Old 01-17-2016, 12:34 PM   #26
Lattimer
Lattimer's Avatar
Re: FITECH EFI 600 Basic and Command center intall with pics, factory tank
Originally Posted by LostMy65 View Post
I'm thinking about installing mine on the passenger side inner fender back by the heater.
Edelbrock also has a sump tank unit that many mount up front on the radiator support. Go to YouTube and watch install videos of the Holley Terminator, MSD Atomic, EZ-Fast, and the Edelbrock E-Street. Many Pump/Tank install options with or without the SumpKit/FCC.
The Edelbrock tank looks like its a lot bigger than the FITech one. I looked at that one a while ago but couldn't see a good way to fit it without moving other stuff.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 01-17-2016, 12:56 PM   #27
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
There's a guy in these forums that made his own.
Here's a couple threads where there's been some previous discussion :
http://67-72chevytrucks.com/vboard/s...68#post7450468
http://67-72chevytrucks.com/vboard/s...d.php?t=686601
66 C20 Service Truck:
Old 01-17-2016, 01:02 PM   #28
steveo3318
steveo3318's Avatar
The 85551 is the exact one I am going with.
1967 c10 3OTT with R10 overdrive.
385 Stroker, 373 posi
FITECH EFI, Vintage air, York 210 OBA,
4/6 drop with riddler 20x8 and 20x10
1957 S5T Leslie Supertyfon train horns and EMD bell
"No bolt left unturned"
steveo3318 is offline   Reply With Quote
Old 01-17-2016, 01:06 PM   #29
LostMy65
LostMy65's Avatar
Cool! I'm going the same route as you.
First I'll get the FiTech EFI all up and running, then make the switch to Computer Controlled Timing.
Originally I thought my existing distributor was a nice MSD, so I was going to hold off on the timing control feature, but mines just an old GM HEI with a pretty MSD cap and wires.
Old 01-17-2016, 01:24 PM   #30
steveo3318
steveo3318's Avatar
My current dizzy is a Msd street Fire hei. Basically a exact gm hei replica with a few nicer internal parts. Don't throw your dizzy away. May be a street fire also
Old 01-17-2016, 01:33 PM   #31
LostMy65
LostMy65's Avatar
No, I found a stamped number on the side. It's out of a 77 vet.
Either way, I won't be throwing it away.
Old 01-17-2016, 01:41 PM   #32
LostMy65
LostMy65's Avatar
As far as I can tell, the only thing we need is a coil and phasing rotor. Nothing else is needed for the ECU.
Old 01-17-2016, 01:44 PM   #33
steveo3318
steveo3318's Avatar
CORRECTO FRIENDO I may buy an extra cap to drill a hole in to phase the rotor. Look it up on YouTube. Msd has a nice write up.
Old 01-17-2016, 01:48 PM   #34
LostMy65
LostMy65's Avatar
Yep, already saw that video. In the last couple weeks I think I've watched every msd video there is. Along with every FiTech, E-Street, Terminator, EZ-Fast, Atomic video there is. :-D
Old 01-17-2016, 01:53 PM   #35
LostMy65
LostMy65's Avatar
I've posted many links to videos, articles, and other forum discussions in this thread :
Old 01-17-2016, 01:55 PM   #36
siggyfreud
siggyfreud's Avatar
So does this thing run off the stock low pressure pump, and then using a secondary pump in that big until to boost the pressure?
siggyfreud is offline   Reply With Quote
Old 01-17-2016, 02:09 PM   #37
LostMy65
LostMy65's Avatar
Yes, but it isn't that big. There's a forum post of it next to a pop can.
Here's a video :
https://youtu.be/SsscxiUga5Y
Old 01-17-2016, 07:21 PM   #38
steveo3318
steveo3318's Avatar
Last pictures unless someone ask for more. Here she is all cleaned up under the hood and the paint touched up I chipped. I bought some wire mold I gotta put on behind the breather
Old 01-17-2016, 07:29 PM   #39
LostMy65
LostMy65's Avatar
What in cab heater are you using?
I'm thinking about installing my FCC there on the passenger's firewall.
Old 01-17-2016, 07:39 PM   #40
steveo3318
steveo3318's Avatar
I have vintage air the gen IV kit. Heater coil is in the cab with evaporator coil
Old 01-17-2016, 07:40 PM   #41
LostMy65
LostMy65's Avatar
Old 01-17-2016, 07:45 PM   #42
snipescastle2
snipescastle2's Avatar
Talking Re: FITECH EFI 600 Basic and Command center intall with pics, factory tank
Awesome install! This may have already been asked, but why do you have two A/C compressors? Or is one acting as an air compressor for a bagged suspension?
Thanks!
Ben Smith
snipescastle2 is offline   Reply With Quote
Old 01-17-2016, 07:58 PM   #43
Dave in Ozark
In regards to the phenolic spacer- how much of an issue is heat soak on a FI throttle body?
Dave in Ozark is offline   Reply With Quote
Old 01-17-2016, 09:02 PM   #44
steveo3318
steveo3318's Avatar
I collect and restore 100% real train horns and bells. I converted the compressor on the drivers side to an air compressor. I run 3 tanks. The 12 in back and 2 3 gallons for a total of 18 gallons at 200 psi regulated to 130 for the horns. No bags on the truck. Just a weird LOUD hobby. These are my 1957 bronze chambered Leslie supertyfons S5T and bell. Both off the same 1950's Norfolk Southern unit
Old 01-17-2016, 09:03 PM   #45
steveo3318
steveo3318's Avatar
Here's a video starting from a mile or so away
http://vid227.photobucket.com/albums...psyrdx6orc.mp4
Old 01-17-2016, 09:08 PM   #46
steveo3318
steveo3318's Avatar
I have never heard of any issues with heat soak on fuel injection. No problems with mine to date.
Old 01-18-2016, 09:17 AM   #47
truckdude239
truckdude239's Avatar
If it where me i would run hard line under the radiator and just use rubber to connect to the pumps that much rubber fuel line is asking problems
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 01-18-2016, 09:22 AM   #48
swampbog
swampbog's Avatar
Your neighbors gotta love ya
Seriously, that is cool as hell.
swampbog is offline   Reply With Quote
Old 01-18-2016, 09:28 AM   #49
swampbog
swampbog's Avatar
Originally Posted by dave in ozark View Post
in regards to the phenolic spacer- how much of an issue is heat soak on a fi throttle body?
i have never heard of any issues with heat soak on fuel injection. No problems with mine to date.
I wonder if it helps with fuel atomization, probably not much. I have a 1" spacer under my carb and I was wondering if I should keep it with the fuel injection or just remove it.
I wonder if anyone has done a test to see if it makes a difference or not.
Old 01-18-2016, 09:41 AM   #50
diggerbob
diggerbob's Avatar
That is bad to the bone. I bet folks poop their pants when you come up behind them and hit that train horn!
diggerbob is offline   Reply With Quote
