Old 12-16-2015, 12:22 AM   #26
Zoomad75
K5Camper
Zoomad75's Avatar
Re: LS swap for my 75
Bruiser- We had talks about an 8.1. Fact was the engine that is in the polar bear came from my garage. My budget really wasn't jiving with the expense, harness and controller, ect. So we horse traded and I got the MEFI4 controller and custom harness to run the 5.3 on, he got the engine. Hindsight being 20/20 knowing what I've spent so far on the 5.3 the 8.1 swap might be a wash. Then again my 5.3 was a take out of a customer's truck that had us install a 5.3ho GM performance crate. So no cost out as he didn't want it. Mine has room to grow with the 5.3 though as a 6.0 isn't hard to find either.
Getting back on track, if the OP is planning on using the PCM and wiring from the donor truck, using a 208 isn't going to get the vss signal needed. Go look for a pass side drop 241 from a 90-91 Blazer or Suburban. Specifically, a 27 spline input to match the 4L60e. That will have the correct VSS tone ring and sensor on the output of the t-case to provide the input needed to the PCM. The 241 will bolt right up to the 4L60e too.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 12-16-2015, 12:34 AM   #27
lowrodderchev
lowrodderchev's Avatar
sweet thank you I'm going to start hunting tonight thanx again
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 12-16-2015, 11:42 AM   #28
68Timber
I know the pieces fit
68Timber's Avatar
Thanks for the correction.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 12-16-2015, 11:25 PM   #29
lowrodderchev
So was pulling the harness from the motor and I'm having a hard time removing the plug that's were the shifter arm is. Theres 2 plugs neither one of them will budge. Any suggestions?
Old 12-16-2015, 11:31 PM   #30
lowrodderchev
Its this plug
Name:  4l60e transmission is there a seal behind range sensor__ anyone know_.jpg
Old 12-16-2015, 11:40 PM   #31
lowrodderchev
Looks clean no
?Name:  WP_20151216_15_29_19_Pro.jpg
Old 12-18-2015, 01:01 AM   #32
Zoomad75
K5Camper
Zoomad75's Avatar
The connectors at the range switch are a little stubborn, but with a small pocket screwdriver or pick they should come free. The top connector, pull the blue clip out of the connector. Then lift up on the grey loop that is just to the left of where you pulled the blue clip from and it should release. Remember these are weatherpack connectors so the rubber gasket inside might not make the connector pop right out, you might have to work it side to side to get the gasket to release. The lower white connector just needs that bail end pulled up over the lock to release. Still, work the connector once it is loose from side to side to finally pull it out.
Heads look clean! Good Score!
Rob Z.
Old 12-18-2015, 11:12 AM   #33
lowrodderchev
Man I'm full of questions and a really appreciate all your guys help. So if I switch to a 241 case will I have to modify my cross member? If so what transfer case would you recommend to use to avoid modifying the cross member thanx again
Old 12-18-2015, 11:19 AM   #34
bowtieguy79
Ephesians 2:8
bowtieguy79's Avatar
Originally Posted by lowrodderchev View Post
Its this plug
Attachment 1477821
A heat gun will help loosen the glue GM put in there. Works like a charm! Nice swap!
bowtieguy79 is offline   Reply With Quote
Old 12-19-2015, 01:12 AM   #35
Zoomad75
K5Camper
Zoomad75's Avatar
I'm not sure of the specifics on mounting location difference from the 205 you have to the 241. The beauty here is if it's further back on the 241 vs the 205, just move the crossmember back to adjust. Worst case, get the 241 crossmember from the same truck you got the 241 from. At most you might need to drill a couple of holes in each frame rail to either slide the old one back or fit the 241 crossmember in.
Rob Z.
Old 12-20-2015, 06:42 PM   #36
lowrodderchev
how does $413 for a NP241 sound? or should I keep looking? not sure what they usually go for
Old 12-21-2015, 02:16 AM   #37
Zoomad75
K5Camper
Zoomad75's Avatar
It's a little high, compared to the one I picked up to replace my fubar'd 241. Got mine at a local boneyard for $220 or around there. Is that one a VSS version from a 90 or 91? That's the only two years you can shoot for. Oh yeah, go 1/2 ton only too. I thought I did and the one I picked up was a 32 spline input from a 3/4 ton with a th400. We didn't notice the difference until after we put it back in and we didn't have park. Park didn't work because the 27 spline output fits just inside the ID of the 32 spline input without touching a thing.
