Old 07-31-2016, 12:44 AM   #26
crakarjax
crakarjax's Avatar
Re: CPP bent panhard bar
Where can I get a mount #2 as seen above? Anyone make repos of those?
My 68 3/4t has the same mount as the 63-64 so they were in use long after 65, at least in 3/4t trucks. I also had to chop off the bottom of the pass. side mount because of the thicket 3/4t trailing arms... not too happy with CPP for not calling out the differences.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 03-18-2017, 09:59 PM   #27
dano3
Got brackets from a 65 this is how clearance I have now. The last pic shows how far it moves the bracket, the rivet was the center of old bracket.
dano3 is offline   Reply With Quote
Old 03-19-2017, 11:50 AM   #28
rvrfoot
Its because its not a stock diff cover
rvrfoot is offline   Reply With Quote
Old 03-20-2017, 10:44 AM   #29
chevy_mike
Never Ending Projects
chevy_mike's Avatar
FYI, the adjustable end of the rod was supposed to got to the trailing arm bracket, not the frame bracket. This is why you had to move the mount, because the bend is wrong for that direction.
Here is mine,
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 03-20-2017, 11:40 AM   #30
crakarjax
crakarjax's Avatar
The mount had to be moved either way because it just puts the rod end in the wrong position. The rod end itself doesn't have any fore/aft move-ability because of the bushing ends, so it naturally doesn't line up with the alternative mount location and requires a custom or more common stock mount. This actually doesn't have anything to do with hitting the diff cover, that's just an additional side-effect.
Old 03-20-2017, 06:26 PM   #31
Slow Build
Slow Build's Avatar
This is a picture from CPP's site showing the bar mounted with the adjustable side at the frame bracket.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 03-21-2017, 10:47 AM   #32
chevy_mike
chevy_mike's Avatar
Well, I know it would not have cleared my diff cover the other way. I tried. Maybe there is no right or wrong way.
