07-13-2015, 11:14 PM | #26 |
Re: Installing The NV4500 5 Speed Overdrive Transmission In The C-30
Excellent work Leon! You made the whole conversion look too easy.
Scott |
07-14-2015, 02:51 AM | #27 |
ill have to remember this if I can ever find me a nv4500
07-14-2015, 02:43 PM | #28 |
Any interior shots of the final project?
07-14-2015, 03:15 PM | #29 | |
The Older Generation
Mine is supposed to be a '93 and it has an electronic output on it. I will be putting a GPS analog speedometer in it later. I don't have a clue what the ratio is as I wasn't really concerned about that with the 5 speed. I will have to check it out, but I would guess from the way it winds out and the shift points it is a 4.10.... Yes, I start out in 2nd and will only use the granny low when pulling the trailer or on really rough terrain. LockDoc
07-14-2015, 03:30 PM | #30 | |
I will post a couple of interior pictures later. This will work with the '92 - '96 (I think) NV4500's but it may not work with the later ones. LockDoc
07-14-2015, 07:06 PM | #31 |
Currently Blazerless
Good job Leon! I'll bet she feels like a completely different truck!
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
07-14-2015, 07:41 PM | #32 |
While it may be more work than some like, here is a bolt in floor pan I modified when I put the NV4500 in my old 4wd. This way I was able to use my original shift boot etc.
Posted via Mobile Device |
07-15-2015, 10:59 AM | #33 |
I had to do a double take, what a nice truck LockDoc! Mine could be it's twin!
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
07-15-2015, 12:19 PM | #34 | |
The first four gears are very close to the gears in the SM465, but adds the fifth gear, which is a 0.7:1 overdrive. The truck should drive just the same around town, but be more relaxed on the highway using the overdrive 5th. There are Dodge and Chevy versions of the NV4500, and Chevy used a couple ratios for the granny 1st. While varying slightly, the ratios are close enough that they would probably be indistinguishable from the driver's seat. The other advantage of the 5-speed- Truck trannys have pretty wide gear spacing. Adding 5th gear and swapping the rear axle for lower gearing (higher numerically) would be the same as having closer gear ratios. After the NV4500 is installed, I'll drive it for a bit and decide if I want to keep the same rear end gears or swap to something different. |
07-15-2015, 09:43 PM | #35 | |||
LockDoc
07-15-2015, 09:45 PM | #36 | |
I think mine is the lower 1st gear. I did some reading on it but I don't remember what they were now. LockDoc
07-16-2015, 06:17 AM | #37 |
Nice job...If not mentioned already... I know a guy who put a 4500 in a Chevy and used a Dodge version. He claims it requires less modifications?
07-16-2015, 08:21 PM | #38 | |
It's been too long since I researched it but I think the later Chev and Dodge versions sit on an angle (tilt to one side) and the input shaft is longer. That is all I remember about them. LockDoc
07-16-2015, 08:26 PM | #39 |
Here are a couple of shots of the interior showing where the modified shifter sits. If anything it might need to be shortened a couple of inches. That would be no big deal since it unscrews from the stub coming out of the tower. LockDoc
07-16-2015, 08:51 PM | #40 |
Post Whore
I have the later model gm nv4500 in my c30 and there is no tilt to it..my tailshaft is much shorter than yours though..with the gm electric speedo I used a dakota digital to convert it back to cable drive and kept my stock speedo..on the dodge nv the input shaft is longer and needs swapped out for a gm input shaft to make it work but the bonus is the dodge uses a cable speedo so no converter is needed. I've got 4.10 gears in mine and its great with the overdrive.
07-17-2015, 06:23 AM | #41 |
Now I remember about the Dodge version...It has a mechanical speedo drive and was not a tilted tranny. It also has a 1-1/8 10 spline... I believe it was from a early 90's Cummins Dodge..
07-17-2015, 04:18 PM | #42 | |
LockDoc
07-18-2015, 07:29 AM | #43 | |
You are correct.....The guy I know who put a 4500 in a 59 GMC has this to say
07-18-2015, 09:23 AM | #44 | |
That is good info to know but the whole point of this thread is to show guys how to do this on the cheap. That adapter plate is $270.00 from Summit Racing. I didn't have to buy anything to install the '93-'95 Chevy NV4500. If a guy already has the Dodge 5 speed or has access to one cheap enough to override the cost of the adapter then that would be the way to go. Here is a link to the Dodge NV4500 adapter for the guys that need to go that way: http://www.summitracing.com/parts/add-712550 LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 07-18-2015 at 09:32 AM. |
07-18-2015, 10:31 AM | #45 | |
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
07-18-2015, 10:59 AM | #46 |
but on the other hand the dodge trans is the only one that will accommodate a mechanical speedo. the chevy ones you either have to buy a $280 converter box to keep your original speedometer or hack in some electric one. so its 6 to 1 all depends on what you want to do.
07-18-2015, 11:49 AM | #47 | |
For now I'm using my Garmin that I already had. It's working out great and I just selected the screen that shows the MPH in the main area. LockDoc
07-18-2015, 12:31 PM | #48 |
I also suppose it depends on how much you pay for a tranny and what's easier to find. Around here there seems to be more Dodges with NV4500's that are being parted out.
07-18-2015, 06:21 PM | #49 |
I swapped some parts for a 1997 NV4500 that came with the stock bell housing, clutch, PP, slave cylinder, drive shafts and shifter. In all I had $300 in the swap kit. With the 5.3L swap, a sachs 1050 flywheel, a high hump tunnel, and motor mounts for the newer engine to sit in the stock SBC location, I just had to move the transmission cross member about 3.5" back (using the factory holes) and everything bolted in place. The gearbox lined up perfectly with the high hump opening. I had to modify the drive shaft cross member and shortened the rear NV4500 specific drive shaft. I hope to get the drive shaft monday so the truck can be back on the road in a few days.
07-19-2015, 06:45 AM | #50 |
The guy who used the Dodge 4500 also told me the shifter location is about 4-5 inches further back than the Chevy version... That photo above reminded me...