Look on car-part.com and search for the t-case with a 91 suburban v1500 in your area. I'm sure somebody will have one. That's how I located mine.
Rob Z.
Old 12-21-2015, 10:37 PM   #38
lowrodderchev
Thanx I'll check them out in not having any luck around here
Old 01-04-2016, 06:14 PM   #39
lowrodderchev
So I found a transfer case hopefully the right one the numbers,are
241c
1561 4199
116 903
272
Sound about right?
Old 01-06-2016, 10:23 AM   #40
lowrodderchev
Thanx Zoomad75 looked up that website found a np241 for $180. It 3 hours away but a buddy of mine is heading that way for vaca so he volunteered to.pic it up so now I need a shifter and crossmember
Old 01-09-2016, 11:57 PM   #41
Zoomad75
K5Camper
Zoomad75's Avatar
Good Score. Not a bad price either.
Rob Z.
Old 01-10-2016, 12:03 AM   #42
lowrodderchev
Got a shifter and cross member for $50 today
Old 01-12-2016, 11:32 AM   #43
lowrodderchev
on to my next question. slip eliminator. should I get one? ive read that a NP241 with 4 inch lift and 35's aren't the best together. to much stress on the back of the case and crack it. any suggestions, horror stories, or not that big of a deal?
Old 01-13-2016, 01:35 AM   #44
Zoomad75
K5Camper
Zoomad75's Avatar
I'm not planning on running one in my 91 with the 241. Mine has the slip yoke riding in the middle of the travel at ride height so my truck with 4" of lift is not a problem. The driveline angles don't look bad either. The bigger issue is the aluminum case being fragile on the rocks, not so much the tailshaft housing. I need a skid plate more than a SYE.
Keep this in mind, most SYE's are sold for Jeeps due to the extreme shortness of their rear driveshafts. A SYE allows one to add a little bit of length and a double cardan joint to correct for the crappy driveline angles on such a short wheelbase. K5's have twice the length or better in the driveshaft compared to the average TJ/YJ/CJ Jeep. This is the main reason to add a SYE on a Jeep or anything, not to stress on the output itself.
Yes a SYE with a fixed yoke driveshaft will yield the most strength, but are you planning on extreme rock crawling? Or are you planning on trail riding with moderate obsticals?
Rob Z.
Old 01-13-2016, 11:24 AM   #45
lowrodderchev
Defiantly no rock crawling, a trail here and there more speed bumps that tree stumps �� the crossmember i picked up has the skid plate so i should be ok thank you
Old 01-13-2016, 01:58 PM   #46
Front Range
Front Range's Avatar
Another option is a slip yoke CV if your concerned about high angle / vibration / stress.
Folks that throw dirt on you aren't always trying to hurt you, and folks that pull you out of a jam aren't always trying to help you.
Front Range is offline   Reply With Quote
Old 03-05-2016, 04:37 PM   #47
lowrodderchev
found a local guy that will do my harness and PCM for $400. seem about right? he said he even has a motor on a stand for me to see it in action.
Old 03-30-2016, 12:30 PM   #48
lowrodderchev
So finally making progress on it. Need to figure out the fuel lines. My motor has the return lines. I'm new to AN lines learning as I go. I order dirty dingo mounts, ac delco pump, and 87 tank and sender
Old 03-31-2016, 09:51 PM   #49
68Timber
68Timber's Avatar
That really looks sweet. I don't speak fuel line either, whether factory or AN. I see discussions on it here and read them to try to get up to speed on the basics but I think I need the Cliff Notes or something. Keep the updates coming.
John
74 Honda Z50 build
Old 03-31-2016, 11:51 PM   #50
lowrodderchev
Brown Santa showed with gifts �� 87 tank/sending unit, and dirty dingo mounts
