Old 10-08-2015, 01:10 PM   #26
Eagletucky
Where did THAT bolt go?
Eagletucky's Avatar
Re: Kents 62 knock out knee knocker
Great looking work. Looks like a fun project!
The Swiss Car Club......A drinking club with a car problem....
Eagletucky is offline   Reply With Quote
Old 10-08-2015, 01:12 PM   #27
j.walters
j.walters's Avatar
the rear of the frame was boxed in. He made a front mount with a piece of angle. then bent his lower mounts to set it to the depth that would hide it the most and keep it safe. Then bent some straps to hold it down from the top. used some anti vibe rubber strips all around it to keep it quiet and firmly in place.
1964 swb bbw body drop on 22s ls swapped c10 build..
http://67-72chevytrucks.com/vboard/s...d.php?t=617623
j.walters is offline   Reply With Quote
Old 10-08-2015, 01:18 PM   #28
j.walters
j.walters's Avatar
well crap it wont let me add piks says I need to contact an admin...
Old 10-08-2015, 01:50 PM   #29
Classic v6 GMC's
Classic v6 GMC's's Avatar
Great work and I really like the dash!!!
Classic v6 GMC's is offline   Reply With Quote
Old 10-08-2015, 04:40 PM   #30
j.walters
j.walters's Avatar
here are those tank piks
Old 10-08-2015, 08:56 PM   #31
azdude1964
azdude1964's Avatar
Please give us more info on that tank is it a car or truck tank and where you got it?
efi 496bbc th350 custom brakes narrowed 9 coilover rear.
azdude1964 is offline   Reply With Quote
Old 10-09-2015, 12:17 AM   #32
rwade
rwade's Avatar
I am not as familiar with these years and I was told the 60-62 cabs were specific to those frames as far as cab and bed mounts. If that is true what did you have to do to make it all work on the 66 frame? I've got a 61 is the reason for my curiousity.
Thank you, Wade
rwade is offline   Reply With Quote
Old 10-09-2015, 09:51 AM   #33
j.walters
j.walters's Avatar
Everything was the same except the front mounts. on this one he just drilled out a new hole and used new mounting hardware to fab up a new mount. the inner brace runs over the 66 frame in the same area. really easy.
Old 10-09-2015, 09:55 AM   #34
j.walters
j.walters's Avatar
More piks or the dash annnnnnnnnd Who knows what the seat is ? and no it isn't from a 67-72.
Old 10-09-2015, 09:58 AM   #35
j.walters
j.walters's Avatar
Christmas time!!!!! well maybe a day or 50 early
Old 10-10-2015, 12:57 AM   #36
Captainfab
60-66 Nut
The rear bed crossmember and the crossills are also different since the '60-'62 frame is wider in the rear. However they can be modified to work with the '63+ frames.
Thank you, Wade
Old 10-13-2015, 03:47 PM   #37
j.walters
j.walters's Avatar
If anyone would know its him^. We haven't found that out yet since we aren't to mounting the bed. But now we know that its going to need to be modified. thanks Captainfab!
Old 10-13-2015, 05:19 PM   #38
Turtleman
Turtleman's Avatar
OK .. So stupid question?
"IF" you ever have to remove the tank,,, will you need to remove the bed first? From the Images it looks like the lower supports are welded to the frame?? Or am I just to old to see right?
Turtleman is offline   Reply With Quote
Old 10-13-2015, 05:35 PM   #39
j.walters
j.walters's Avatar
since the bed floor has to be raised for the notch it will have a hidden "trunk" where it will be accessible.
Old 10-21-2015, 04:08 PM   #40
j.walters
j.walters's Avatar
here are a couple of the gas tank mount removed
Old 10-21-2015, 04:14 PM   #41
j.walters
j.walters's Avatar
the original dealer badge and then three we scored nos from the grandson of the old dealer.
Old 10-22-2015, 09:10 AM   #42
j.walters
j.walters's Avatar
starting to build the rear suspension. He started off wanting it static dropped .... you see where that's got us.
Old 10-22-2015, 09:13 AM   #43
j.walters
j.walters's Avatar
I cut down a C-60 grille just to see if it flows with the look that he is wanting.
Old 10-07-2016, 05:27 PM   #44
j.walters
j.walters's Avatar
Since the last update the truck has taken a drastic turn. It turned from a nice driver to a full blown custom. Kent got a hold of Schott Wheels and had them make him a set od 22x9 and 22x12 billets.
Old 10-07-2016, 05:30 PM   #45
j.walters
j.walters's Avatar
Along with the new shoes and brake system he installed a Porter built drop member and a new rack. The front stance was achieved fairly easily.
Old 10-07-2016, 05:36 PM   #46
j.walters
j.walters's Avatar
The back required a lot more Fab work. The 2x4 rails were bent off of our specs by Art Morrison. Qa1 shocks were mounted behind the Dutchman 9in. ford. Aeromotive fuel cell w/pump and the Viar 480s were mounted in the back section as well.
Old 10-07-2016, 05:37 PM   #47
j.walters
j.walters's Avatar
There are plenty more piks of the process to be loaded.
Old 10-07-2016, 05:42 PM   #48
Bomp
Bomp's Avatar
Im in. Looks great
Bomp is offline   Reply With Quote
Old 10-07-2016, 11:46 PM   #49
Captainfab
60-66 Nut
Looks good, but I'm confused by what looks to be a set of lower link bars going to a crosmember to the rear of the differential?
Old 10-10-2016, 05:49 PM   #50
j.walters
j.walters's Avatar
Those are the shocks on the rear of the diff.
