01-17-2016, 09:23 AM | #26 |
Re: Tailgate Seal
The pictures I posted above are the two vertical strips that go on each side of the bed. I still have the original horizontal strip, and it looks almost identical to the last picture above of the green truck. I'll post a picture of it later today.
Thanks. |
01-17-2016, 10:04 AM | #27 |
I'm trying....
Re: Tailgate Seal
Dan...do you have the metal vertical hold down strips pointed to in this pic? Based on your posts, I'm assuming you did not.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
01-17-2016, 10:13 AM | #28 |
I'm trying....
Re: Tailgate Seal
Well here you go. I stole this from Alex's very original 69 for sale post. I was oblivious to this type of seal. My truck was a base truck (no carpet, no side panels) from St. Louis and it had the metal strips holding the round profile seal to the inner side of the corner post. This type of seal looks like it is screwed to the jam. I love this site....now let's see if Dwayne can come up with a part number
01-17-2016, 11:37 AM | #29 |
Re: Tailgate Seal
No, I don't have those. Here's a picture of the horizontal carpet hold down. It had the remnants of a seal under it when I removed it.
01-17-2016, 12:14 PM | #30 |
I'm trying....
Re: Tailgate Seal
Yep...Dan I think your seal and carpet strip are what came on your truck. I think your set up is the same as Alex's red 69 pictured in my previous post.
Edit...I'm not sure of this, of course smarter more experienced folks weigh in...it seems right though.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." Last edited by IronCanine; 01-17-2016 at 12:22 PM. |
01-17-2016, 01:28 PM | #31 |
Re: Tailgate Seal
There is some adjustment(slotted holes) for seal to tail gate contact. The after market one piece I used seals very well.
01-17-2016, 02:58 PM | #32 |
Re: Tailgate Seal
Here's a closer view of what it would look like installed. I think I will try and find some of those metal strips and use the newer type seal. Like Doo mentioned, the sloted holes would allow for adjustment where my original one doesn't.
01-18-2016, 07:02 PM | #33 |
I'm trying....
Re: Tailgate Seal
Huh...well, I thought what you had fit in the jam. Your post/pic clears it up for me...I interpreted the pic of the red 69 to be what you had. Still never seen a tailgate seal like yours, though it looks like it was well engineered and probably worked well. If nothing else, it's made for a good thread. Maybe someone will post pics of a similar setup and shed some light on it. Makes sense to me to go with the "metal plates" set up.
01-19-2016, 07:49 PM | #34 |
Re: Tailgate Seal
Went to look at a 70 CST today. Look at it's seal I've
Never seen one intact. |
01-19-2016, 07:52 PM | #35 |
Re: Tailgate Seal
Carpet seal
01-21-2016, 10:04 PM | #36 |
Re: Tailgate Seal
This is what I have figured out so far the 69-70 are different than the 71-72. I am assuming the plate they are mentioning is the carpet strip but will have to do some more research.
01-21-2016, 11:14 PM | #37 |
Re: Tailgate Seal
Good find !! I also have part #5 but won't be using it on my build. Was that available on the 71-72? Just curious
01-22-2016, 08:39 AM | #38 |
Re: Tailgate Seal
01-22-2016, 08:40 AM | #39 |
Re: Tailgate Seal
I actually have on for sale on the forum check it out and see how it compares to yours.
02-06-2016, 12:23 PM | #40 | |
Re: Tailgate Seal
02-06-2016, 01:09 PM | #41 | |
Re: Tailgate Seal
All that to say, I would use seal trim, and be done with it.Attachment 1496296 |
02-06-2016, 01:15 PM | #42 |
Re: Tailgate Seal
Shown installed (sideways), then a picture of the channel the seal runs in.
