Old 04-11-2016, 08:49 PM   #26
mehoff400
Re: 65 long bed step side
was able to fire it up today and let it run for a little. i saw the temp gauge pined so i turned it off but i think it was just cause it was so low on coolant. would of messed with it some more but battery is about dead and buddy has battery charger.
66 c10 patina 250 T-5
My truck
mehoff400 is offline   Reply With Quote
Old 04-11-2016, 09:20 PM   #27
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Cool! Hope to see some footage!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 04-12-2016, 09:10 PM   #28
mehoff400
messing with it more today and i think i have a bad temp gauge. the gauge shows its overheated quicker than 2 min of starting the engine. crack the radiator and the coolant is very cold. any replacements or way of testing?
My truck
Old 04-13-2016, 12:34 AM   #29
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Maybe try a new sending unit?
Old 04-15-2016, 09:48 PM   #30
mehoff400
currently has a new sending unit. does it have anything to do with the placement of the sending unit? my 230 it was on the thermostat housing. with the 250 out of the nova i got its right above the intake/exhaust. i am wondering if the placement is heating up the sending unit?
My truck
Old 04-15-2016, 09:48 PM   #31
mehoff400
hood is on and ready for a test drive
My truck
Old 04-16-2016, 04:11 PM   #32
62stepside longbox
62stepside longbox's Avatar
Awesome! So how Was the drive with the new t5?
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 04-16-2016, 04:17 PM   #33
mehoff400
i drove it up the street a couple times and back. LOVE it so far just a little worried about going to far with my temp gauge not working correctly. i just picked up a laser temperature gun and going to flush the system to make sure its not clogged up with anything. i had some steam from under the hood but with no overflow bottle i believe its just from the overflow tube.
My truck
Old 04-16-2016, 04:25 PM   #34
62stepside longbox
The "steam" could be smoke from the engine getting hot and burning the paint off. It happens really easily on the exhaust manifold.
Old 04-16-2016, 04:30 PM   #35
mehoff400
yea that was my second thought. i just wanted to make sure. other than that it was running great.
My truck
Old 04-17-2016, 06:56 PM   #36
mehoff400
got a laser temp gun and everything looks good. took some water out of the radiator due to not having an overflow bottle. took her on 2 10 mile drive and nothing but a smile on my face having this T-5 is so worth it!!! i haven't taken it on the freeway yet but around town it sure is great. i need to get a couple things on order a longer speedo cable. and would like to get a stock tac
My truck
Old 04-20-2016, 11:25 PM   #37
mehoff400
today i tackled the headlights. they would start turning on and off after turning on for 1 min. added an upgraded wiring with relays in them problem solved and brighter lights. now to figure out what is going on with my rear turn signals. front will work as usual but the rear both will flash i have already replaced the turn signal switch in the column .. any suggestions?
My truck
Old 05-02-2016, 06:30 PM   #38
scoot_mcgrute
Curious what you did for the HEI power wire. I'm getting close to that step on my 66 and not sure 100% how to go about it. Did you replace the wiring from the bulkhead connector to the fuse panel too?
Truck looks great!
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 05-02-2016, 09:21 PM   #39
mehoff400
i can't help ya with that one. when i bought the truck it already had a HEI in it. i am sure tj's chevy can help ya out.
i do want to give an update i have been doing a couple freeway trips with the T-5 now. man this thing is just a cruiser now i can drive anywhere and not worry about a thing. before with the 3 speed i was worried about some step hills in my area. now its no issue and i am passing cars with ease. anyone looking to do the T-5 it is well worth it in my book.
My truck
Old 05-02-2016, 09:46 PM   #40
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
T-5 or tremec for the win! lol I can't wait to test my TKO out.
Old 05-02-2016, 09:47 PM   #41
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Truck looks great!
I wired mine from the ignition side of the starter solenoid. Seemed to work nice.
Old 05-04-2016, 02:31 PM   #42
scoot_mcgrute
Heck, I thought it would be harder than that!
Mehoff, you're on PNWJeep too aren't you?
1966 Army Truck
Old 05-04-2016, 07:09 PM   #43
mehoff400
yes, yes i am!
My truck
Old 05-05-2016, 01:29 PM   #44
scoot_mcgrute
yes, yes i am!
Thought so! I used to be but haven't logged in for a while and forgot my password.
1966 Army Truck
Old 05-18-2016, 08:22 PM   #45
mehoff400
Just installed a speedometer cable today i ordered a clifford intake and headers holley carb and new air cleaner here is the air cleaner.
My truck
Old 05-18-2016, 09:14 PM   #46
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Air cleaner is Sharp!
Old 06-14-2016, 09:16 PM   #47
mehoff400
new converted 3 barrel holley 600 carb.
My truck
Old 06-14-2016, 09:36 PM   #48
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Old 06-16-2016, 08:45 PM   #49
rusty76
rusty76's Avatar
Really cool truck.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 06-17-2016, 12:14 AM   #50
powell72
powell72's Avatar
Digging it, definitely my style of build.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
