Old 06-29-2015, 11:00 PM   #26
tre5
tre5's Avatar
Re: Tre 5 Customs 1980 C10 build
Starting to get this thing back together, just so it can all come back apart again.
Follow me on facebook and Instagram. Tre 5 Customs
My '49 http://67-72chevytrucks.com/vboard/s...d.php?t=673809
Customer build: 67 Blazer Roadster http://67-72chevytrucks.com/vboard/s...d.php?t=443105
Customer build 1980 C10 http://67-72chevytrucks.com/vboard/s...49#post7210949
tre5 is offline   Reply With Quote
Old 06-29-2015, 11:03 PM   #27
tre5
tre5's Avatar
Also got all the floor welded back in. The Porterbuilt "bolt in body drop" isn't designed to get the truck laying pinch. Mainly because of all the extra work it requires to get it there. Well, we decided to modify the kit a little, then clearance the floor so it lays on the pinch like my customer wants. I'm sure some clearance around the trans would've been necessary, so it really wasn't much more work.
Old 06-30-2015, 04:21 PM   #28
solidaxel
solidaxel's Avatar
Boy that was fast, a square and a AD fan, you have them both covered!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 07-05-2015, 12:50 PM   #29
tre5
tre5's Avatar
We got the new Griffen radiator insalled. It was supposed to be a "direct fit" but we ended up welding some pieces to the side of it and using the same snapper grommets to mount it to the core support.
A look at the engine compartment so far
Old 07-31-2015, 08:20 PM   #30
tre5
tre5's Avatar
Working on the engine compartment some more. Modified the Eddie Motorsports hinges to clear the tires.
Mounted the brake booster and Baer Remaster up and got the steering hooked up
Old 07-31-2015, 08:34 PM   #31
tre5
tre5's Avatar
Then I sent it over to Hubcaps Hotrod Designs for some sheet metal work
Old 07-31-2015, 08:42 PM   #32
Hart_Rod
Hart_Rod's Avatar
Looks great! What are you doing for the rear wheel tubs? Check out my ChubTubs:
http://67-72chevytrucks.com/vboard/s...d.php?t=676606
Let me know what you think. Keep up the great work!
Hart_Rod is offline   Reply With Quote
Old 08-01-2015, 10:33 PM   #33
youngrodder
youngrodder's Avatar
Another top notch Tre5 build. Nice work.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 08-02-2015, 11:24 AM   #34
TrailerTrash
TrailerTrash's Avatar
dam this thing is SLICK
TrailerTrash is offline   Reply With Quote
Old 08-02-2015, 01:02 PM   #35
Advanced Design
Advanced Design's Avatar
Very nice design and execution with the metal work. Looks great!
Advanced Design is offline   Reply With Quote
Old 08-03-2015, 12:50 PM   #36
Low Elco
Killer metal work. Props to all!
Low Elco is offline   Reply With Quote
Old 08-06-2015, 08:49 PM   #37
tre5
tre5's Avatar
The truck is at the body shop (only two doors down from my shop) for the time being. It'll come back to get the bed done and some other small stuff before it actually gets painted. They started with the fresh metal work under the hood.
Old 09-08-2015, 10:03 PM   #38
tre5
tre5's Avatar
Here's a video of the bed working.
https://youtu.be/YG1HWTBOT3k
Old 09-08-2015, 10:09 PM   #39
Advanced Design
Great action on the bed floor. What actuators did you use?
Old 09-08-2015, 11:05 PM   #40
tre5
tre5's Avatar
Thanks,
They're just 250 lbs ones off ebay. Nothing special.
Old 09-09-2015, 11:23 AM   #41
carboncrew
carboncrew's Avatar
Your projects are sick. Gotta say though, the crew is my favorite
Pics don't do any of the projects justice....I drive by really slow (yes like a creeper) when visiting Trend Auto.
________________
My very own build
My tailgating ambulance
carboncrew is offline   Reply With Quote
Old 09-09-2015, 01:42 PM   #42
BigMike608
BigMike608's Avatar
Very very nice!
1977 SWB C10 - "Woodson": 5.3 Vortec LS Swap, 4L60e Trans, 4.5/5 drop
BigMike608 is offline   Reply With Quote
Old 09-09-2015, 11:48 PM   #43
tre5
tre5's Avatar
Some pics of the bed. It's all done now and off to the painter.
Old 09-09-2015, 11:49 PM   #44
tre5
tre5's Avatar
Located some battery jumper terminals in the gas door.
Old 09-20-2015, 10:09 AM   #45
tre5
tre5's Avatar
Stripped everything down to nothing for paint and powder coat.
Here's a shot of some of the parts. The inside of my truck was full as well.
I was able to talk my powdercoater into getting everything done in less than a week by ordering and paying for the powder myself and getting the frame sandblasted before I brought it to them. So I dropped the chassis off for blasting on Monday, picked it up Tuesday morning and headed to the powdercoater Tuesday afternoon. Then went back there with the powder from Prismatic Powder on Wednesday. They sprayed it Thursday and I picked it up Friday, arriving back at my shop around 1:30pm. We wasted no time getting it back together...
Old 09-20-2015, 10:12 AM   #46
tre5
tre5's Avatar
While all this was going on, Frank and his crew at IKandy Paintworks were busy on the shell of the truck.
Old 09-20-2015, 10:13 AM   #47
tre5
tre5's Avatar
The bed is just about ready as well.
Old 09-20-2015, 12:13 PM   #48
lolife99
67-72 parts collector,…
lolife99's Avatar
You guys are killing it!
Keith
Convert to disc brakes.
Old 09-20-2015, 07:57 PM   #49
Advanced Design
Really awesome...and fast.
Old 09-21-2015, 05:07 PM   #50
tintbox
Nice Truck!!!!!!!!!!!!!
tintbox is offline   Reply With Quote
