Old 08-27-2015, 10:25 PM   #26
Chevystep
Re: DIY 3 Point Seat Belt Installation 1960-66 Cab
Wow, great write up and bookmarked! I think I already have shoulder belt fasteners (the upper ones) in my 66, but with only lap belts in it. Maybe they were thinking about it in late 66? I'll try to get some pix and some measurements of them and their location.
Chevystep is offline   Reply With Quote
Old 08-27-2015, 10:28 PM   #27
Lugnutz65
Lugnutz65's Avatar
Some of the 1966 trucks had shoulder belts. Some had plugs to go in the holes if that truck was not optioned with the shoulder belt. The factory location is important to some so I'm sure your info will be helpful to them.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 04-10-2016, 08:17 AM   #28
Nevada51
Thanks for this, it's an excellent write up - very comprehensive.
I did a similar thing for rear belts in a VW beetle but instead of welding the point in, we used Sikaflex sealant on one side of the washer, pulled it in to place, and held there while it formed a bond. The bond strength is probably not great, but as mentioned, its not the strength of the welds that matter, it's the washer etc behind the metal that does the work. I thought it was worth mentioning this as the whole thing could then potentially be done by someone who doesn't have a welder, and/or where you don't want to damage the cab paint.
Cam
Nevada51 is offline   Reply With Quote
Old 04-10-2016, 09:20 AM   #29
DakotaKid
awesome writeup, when I do my BBW conversion, ill weld the top one together before I reinstall the rear window surround. Great on measurements!
Current Project : 1962 Chevy SWB Fleetside
Others, 1958 Edsel Villager Station Wagon
1926 Ford Model T Roadster Hotrod
www.suedescarclub.com
DakotaKid is offline   Reply With Quote
Old 04-16-2016, 10:23 AM   #30
GWs62
GWs62's Avatar
Great write up. I just finished my seatbelt install (Seatbelt Planet) and since my cab is painted I used rivets instead of welding. Drilled a small hole in the washer that matched the small hole I drilled in the cab. Lined them up and bingo!
When was the last time you did something for the first time?
We never really grow up, we only learn how to act in public.
GWs62 is offline   Reply With Quote
Old 04-20-2016, 03:38 PM   #31
vince1
I am about to drill the upper holes. Lugnutz did you weld a 7/16" or a 1/2" nut to the washer and coarse or fine threads? Thanks for this. It certainly takes out the guess work.
vince1 is offline   Reply With Quote
Old 04-20-2016, 04:14 PM   #32
62 short step
62 short step's Avatar
Nice! Now I need to do mine!
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 04-20-2016, 04:50 PM   #33
Lugnutz65
Lugnutz65's Avatar
Originally Posted by vince1 View Post
I am about to drill the upper holes. Lugnutz did you weld a 7/16" or a 1/2" nut to the washer and coarse or fine threads? Thanks for this. It certainly taTkes out the guess work.
The nut you weld to the washer needs to match the bolt threads that come with your seat belt set. So just make sure the bolt used for the shoulder mount matches. That's all there is to it.
Old 04-20-2016, 07:59 PM   #34
vince1
I guess it is off to the junk yard tomorrow to find a donor vehicle and will report back if I find something suitable.
Old 01-02-2021, 10:38 AM   #35
J Williams
J Williams's Avatar
Very nice write up! Thanks man
63 C10
J Williams is offline   Reply With Quote
Old 01-02-2021, 01:10 PM   #36
vince1
I went for the Silverado seat with built in belts.
Old 07-05-2021, 03:13 PM   #37
Vortech
Vortech's Avatar
My GMC has seat belt holes existing around 2" further back at the base. Think I would have an issue using these holes and just making the upper holes as suggested in this thread?
Vortech is offline   Reply With Quote
Old 07-05-2021, 03:14 PM   #38
Vortech
Vortech's Avatar
passenger side
Old 07-05-2021, 03:29 PM   #39
The Rocknrod
Moderator
The Rocknrod's Avatar
Vortech - Mine were close to yours, that's where I mounted the L-shaped bracket for the retractor on mine.
