08-18-2019, 08:23 PM | #26 |
Re: Did 86 silverado come with 305 and 700R4??
The thread title is misleading. Silverado is just a trim level. Doesn’t have anything to do with the engine. Doesn’t have any thing to do with 10/20/30 series truck.
A better question would be, did the 305 come in the c10/k10? I’ll throw in, my 85 k10 left the factory with a 5.0. |
08-18-2019, 11:41 PM | #27 |
Yes they did
Posted via Mobile Device |
08-19-2019, 02:07 PM | #28 |
I own an 86 k10 with the 305/7004r combo... even has 3.08 gears. I very rarely use overdrive, and it is extremely anemic.... may be the slowest v8 powered anything ive ever had... BUT it starts great in sub 0 cold, andthe 4wd works great too!!! I have an 83 c30 srw for pulling duties...
Mike
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
08-21-2019, 10:48 AM | #29 |
the 84 parts truck I had was 305 and 700r4
08-21-2019, 11:28 AM | #30 |
My goodness, gentlemen -
Just when I thought I had you all trained. K https://www.gmheritagecenter.com/doc...olet-Truck.pdf
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
08-21-2019, 11:36 AM | #31 |
So - if anyone still cares at this point - the answer is:
Yes - in a K10 with California emissions. I should add that one could purchase a vehicle with CA emissions for Federal use. There were no restrictions against that, and we used to do it all the time in order to get the larger cubic inch engine (and then immediately rip off all the emissions controls). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 08-21-2019 at 03:09 PM. |
08-21-2019, 07:45 PM | #32 |
Junior Member
305 if it's an LE9 is a great motor if you take advantage of that high compression! I had a 305 LE9/7004 with a 3.08 gear in a K10. After I replaced the flat cam with a Summit K1101 it did well! Had good power and TC stayed locked up on all but the steepest highway grades.
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Gold White Fleetsides/Saddle |
