09-25-2015, 10:09 AM | #26 |
Re: Project 72 Shades of Gray
09-29-2015, 02:04 PM | #27 |
Sweet build! What are you planning for rear tubz? Obviously you do awesome metal work and can build them yourself, but if you're looking to save some time, check out my rear tubs:
http://67-72chevytrucks.com/vboard/s...d.php?t=676606 EDIT: Looked over your posts again and noticed the picture showing the bed floor at stock height. Let me know if you have any questions about the hood brackets.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 09-29-2015 at 02:14 PM. |
10-02-2015, 09:47 PM | #28 |
project update... still trying to wrap up the construction and mods on the bed assy... the majority is fit and prepped to weld....
Does anyone have any alternative ideas to using the carriage bolts to build the assy?? seen anything,,, know of good quality hardware ect? |
10-02-2015, 09:54 PM | #29 | |
my facebook page for this build gets more updates and detail.. the name is 72 shades of gray c-10 build Im ready to purchase those hood hinge adj plates . |
10-02-2015, 09:57 PM | #30 | |
10-06-2015, 10:52 PM | #31 |
project update
still working on getting all the inner structure for the raised floor assy together.. welded the inners back on the outers and have the wheel house extensions/ outer wheel houses done and in primer. |
10-07-2015, 10:30 AM | #32 |
Looking good.
"Life is too short to drive a boring vehicle". Later, Wayne |
10-08-2015, 03:17 PM | #33 |
Looks good!
Corey Jones Designs CoreyJonesDesigns on instagram Ole Silver- 1967 stepside http://www.hotrod.com/articles/1103c...chevrolet-c10/ http://67-72chevytrucks.com/vboard/s...d.php?t=598758 |
10-09-2015, 07:57 PM | #34 |
project update.... just finished mating up, fitting, and tacking up the first extended factory wheel well.. have something special in mind to replace all the carriage bolts in the bed assy.
10-10-2015, 11:57 AM | #35 |
This is how we did the rear it's just a pieces out of an old bedside so it can fit in there really nice and then the inter fenders bolt upward. Worked out well may save you some time on your next one if you have an old bed to cut up...
10-10-2015, 11:58 AM | #36 | |
11-11-2015, 01:26 AM | #37 |
Project update ,,,,
The raised floor bed assy is fit and welded to the point it can be put on the stand...final skim coating needed on majority of it...underside needs some detail work as well as fir and finish on the tailgate....currently working on getting everything from the bed forward lined out and mocked up.. And all gaps perfected. Then. Confirming zero issues with alignment front to rear before frame slides out for blast and PC,. Went with the porterbuilt cowl mount hood hinge system and oversize tubs..putting this build on overdrive now...chassis expected complete with drive train before I can wrap up the mudwork and mods to the body... |
11-16-2015, 11:12 PM | #38 |
project update..
the bed assy is welded up in final position, there is some final fitting to be done in with the tailgate gaps ect. and the underside needs to be dressed up and prepped. Trying to get everything from the rear cab forward aligned for final fit, slipping the chassis out for blasting. The porterbuilt cowl mount hinges proved to be a little challenging considering the firewall was modified with different hinge system planned. the TUBZ are nice but aren't playing that way in regards to fit. Any advice or suggestions from those experienced are welcome. I am really curious about how others have approached painting and assembly with these tubs and metal finish panels... thanks. Has anyone had success with eliminating the hood hinge bolts (shaving them) and welding the strut bracket, either whole or partial? |
11-16-2015, 11:20 PM | #39 |
pics
11-16-2015, 11:23 PM | #40 |
more
11-19-2015, 10:40 AM | #41 |
67cheby
Looking great any other questions feel free to call me anytime 1-479-599-9664
11-19-2015, 11:47 AM | #42 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
