory did it all the time and they will fit factory looms; I have 7mm on mine, no deficits. Take your pick:
http://www.summitracing.com/search/p...20plug%20wires
Old 04-14-2015, 07:04 AM   #28
don t. - 72gmc
I read on this site years back, but I don't remember specifics.
If you swap points to HEI, there was a certain year Corvette plug wires that are the correct length to fit our trucks, and they had the correct ends.
HTH...don t. ...
don t. - 72gmc is offline   Reply With Quote
Old 04-14-2015, 09:14 AM   #29
EARNHARDT#3
EARNHARDT#3's Avatar
Right on! I agree with everything you said.
I think that at some point auto manufacturers and spark plug manufacturers played games with the actual heat ranges in order to sell their plugs to their people and to make Champion look bad as I don't recall them being standard equipment? Not sure. But I think with the many brands of cars now available, heat ranges are a bit more honestly portrayed?
No, let's NOT talk about oil filters, manifold vacuum vs ported vacuum, PCV valves, etc.
Don't forget about the infamous "PVC" valve LMAO!!!
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 04-14-2015, 09:44 AM   #30
enaberif
I will confirm on the 0.035 to 0.045 plug gap. My truck was converted from points to HEI and I couldn't figure out why my truck ran like crap until I checked the gap.
Also had to replace the points resistor wire which is easy enough to do with replacing the wire from the bulkhead. You'll need a new terminal end to do it properly though but then its oem.
enaberif is offline   Reply With Quote
Old 04-14-2015, 08:44 PM   #31
CST10
CST10's Avatar
0.035" for points. Hei use 0.045" gap. Plugs are your choice. I use R44TS since I do a lot of slow cruising and very little hauling loads in my truck. If you convert to hei it will run a whole lot better.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline   Reply With Quote