Old 07-05-2021, 06:18 PM   #40
Vortech
Vortech's Avatar
great, thanks
Old 11-27-2022, 09:37 PM   #41
Arne
Arne's Avatar
Same issue here, the interior of my truck's cab was painted by the PO before I bought it. So welding wasn't an option.
My belts also came from Seatbelt Planet, and I ordered a pair of mount plates for the upper mounts. These plates have a pair of small holes for rivets (or small bolts, I suppose).
https://www.seatbeltplanet.com/i-304...tegory:1389311
After drilling the main hole, I set the plate over the hole from the outside, and marked only the lower rivet hole. I figure the whole point is not to add any strength, but just to hold the plate in place when you take out the seat belt later. A single rivet will do that just fine.
By using only the lower hole for the rivet, the rivet head is hidden by the seat belt when everything is in place. No welding or painting needed.
- Arne
Finished Project - 1964 C10 Stepside, mild restomod
覧覧覧覧覧覧
Arne is offline   Reply With Quote
Old 11-28-2022, 03:17 PM   #42
Vortech
Vortech's Avatar
what length do you need for the center lap belt.
Old 11-28-2022, 04:56 PM   #43
Arne
Arne's Avatar
I didn't get a center belt, at least not yet. But the 60" should be correct, I've used that one on a different project for a single lap belt, and it was just fine.
- Arne
覧覧覧覧覧覧
Old 12-01-2022, 12:18 AM   #44
slepysal
slepysal's Avatar
I used the same pate Arne used. I wound up using "new" surplus Hummer 3 point.... fit and work well
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 03-07-2023, 08:39 PM   #45
highwinger
highwinger's Avatar
Originally Posted by Lugnutz65 View Post
I got the belts from Seatbeltplanet.com. They are the Lift Latch 140 inch with 20 inch adjustable buckle. The all metal lift latch buckle can get very hot if you live in a hot climate so choose the buckle mechanism that fits your needs. My seat is all the way back and the buckle end belt is barely long enough. Adjust the behind the seat anchor location a little more forward if needed. I am very satisfied with the quality of the belts and mechanism. They also have pre-made anchors that will do the same thing I did when I welded the nut to the washer. The belts do NOT come with any anchors kits so be sure you order that stuff too.
Thank you very much for the wonderful write up! You made the install very straight forward.
highwinger is offline   Reply With Quote
Old 03-10-2023, 11:13 PM   #46
Lugnutz65
Lugnutz65's Avatar
You are very welcome.
Here’s an update that I’ll soon add to the original DIY.
I just finished installing 3 point seat belts in my 1963 cab. Another C10 owner commented to me that he was able to reach up into the B pillar high enough that he didn’t need to tack weld the fender washer/nut assembly to the inner wall of the B pillar.
Here’s what I did this time. I used 5 minute epoxy to hold the nut onto the fender washer. Once it was dry, I used masking tape to attach my crescent wrench to a large heavy paint stick. Then I used a VERY MINIMAL amount of masking tape to hold the fender washer/nut to the wrench. I was able to easily feed this up inside the B pillar and line it up with my predrilled hole. I was able to tighten the shoulder strap bolt onto the fender washer/nut with no problems. I then pulled DOWN on the paint stir stick to free the wrench from the fender washer/nut. The driver side required removal of the gas tank filler neck to gain access to the B pillar, so I guess I’d still recommend removing the tank to minimize frustration.
Old 03-11-2023, 09:30 AM   #47
ls60apache
as always great tech from lugnutz...also thanks for the T5 info that i used on my 57 210
ls60apache is offline   Reply With Quote
Old 03-11-2023, 01:59 PM   #48
Braunschweiger
Another great idea from them.
Greetings Harald
My 62 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=829782
Braunschweiger is offline   Reply With Quote
Old 03-14-2023, 09:37 AM   #49
Lugnutz65
Lugnutz65's Avatar
I値l send you a PM about this.
